01-07-2024, 11:40 AM | #1 |
Fuel line size for 250
I have a ‘68 with a 250, and the pump to carb line rusted through.
I need to replace it, but I don’t know what size the line is or what size the fittings are. Are they double flared? Any suggestions on what to use to replace it would be appreciated! |
01-07-2024, 11:56 AM | #2 |
Who Changed This?
Re: Fuel line size for 250
5/16" line, iirc. The line is double-flared. The nuts are 5/16" "B-nuts".
01-07-2024, 12:33 PM | #3 |
Awesome. Thanks! Now to see if my local parts store has any line on hand. The shelves have been looking pretty thin lately.
01-07-2024, 02:25 PM | #4 | |
To answer your flare question.. Yes, fuel line is double flared.. Pre-flared brake line is a good replacement for fuel lines. They can be joined together by using a brass Flare union, and bent to shape/fit using a common "hen house" tubing bender.. |
01-08-2024, 03:25 PM | #5 |
GM used 5/16" on 6 cyl and 2 brl v8 models. 4 brl v8 got 3/8"
3/8" fuel pumps flow more gas than 5/16 ones |
01-09-2024, 10:51 AM | #6 | ||
5/16" worked. I've got the new line bent up and in place. I did also learn that I need to work on my tubing bending skills Quote:
Thanks again for the info! |
