Old 01-11-2024, 11:40 AM   #1
Toro
Toro's Avatar
Fuse panel - new labels
Has anyone made new labels for their fuse panel? The original factory labels have faded/worn off on a majority of mine. It looks like the originals were painted on silkscreened on. It's very narrow on the edges, and I'm not sure what labels would even fit. Better solution would probably be one big label/sticker that included fuse cut-outs that could go over the entire face. Thanks for any input.
Toro is offline   Reply With Quote
Old 01-11-2024, 12:27 PM   #2
71CHEVYSHORTBED402
71CHEVYSHORTBED402's Avatar
Re: Fuse panel - new labels
Shame those made for a new harness aren't available, but I haven't done the research. Option to do that with labels and a printer. Or that big label. Or leave it alone Can always put an illustration in plastic sheet, keep it in the glove box.
https://www.loadzalabels.com/products/black-stickers
Tony
71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assembly kit for restoring the (a) truck from the ground up. My build thread, and more on the assembly kit https://67-72chevytrucks.com/vboard/...d.php?t=730025
71CHEVYSHORTBED402 is offline   Reply With Quote
Old 01-11-2024, 05:23 PM   #3
LS short box
Take pic of the fuse block and take it to a local graphic shop and see if they can help. If they can make you new labels have them do a 1/2 dozen sets. Use one set for your project and then sell the others to folks that are in the same boat as you are with a bit of a mark up.
LS short box is offline   Reply With Quote
