01-14-2024, 05:56 PM | #1 |
67-72 4x4 questions
So, I have a 69 k10 I'm restoring, It's currently on a shortened squarebody frame, and I want a longbed k20 by the end of it. I have a 72 c20 parts truck, trailing arm rear, could I use my squarebody front suspension under the c20 to make it a 4x4? Finding a 4x4 frame is impossible around me that someone doesn't want an arm and a leg for.
1994 k1500, Oldredz71(ext shorty 4x4 6 in lift) 1998 S10ZR2 2005 Silverado 2500hd(tow pig) Made in the USA, just like my trucks |
01-14-2024, 10:32 PM | #2 |
Born Psycho
Re: 67-72 4x4 questions
talk with board member BlueBullet, he's doing a longhorn to a K30 swap. i just sent him the brackets for the front leaf springs and your C20 frame has marks where all the brackets need to be mounted, it's even marked in the rear for leaf spring hangers. if you decide to go that route your squarebody rear diff will bolt in with the only modification needed is one shock mount will have to be relocated to the front of the axle housing.
jerry moss 72 cheyenne super K20- tilt,tach,vacuum,speedwarning,buckets,shoulder belts,am/fm,tow hooks,bumper guards,toolbox,aux. fuel tank,posi front and rear,plus other goodies!!! SOLD 69 suburban K20-tilt,tach,vacuum,speedwarning,buckets,shoulder belts,am/fm,4 inch all spring lift,4 speed, 14 bolt full floater, dana 44 HD,warn winch,posi front and rear,tow hooks,plus other goodies. 73/80 chevy/gmc K20 SB400,turbo 400,205,tilt,a-c,gas hog. 77 K/5 cheyenne blazer-daily driver/beater. SON HAS IT NOW BRENTWOOD,CALIFORNIA |
01-14-2024, 11:15 PM | #3 | |
01-14-2024, 11:38 PM | #4 |
All about them K’s
https://www.offroaddesign.com/replac...ucks-pair.html
https://www.offroaddesign.com/1967-1...ly-kevlar.html https://www.offroaddesign.com/tensio...hevy-pair.html The only thing I don’t believe ORD makes is the rear main eye hanger but you could always use all four 2wd hangers for a 67-72 2wd if need be. I’m not a fan of converting to 4x4 and leaving the trailing arms personally. There’s a little welding that needs to happen on the 2wd frame to mount the front shackle hangers but otherwise it’s not a bad job. Square body stuff uses longer front springs so it’s definitely not a “bolt in swap”. Not saying it’s not possible, it’s just more involved. You can use the sqaure body steering box, axle and drag link as they are all basically the same as 67-72.
Tyler '57 3100 http://67-72chevytrucks.com/vboard/s...d.php?t=813888 '72 K20 Cheyenne http://67-72chevytrucks.com/vboard/s...d.php?t=662879 ‘69 K10 SWB http://67-72chevytrucks.com/vboard/s...d.php?t=805206 '98 Silverado LT K2500HD ECLB Vortec 454/4l80E: 6" lift 315/75/16's ‘87 IROC-Z all original 50K mile survivor TPI 305 IROC Blue ‘10 Camaro 2SS/RS Aqua Blue Metallic #93 -version 2.0 Last edited by 57taskforce; 01-14-2024 at 11:43 PM. |
01-14-2024, 11:40 PM | #5 |
Born Psycho
yes it will bolt right in, you might have to fabricate brake lines. your steering box off the square body will bolt in too. you will need an engine and transmission crossmember for a 4x4. if someone close to you doesnt have them i have both but shipping would be a killer. i also have a torque bracket for a 205 transfer case if thats what you'll be running.
01-14-2024, 11:54 PM | #6 |
Sweet! I wonder if the square crossmember would fit, plan is to make it a leaf truck all around. I'd like to find a 205 but I do have a fresh th350 or a 465. Engine will either be a ls or a 350, whichever I decide to put in it as I have both. Plan is to make it a nice old truck but still be able to do truck stuff. One of the trailing arms is bad so I'm 99%sure it'll be leaf sprung when done
01-15-2024, 12:04 AM | #7 |
All about them K’s
Ord also makes a 4x4 engine crossmember too… look around on there any you’ll find it.
Tyler '57 3100 http://67-72chevytrucks.com/vboard/s...d.php?t=813888 '72 K20 Cheyenne http://67-72chevytrucks.com/vboard/s...d.php?t=662879 ‘69 K10 SWB http://67-72chevytrucks.com/vboard/s...d.php?t=805206 '98 Silverado LT K2500HD ECLB Vortec 454/4l80E: 6" lift 315/75/16's ‘87 IROC-Z all original 50K mile survivor TPI 305 IROC Blue ‘10 Camaro 2SS/RS Aqua Blue Metallic #93 -version 2.0 |
01-16-2024, 08:47 AM | #8 |
Just take all the Squarebody 4wd parts off that chassis and install them on your 2wd chassis...spring mounts, cross members, everything.
01-17-2024, 06:21 PM | #9 |
If special k says it'll work I know it will. Did some measuring and it'll move the wheels back half inch in the wheel wells up front, but I'm sure I can figure it out to make it line up right. I'd rather have a k20 long bed as I have a 94 shortbed show truck and haven't had a long bed. Plus, I've always liked the look of a lifted longbed.
