01-14-2024, 06:29 PM | #1 |
Rear sway bar install
Got my rear sway bar installed today. It is a POL RSBK6372. I had questions about where to mount it, even after reading the directions multiple times. I mounted it as close to the rear as I could and still able to reach frame with mounting tabs. It looks pretty good, and I think it will work well.
Front bar is next. |
01-14-2024, 06:46 PM | #2 |
70+ ( Old Skool Club )
Re: Rear sway bar install
I put a Hellwig Rear Bar on my 72 a couple years ago. I've had the truck long enough that could feell adiference when taking corners/curves spiritedly. Do you have a front bar on the truck already?
1972 C10 Custom/Deluxe 613 Highlander 406/700R4 1999 White Tahoe LS 4x2 with Z56 Police Package 1992 K1500 GMC Suburban Members I have personally met: MusicMan70 - HeavyD - ChewyChevy67 - StingRay -71SWB4x4 - 67 Burb - DeadheadNM - too much stuff - bc65 - das601 " Circumsatances Do Not Change Responsibility " " The Sky is not the Limit, Your Mind is." Marilyn Monroe .. RIP Charlie Watts 1941 - 2021 |
01-14-2024, 07:07 PM | #3 |
Who Changed This?
That's looking good! After putting on a much taller camper and using the mushy sidewall Firestone Transforce tires, I get oversteer. Didn't have that with the previous tires, which were Michelins. I get oversteer even when I run 10 PSI greater pressure in the rear tires.
01-14-2024, 07:18 PM | #4 |
The Hellwig looks like a nice setup.
My truck didn’t have a sway bar. I bought a kit from POL that had front and rear sway bars. I hope to get the front installed tomorrow. I plan to use it as a fair weather daily. Improved handling will be a plus. I will occasionally pull a 5-6k open trailer and I’m hoping the sway bars will provide stability when towing. |
01-14-2024, 08:44 PM | #5 |
Has anyone used the OER brand bar? Opinions?
70 C/10 SWB 402/TH400/3.73 "The Needy Beast" 200,000 Mile Club Disc Brake Club Owner installed options: Front Sway Bar Power Steering Power Brakes Cigar Lighter Courtesy Lights Deluxe Side Markers Wiper Delay Power windows Power Locks Sniper EFI 2015 Silverado 1500 LS 4.3/6L80/3.23 lowered 2" front & rear |
01-15-2024, 11:25 AM | #6 |
I had the same POL RSBK6372 sway bar on my truck. Under power, when the tires lost traction, my truck would go side to side uncontrollably.
One had to get off the throttle quickly our I may have rolled the truck. It quit when I removed the bar. Let us know how yours work out please. Wondering if it something was amiss on just my truck. Although I did find another C10 owner with the same issue. Other type bars work, specifically those that attach to the differential like stock truck sway-bars. Without further information I consider this one dangerous. |
01-15-2024, 12:47 PM | #7 | |
01-15-2024, 02:30 PM | #8 |
I control oversteer with my hands and my right foot. -klb
67 C10 fleet fuel injected '70 402, 700r4, 3.73 posi 07 335 sport turbo 6sp 94 Trans Am GT LT1 6sp posi -- sold after 22yrs 99 540 sport V8 6sp -- sold 73 240z L24 4sp -- given to friend 68 C10 step 350/350 3.73 open -- sold |
01-15-2024, 07:18 PM | #9 | |
01-15-2024, 09:42 PM | #10 |
My truck had the factory front sway bar when I bought it and I believe they are 7/8ths of an inch. I sourced a factory 1 ton 1 1/4 inch front bar from a scrap 73/87 GMC 3500 and installed it 6/7 years ago with Energy Suspension Poly Bushing. I added the Rear Hellwing 1 1/18th rear bar in 2 years ago and truck was at stock height then and I could feel the difference on tight turns after the rear bar was installed. Then I lowered the truck with a 2 1/2 inch dropped spindle and 3 inch rear spring with shock relocators and adjustable panhard bar. Also did complete front end rebuild with the original springs up front. The shocks are nothing fancy or exotic just Monroe OE Spectrums that I put on the truck around 2015/16 not long after I got it. Tires are 255/60 17 on 17 by 8 rims. My point with all this info is that my truck handles and corners superbly and going onto on ramps at a good clip it stays flat with no lean or feeling of losing it. I think you will love your new front /rear sway bars. Pic is my truck as it sits now with above mentions installed.
01-15-2024, 11:46 PM | #11 | |
01-16-2024, 11:51 AM | #12 | |
68 C10 Longbed
