01-20-2024, 09:54 AM | #1 |
High Beam/Trans Neutral?
Gentlemen- I have spent a week examining my ‘80 C20 350/350 wiring manual with no avail. In short, can anyone assist in identifying this LT GRN wire. Best I can tell it is for either BU lights, Hi beams or trans neutral switch. However, my BU lights are working. The wire originates from a grommet in the firewall behind the instrument panel. It seems unusually long. I am severely colorblind and this has been a challenge…
Thank You, Single Action Army |
01-20-2024, 11:24 AM | #2 |
Re: High Beam/Trans Neutral?
Does your parking brake have a switch on it?
It could be the parking brake indicator light.
________________________________________________________________________________________ ____________________________________________ 84 Chevy K-20 63 Impala (my high school car) http://67-72chevytrucks.com/vboard/s...Crew Cab Build |
01-20-2024, 11:34 AM | #3 |
Thank you Getter. It does, but wiring schematic shows BLK/LT BLU and GRAY to Park SW.
01-20-2024, 12:13 PM | #4 |
Looks like an added wire long ago from a previous owner
01-20-2024, 12:32 PM | #5 |
Green is often used for:
Temp Gauge/Idiot sender AC clutch Possible a PO ran a new wire while trying to figure out why the temp gauge never moved. Often happened if the OEM sender was replaced. |
01-21-2024, 05:05 PM | #6 |
Junior Member
Best thing to do is start tracing it back, where does it go, what does it connect to at other end.
01-21-2024, 06:51 PM | #7 |
Curiosity led to me yanking out the instrument panel. The wire wasn’t factory and probably used for POs CB hookup. Oh well, now I can take a shot at replacing the speedo needle and burned out indicator lamps. Thank you for everyone’s help.
