01-22-2024, 04:29 AM | #1 |
The great electric cooling fan debate…
Had to step away from the computer for a while so apologies for my absence….
As a recap I have a 66 C10 with an LM7. Radiator is a generic ally 25 x 19 for which I have made a shroud to attach 2 fans - sorry can’t remember the size - run from the stock computer so they come on individually. The problem is my shroud looks absolutely horrid. I would like to find a factory style shroud and fan that doesn’t scream - made from the side of a washing machine…. Used the search function and hear about the Tanus fans but they are a little hard to come by in the UK. Therefore are there any Euro style set ups that you have used that fit and keep the engine cool. Looked at the eBay duel fan set ups but would prefer not to spend £200+ Suggestions and recommendations gladly accepted. P.
Woody's Build - http://67-72chevytrucks.com/vboard/s...d.php?t=658621 If it goes wrong, I blame the Internet... |
01-22-2024, 05:39 AM | #2 |
Re: The great electric cooling fan debate…
I'd ask what's the advantage to a complicated system vs the dead simple traditional clutch fan?
01-22-2024, 06:23 AM | #3 |
Good question.
Don't have a clutch fan and the chances of getting a used fan in the Uk are very slim. Looking at buying one new, including the shroud and shipping is more expensive than a good electric set up. An adequate electric set up is even cheaper! P.
01-22-2024, 06:33 AM | #4 |
I'd think that getting the fan would be cheap, and getting a new clutch is easy but a bit more.
Needless to say I have no idea what importing cheap (<$100) things to the UK costs. I'd guess the shroud would be the same so... |
01-22-2024, 02:00 PM | #5 |
Do you really need a shroud?
Pics of yours would help. |
01-22-2024, 02:58 PM | #6 |
I'm using electric fans from a 98 Trans Am on the stock (at least the one that came in the truck) radiator. I've got an LS1 (from the same TA) with an auto trans and air conditioning and in the Florida heat and the AC on the truck doesn't get over 190* The shroud is factory black plastic and blends in nicely.
1965 C-10 1/2 ton shortbed part time daily driver 1980 C-10 1/2 ton shortbed project |
01-24-2024, 12:33 PM | #7 |
Since you are in the UK and you don't have great access to a salvage yard with American cars I would say spending the money on a good E-fan setup is the way to go.
1966 C10 "Mary" 1972 C10 Cheyenne "Betty" https://67-72chevytrucks.com/vboard/...d.php?t=847364 1976 C35 Sierra Grande "Mr. Harvey" 1979 C10 Silverado "The BIG TEN" https://67-72chevytrucks.com/vboard/...d.php?t=841339 1982 C10 Silverado "Lucy" C10 Club Texas -HMIC |
02-01-2024, 03:28 PM | #8 |
if you have to go electric I would go with SPAL
2000 c3500 utility bed 7.4l 5sp manual old body style. Cab and chassis 1964 GMC K10 383cu in/sm465/twin stick np205 1965 Chevy C60 |
02-02-2024, 07:08 AM | #9 |
Thanks for the feedback chaps.
Purchased a pair of duel Spal fans and a shroud for £100 new. Has over 3000cfm capacity so will be perfect for my usage. P.
02-02-2024, 03:41 PM | #10 |
Awesome! Let us know how it goes, if you think of it! I am hoping to be addressing this issue on my build this summer some time...
Travis' Tribute Truck - 65 C10 Frame Up Restoration http://67-72chevytrucks.com/vboard/s...d.php?t=495073 |
02-05-2024, 08:51 AM | #11 |
This is the fan system I have on my '71 C/10.. No computerized engine management system. Just a rambunctious carbureted 454 BBC. One fan comes on with a signal from the ignition switch.. The other fan is activated by a coolant temp sensor, set to come on at 195 Fahrenheit.. The second fan very seldom comes on. I live in East Texas where summer time temperatures run consistent triple digits.. They're not cheap, not very pretty, but they WORK!!!
https://www.summitracing.com/parts/der-16826 |
