01-22-2024, 11:12 PM | #1 |
Medium Olive Spray Paint
Years ago someone posted of a spray paint that closely match the Medium Olive, which may have been in a thread under the "Projects & Builds" forum but for the life of me I cannot find it. Anyone have a link to who might have OEM type colors in a spray can? I'm wanting to touch up my firewall while my engine is out, appreciate any help.
01-22-2024, 11:28 PM | #2 |
Re: Medium Olive Spray Paint
I got some in a rattle can for touch-ups on this old 71 from these guys - just gotta select year-make-truck-code 504. (obviously not a professional paint job, was just trying to get it drivable/presentable)
01-23-2024, 08:16 AM | #3 |
I can't imagine any off the shelf paint ever matching medium olive poly. That is the hardest mix to get a consistent mix using the factory code. I see it anywhere from a silver tinted green to candy apple green. Getting a spray can mixed at an autobody supply house is your best chance of getting it close
01-23-2024, 01:18 PM | #4 |
https://www.automotivetouchup.com/spray_paint.asp is what I used for interior touchup. I repainted my ashtray and two aircon vent covers on either side of the dash. This was a near-perfect match of TWO STAGE non-metallic Hawaiian blue 510 paint, requiring a top coat of clear.
'72 C10 Cheyenne SWB North Carolina truck for 50 years, 72k original miles, Medium/Hawaiian Blue, 3 owners - one for 40 years, garaged kept, original: sheetmetal, undercarriage, moldings, glass * * * New - engine rebuild at 65k in 2015, one repaint in 2010, new front bumper, houndstooth seat, carpet, 8 inch rally wheels on 275-60R-15, LED lighting. - Semper Paratus! |
01-24-2024, 09:06 AM | #5 |
Yeah, I had the same color mixed at the body supply place for the tool & stowage door on the '71 K/20 Highlander I had. It matched quite well. But matching metallic is a totally different game. And off the shelf color for some other vehicle? Good luck with that.
Here is a peak at the '70 Custom/10 I had with the bed repainted (po) by Maaco. The whole truck had been painted over previously
01-24-2024, 10:28 AM | #6 |
Thanks for the suggestions. I ordered some from Jocko's recommendation, I'll report back on how it matches. This is far from a show truck and will be confined to just the firewall, not as if it was being compared to a body panel in direct sunlight, so if it's remotely close it should work great.
01-24-2024, 10:49 PM | #7 |
Areas not exposed to the sun for decades (like your firewall) should be a pretty close match. Good luck and would love to see some pics when you're done.
01-25-2024, 08:28 AM | #8 |
That factory pack mix will be correct and, as Jocko said, on the unexposed to sunlight firewall even better. That's in advance for following up. A thing we need to see more of here.
01-27-2024, 12:49 PM | #9 |
70+ ( Old Skool Club )
Had a spray bomb mixed for the gas fill cover box when relocated my gas tank. Its close I guess.
1972 C10 Custom/Deluxe 613 Highlander 406/700R4 1999 White Tahoe LS 4x2 with Z56 Police Package 1992 K1500 GMC Suburban Members I have personally met: MusicMan70 - HeavyD - ChewyChevy67 - StingRay -71SWB4x4 - 67 Burb - DeadheadNM - too much stuff - bc65 - das601 " Circumsatances Do Not Change Responsibility " " The Sky is not the Limit, Your Mind is." Marilyn Monroe .. RIP Charlie Watts 1941 - 2021 |
01-29-2024, 02:09 AM | #10 | |
I just went to the link you have in your post. For 1970, they don’t have 504 Medium Olive listed as an option. However, I checked both 69 and 71, and they list 504, though both years have the 504 code listed by different names. Last edited by custom10nut; 01-29-2024 at 02:14 AM. |
01-29-2024, 07:25 AM | #11 |
Can't speak for their website, but 504 was available 69-72 and marketed under various names (between the brochures and SPID), such as willow green, yellow-green, and medium olive - the latter being the most common SPID nomenclature.
01-29-2024, 04:07 PM | #12 |
I saw that too. 504 is the same under different names, so unless they've somehow magically calculated the fade year-over-year they ought to be the same
1970 C10 Custom longbed 350/350 |
01-30-2024, 09:01 AM | #13 |
someone posted awhile back, Kia has a color on their 2019 line thats a very close match , just a suggestion
A Little Better Every Day Cancer Survivor, most dont know what they have until its gone, appreciate everything |
01-30-2024, 01:15 PM | #14 | |
Greater love hath no man than to lay down his life for a friend. Members i Have met Earl Slick68 1969 Stepside Build thread http://67-72chevytrucks.com/vboard/s...=1#post4253546 Chevy Trucks the longest lasting most dependable trucks on the road |
01-30-2024, 01:16 PM | #15 | |
Edit* Looks like this color isn't available for any of the off the shelf DupliColor type products, it's a custom mix. At that point, might as well get the GM 504. Last edited by Toro; 01-30-2024 at 01:25 PM. |
01-30-2024, 01:43 PM | #16 |
I have tryed to get GM504 formula for "modern paints" without any luck.
Paint shops dont regonice "GM504" at all. |
01-30-2024, 04:32 PM | #17 |
I had these bookmarked. You might have better luck with the cross-referenced paint codes
https://paintref.com/cgi-bin/paintde...Medium%20Olive https://paintref.com/cgi-bin/colorco...0Olive&rows=50 There are many posts to read about what a PITA it can be to get a match, even with a custom scan on the glovebox lid, and apparently even more so in 2-stage
01-31-2024, 12:11 PM | #18 | |
