01-29-2024, 02:22 PM | #1 |
Exhaust band clamps, general (fitment) question
Question on band clamps, specifically SUMMIT brand if anyone has used them. Do they normally go on easy?
I've never used them before, and wasn't expecting to 'fight' with them to get over the pipe ; ) Since there doesn't appear to be dropdown pipes available for a 396 with factory manifolds (and no local shop with a mandrel bender) I'm starting to gather exhaust parts for my truck (68 C20 Utility, 396 w/ factory manifolds). I'm planning to go with 2.5" system, I placed an order with Summit for a pair of FLowMaster FlowFX mufflers, some 2.5" (lap joint) band clamps, etc. Link to band clamps: https://www.summitracing.com/parts/SUM-681250 The parts arrived and it was nearly impossible to get the band clamps on the muffler. I had the nuts backed out to all but 2-3 threads and still could not get the clamps in place. Eventually by removing the bolts, spreading the band around the muffler/pipe, 'clamping' it with large pliers, I was able to get it. This may be normal, I don't know, but hoping others can shed some light. Thanks, Kevin Apparently I'm not the first person to run into this...
'68 C20 Utility 396 4sp (BuildThread: http://67-72chevytrucks.com/vboard/s...d.php?t=806904 ) '68 C10 50th |
01-29-2024, 03:10 PM | #2 |
Re: Exhaust band clamps, general (fitment) question
That's pretty normal. I've got them on my '85 at the headers and that's how I have to get them on, even after 35k miles on them
1985 GMC Sierra Classic Chopped down wrongbed Cammed LH6 5.3/T56/3.90 Walker Tuned 5/8 drop US Mags |
01-29-2024, 03:38 PM | #3 |
Not from Summit I got the 3” x pipe exhaust for my Chevelle from Pypes. Same issue I just went and bought longer SS bolts . Been 10 years no leaks
01-29-2024, 03:51 PM | #4 |
At the body shop.
Clamps are for slip fit junctions
" That didnt make it any newer " " Dont antique the equipment " |
01-29-2024, 05:25 PM | #5 |
They make the clamps shown above for slip fit and also non-stepped type for butt connections.
I used to use the wide type on my hot rods for years but now I use the 1" wide clamps like they use on late model vehicles. You just need to make slots in the exhaust or muffler tube so the clamp can clamp down. |
01-29-2024, 05:50 PM | #6 |
Thanks for the replies guys...
The more I ask around (and from your responses) it does appear this is normal.... editing that "normal" may not be the correct word, but 'expected at times due to variations with brands/pipes' ...might be more accurate ; ) Thanks again, Kevin
'68 C20 Utility 396 4sp (BuildThread: http://67-72chevytrucks.com/vboard/s...d.php?t=806904 ) '68 C10 50th Last edited by KevinK7; 01-30-2024 at 07:58 AM. |
01-29-2024, 07:13 PM | #7 |
I used the same ones on my 2 1/2" FX mufflers to OTA pipe, no problems. Slip fit which they call lap.
01-29-2024, 11:48 PM | #8 |
We know that the muffler pipe ID is designed to slide on a 2.5" exhaust pipe. But the OD depends on pipe wall thickness. Could be that your mufflers' 2.658" OD is a bit on the large size. FWIW, I've bought them from a few different vendors, but haven't had the problem you've described.
Mike 1969 C10 LWB -- owned for 34 years. 350/TH350, 3.08 posi, 1st Gen Vintage Air, AAW wiring harness, 5-lug conversion, 1985 spindles and brakes. 1982 C10 SWB -- sold 1981 C10 Silverado LWB -- sold, but wish I still had it! 1969 C10 (not the current one) that I bought in the early 1980s. Paid $1200; sold for $1500 a few years later. Just a hint at the appreciation that was coming. Retired as a factory automation products salesman. Worked part-time over the years for an engine builder and a classic car repair shop. Member here for 23 years! This is the very first car/truck Internet forum I joined. I still used a dial-up modem back then! |
01-30-2024, 07:55 AM | #9 |
Mike, Thanks for your reply. A buddy of mine locally stopped over and (as you) said he definitely didn't have this issue. On the other hand, he noted, "well, at least they won't slip..."
I was on the fence of returning these Summit ones and trying another brand, but with the thought in mind that they won't allow the pipes to slip/turn, I'm going to go with them. I may not get into this for another month or so, but I will update when I do. Thanks again, Kevin
01-30-2024, 10:46 AM | #10 |
Born Psycho
exhaust tubing is always measured O.D. the muffler neck is measured I.D. that way the pipe will slip inside the neck of the muffler. that's how it's been as long as i've been working in a muffler shop(39 years and counting)
jerry moss 72 cheyenne super K20- tilt,tach,vacuum,speedwarning,buckets,shoulder belts,am/fm,tow hooks,bumper guards,toolbox,aux. fuel tank,posi front and rear,plus other goodies!!! SOLD 69 suburban K20-tilt,tach,vacuum,speedwarning,buckets,shoulder belts,am/fm,4 inch all spring lift,4 speed, 14 bolt full floater, dana 44 HD,warn winch,posi front and rear,tow hooks,plus other goodies. 73/80 chevy/gmc K20 SB400,turbo 400,205,tilt,a-c,gas hog. 77 K/5 cheyenne blazer-daily driver/beater. SON HAS IT NOW BRENTWOOD,CALIFORNIA |
01-30-2024, 02:37 PM | #11 | |
The muffler pipe is meant to slide over a 2.5" OD pipe. There may be some kind of standard for its OD, but its ID is the critical dimension, whereas OD is a function of wall thickness. In this case that's .079". I'd bet some muffler pipes have thinner wall thickness (.0625"?), which would have made for easier clamp installation. To the OP: I have leaned to torque the heck out of the clamp bolts, or you will see some condensation drip out. Also, those clamps will be easier to reinstall once they take the shape of the pipes.
01-30-2024, 06:22 PM | #12 | |
Born Psycho
01-31-2024, 12:58 PM | #13 |
Yeah, I can see how that happened! When writing both my posts above, I had to double check my OD and ID numbers for exhaust pipe sections and mufflers.
