02-03-2024, 08:05 PM | #1 |
Reinstalling side molding
When we took the box off the truck last fall, the upper side molding popped off. Is it possible to reinstall it with the old clips? What’s the trick?
02-03-2024, 09:21 PM | #2 | |
The Older Generation
Re: Reinstalling side molding
Probably not with those clips. My Dually had the stick on plastic clips that were still on the bed, so I just started one end of the trim on the first clip and slid them on. The metal clips should pop out of the holes (except for the two end ones) and then you can re-install them into the trim again and put it all on at once.. Put some masking tape around each clip to protect the paint, and spray a little penetrating oil on each clip where it goes into the hole before prying them out. I use a door panel clip removal tool for prying them out.....
02-03-2024, 09:36 PM | #3 | |
02-03-2024, 10:00 PM | #4 |
Think I found some at LMC
02-03-2024, 10:03 PM | #5 |
70+ ( Old Skool Club )
The best place place to get the proper clips is Mar K. I just got some from them for my truck. They don't show as an individual pieces for sale but if u call them they will sell them separately, although u may find them pricey..
1972 C10 Custom/Deluxe 613 Highlander 406/700R4 1999 White Tahoe LS 4x2 with Z56 Police Package 1992 K1500 GMC Suburban Members I have personally met: MusicMan70 - HeavyD - ChewyChevy67 - StingRay -71SWB4x4 - 67 Burb - DeadheadNM - too much stuff - bc65 - das601 " Circumsatances Do Not Change Responsibility " " The Sky is not the Limit, Your Mind is." Marilyn Monroe .. RIP Charlie Watts 1941 - 2021 |
02-04-2024, 10:52 AM | #6 |
Thanks. I checked out Mar k site, they make a lot of nice stuff.
