![]() Join Date: Jan 2013
Location: 3,018 feet above the SoCal/Mojave Desert region.
Help with mounting '72 bumper lights.
Mine are mounted all funky from the previous owner. The two assemblies have the notches on the top right so the left lens don't fit. Only three screws are the same. Then the previous owner used washers to mount also. This is all the mounting hardware used. Somethings wrong.
The lenses have six holes. Four to mounts the lens. What about the top two? Thanks again all. |
Re: Help with mounting '72 bumper lights.
Not sure how much help I'll be. There is a right and left for both the lens and the assembly. The "3" screws are the right ones, and there are 4 per lens. PO probably stripped out the holes and used what ever he had on hand. Good luck
1972 C10 SWB, Air, PS, PB, 350/350THM. Second owner. 1965 Corvette roadster, 44K miles, 327/365 SHP, 4 speed, side exhaust, knockoffs, teak, second owner (bought in 1970), Have ALL numbers matching components. My frame off restoration thread: http://67-72chevytrucks.com/vboard/s...d.php?t=556703 |
![]() Join Date: Feb 2009
The park lamp housing’s top positions onto the top of the front bumper’s ledge. Each housing mounts to the bumper using two #2 phillips pan head screws with spin star washers, inserted from below. The screw threads are #10-24 x 3/8.
• Each housing’s bottom takes a rubber bumper inserted from the front, for contacting the front bumper’s inside. Replacement bumpers sold through the internet are of poor design, and don’t work anyway. Use part #4081765. • Each harness plugs into a respective boot connector on the forward lamps harness, inserted through the core support. • Each park lamps lens mounts with a foam rubber gasket, and four special stainless #1 phillips pan head screws. The screw threads are #8, and the tips are pointed. The screws are 1.7/16” long under head, of which 1” is a thick shaft, reference images. • The park light housings and lenses are stamped GUIDE, 8T, SAE, IP, 71. The housings and lenses are also stamped LH or RH respectively. In other terms, those lens screws are right. But your mounting screws are wrong. Look online for the right screws.
Tony 71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assm. guide "kit" for restoring the truck from ground up. With assys, the guide accts for 1000s details, OEM identifications & part numbers, written in short order. 700+ images of assm., illust., charts, and points of interest. Much of the info. applies to all 67-72 GM trucks, and to a lessor degree all 67-72 GM vehicles. My build thread, and more on the guide https://67-72chevytrucks.com/vboard/...d.php?t=730025 Last edited by 71CHEVYSHORTBED402; 02-06-2024 at 06:13 PM. |
![]() Join Date: Jan 2001
What he said, but...
If you have a reproduction bumper, getting both mounting screws to line up can be a challenge. I have yet to see a reproduction bumper that has the holes in the right locations.
I have sworn upon the altar of God, eternal hostility against every form of tyranny over the mind of man. - Thomas Jefferson |
I just happened to have an image, thought about this thread
Tony 71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assm. guide "kit" for restoring the truck from ground up. With assys, the guide accts for 1000s details, OEM identifications & part numbers, written in short order. 700+ images of assm., illust., charts, and points of interest. Much of the info. applies to all 67-72 GM trucks, and to a lessor degree all 67-72 GM vehicles. My build thread, and more on the guide https://67-72chevytrucks.com/vboard/...d.php?t=730025 |
