02-06-2024, 02:27 PM | #1 |
Carpe manana
WTB Good HEI core
Looking for a solid HEI core to rebuild and use. Doesn't have to have a cap, rotor, or module. Will buy and/or swap for other parts. Thanks.
1972 K5 CST Highlander Blazer: http://67-72chevytrucks.com/vboard/s...d.php?t=708547 1972 K20 Cheyenne Super: http://67-72chevytrucks.com/vboard/s...d.php?t=528308 Members met: ORANGBLAZ, 2003 silverado, MikeCofield, BB72CHEVKT, Duncan&Son, Sameyrasmea72, THENEWMEXICAN, HotRod C/10, brianthelion02, Sport/Truck, ryanroo, michael bustamante, Dirt's72, Already Gone, WestButteTruck, 57taskforce, Moreyel, painterljp, AASmedic, SoCoC10, Lumaestas, carbuff382, Chevyland |
02-06-2024, 06:31 PM | #2 |
Re: WTB Good HEI core
I've good a few Mallory HEI distributors / 1 complete / 1 core if interested.
PM a contact # and I'll shoot u a few pix. marko |
02-06-2024, 09:05 PM | #3 |
Carpe manana
Marko thanks. I’m aiming for a GM Delco example but I appreciate the offer.
02-07-2024, 12:32 AM | #4 | |
Chevy Freak
Thank you Nick
67 K20 5.9 p pump cummins (in progress) 68 Camaro 454BBC 86 Camaro 5.3LS turbo |
02-07-2024, 08:34 AM | #5 | |
Chevy Freak
Let me know if this would work for you. Thanks Nick
02-07-2024, 12:53 PM | #6 |
Carpe manana
Thanks Nick that looks promising. Are you able to read the part number and date code on the body for me? Something like this pick but from a points distributor:
02-07-2024, 12:54 PM | #7 |
Chevy Freak
Sure I can take a look
02-07-2024, 04:40 PM | #8 |
Chevy Freak
Can you tell me where the part number is? I can’t find one. It’s definitely a factory gm hei I just don’t see a part number
02-07-2024, 05:13 PM | #9 | |
Carpe manana
EDIT - added HEI example
02-07-2024, 08:20 PM | #10 |
If you are disassembling any old HEI, a new old stock Delco pickup coil, or pole piece as GM calls them is necessary. Those small wires work harden and break internally due to the back and forth motion caused by the vacuum advance, causing intermittent performance issues or outright failure. Also use a NOS Delco module and use the special heat dissipating grease on the bottom of the module. 1975 Chevy 350 pole piece is 1875981 D1907. The module is 1875990.
1970 K/5 Blazer CST 4WD, Bronze, 93k ACT. miles, 350, 4 speed, positraction, 16.5" x 8.25" wheel option, tilt, tach, vacuum, AM/FM, manual throttle...Dad ordered and purchased new 4/70. Currently frame off restoration in progress... 1972 Cheyenne Super 20 2WD, DK Blue/White, 90K ACT. miles, 402, TH400, 4.10 open, tilt, tach, vacuum, A/C, AM/FM, manual throttle.. A mostly original paint never rusted Texas survivor... 2017 Sierra 1500 SLT 4WD, Black, 41k miles, 5.3, 6L80E, 3.42 LS, 20" polished wheels, everything but moonroof and 6.2... 2019 Canyon SLT 4WD, White, 60k miles, 3.6, 8L45, 3.23 LS, 18" wheels |
02-07-2024, 08:30 PM | #11 | |
Chevy Freak
1112977 5g24
02-07-2024, 09:26 PM | #12 |
Carpe manana
That works. Lmk what you need to get for it and thanks again.
02-07-2024, 09:29 PM | #13 | |
Carpe manana
02-07-2024, 10:27 PM | #14 |
Chevy Freak
No problem- $40 shipped?
02-07-2024, 10:32 PM | #15 |
Carpe manana
Sure. Lmk how to square up. I’ll send a PM. Thanks again.
