02-14-2024, 08:07 PM | #1 |
To Sniper or not to Sniper...?
I'm seriously thinking of converting my truck from the ol' Rochester carb to Sniper EFI system. Reasons include; not dealing with mixture screws, idle speed, hard cold starting, seemingly dealing with the unknown witchcraft of carburetorisms.
My weakness for sure I admit it, carbs have never been my thing, other repairs / rebuilds no problem. Question is, those of you that have made this switch, any recommendations, any feedback? Is it worth the cost? Truck is 1972 GMC K20, pic attached for no real reason....other than I love the thing!
“The doctor said I wouldn’t get so many nose bleeds if I kept my finger outta there,” - Ralph Wiggum |
02-15-2024, 01:06 PM | #2 |
Re: To Sniper or not to Sniper...?
Interesting post, I will be sure to follow. I have often wondered the same.
02-15-2024, 01:14 PM | #3 |
Also hitching a ride, as I have no experience with them either.
1987 V20 farm-hand rescue 1998 C2500 lot-rot rescue |
02-15-2024, 01:32 PM | #4 |
I am assuming this truck has a SBC, not a big block. If using a SBC, I would try replacing the Rochester with an Edelbrock 1406. My research and discussions with many owners has found that the 1406 is easy to initially set up and is rock solid after it is set. The big bonus is that it is about $800 cheaper than a Sniper set-up.
I am not trying to dissuade you from installing the Sniper, just pointing out an alternative. If you go with the Sniper, I would love to follow your progress and how you install it. Cheers! |
02-15-2024, 02:00 PM | #5 |
Thanks 68 C10, I had also considered that option as I did that very swap on my last 1964 C10 and the Edelbrock did work flawlessly, so that's still an option.
02-15-2024, 02:01 PM | #6 |
Oh and yes it is a SBC 350 with just over 100k miles on it. Will be doing a rebuild on it soon.
02-15-2024, 02:46 PM | #7 |
Location: Herculaneum MO (20 minutes south of St. Louis
I've said it before and I'll say it again. If your carbuerated engine is hard starting cold it's not tuned correctly. A $30 carb rebuild kit & learning to properly tune an engine is still the best option. Way cheaper even than the edelbrock mentioned above. Also that Quadrajet is a much better carb than an edelbrock any day.
67 C10 283 T5 swapped longbed fleetside = wife's daily driver 67 C20 292 (originally a 250)4speed longbed fleetside w/original wooden bed=my project truck 67 C10 283+.060 (so a 292 as well)T5 swapped longbed fleetside=my DD 72 C1500 Sierra Grande 350 TH350 longbed fleetside=wife's fair weather truck Can you tell we are fans of longbed fleetsides & 67s Chris Last edited by 67 twins; 02-15-2024 at 02:53 PM. |
02-15-2024, 02:52 PM | #8 |
So you don't like carbs but you'd consider removing the factory carb that has been optimized for your engine by GM and in its place put something that is going to require more fiddling with to optimize for your set up. Why?
67 C10 283 T5 swapped longbed fleetside = wife's daily driver 67 C20 292 (originally a 250)4speed longbed fleetside w/original wooden bed=my project truck 67 C10 283+.060 (so a 292 as well)T5 swapped longbed fleetside=my DD 72 C1500 Sierra Grande 350 TH350 longbed fleetside=wife's fair weather truck Can you tell we are fans of longbed fleetsides & 67s Chris |
02-15-2024, 03:25 PM | #9 |
I've put 10k+ miles over 7 years on an MSD Atomic I EFI. Only real issue was a failed IAC valve. Easy replacement. Holley now owns MSD and is marketing the MSD Atomic II, which is essentially a clone of the sniper so I would not recommend that. The original MSD product, the Atomic I (original) is still being sold by MSD/Holley: https://www.holley.com/products/fuel...tomic_efi_tbi/ My install was the full kit with return line fuel setup. Still running everything original except for the IAC (TBI, pump, regulator, injectors and lines). Hth, -klb
67 C10 fleet fuel injected '70 402, 700r4, 3.73 posi 07 335 sport turbo 6sp 94 Trans Am GT LT1 6sp posi -- sold after 22yrs 99 540 sport V8 6sp -- sold 73 240z L24 4sp -- given to friend 68 C10 step 350/350 3.73 open -- sold |
02-15-2024, 03:49 PM | #10 | |
02-15-2024, 04:18 PM | #11 |
I haven't walked an inch in those shoes....but
I haven't seen anyone who went to a Sniper say they regret it. They are damned expensive so "worth it" depends There is a bolt on tool called the Carb Cheater for about $350 that can give you the feedback you need to tune your carb. It's an interesting option for those of us who didn't grow up fiddling with carbs. About 2x the price of an O2 sensor alone with a phone interface you can watch in real time driving. Thunderhead289 on Youtube makes them Or.. if you're going to rebuild anyway, you could send the Q-jet off to Cliff Ruggles or one of the other gurus while the motor is off. Once it's set up for your application, you're unlikely to need to touch it much. It' also common to have a transplanted Qjet that doesn't have the right parts to match your motor, the things have many variations and they're application specific
1970 C10 Custom longbed 350/350 |
02-15-2024, 10:37 PM | #12 |
Born Psycho
we have installed sniper's on several customers vehicles where i work and as of yet never had any comebacks or complaints. they were easy to dial in and fire up with the touch of the key, idle great and give fast throttle response when you hit the skinny pedal. i'm considering installing one on my 69 suburban when/if i ever get around to finishing it. just my 2 cents worth.
jerry moss 72 cheyenne super K20- tilt,tach,vacuum,speedwarning,buckets,shoulder belts,am/fm,tow hooks,bumper guards,toolbox,aux. fuel tank,posi front and rear,plus other goodies!!! SOLD 69 suburban K20-tilt,tach,vacuum,speedwarning,buckets,shoulder belts,am/fm,4 inch all spring lift,4 speed, 14 bolt full floater, dana 44 HD,warn winch,posi front and rear,tow hooks,plus other goodies. 73/80 chevy/gmc K20 SB400,turbo 400,205,tilt,a-c,gas hog. 77 K/5 cheyenne blazer-daily driver/beater. SON HAS IT NOW BRENTWOOD,CALIFORNIA |
02-15-2024, 11:02 PM | #13 | |
02-15-2024, 11:30 PM | #14 |
I have a Sniper on a 69 Camaro and seems to work great so far, very responsive.
02-16-2024, 08:25 AM | #15 |
Chevy Freak
Ill step up- I have one on my 68 camaro. 454 big block , iron 101 heads, flat tops 9.2:1 compression. Mild street motor. It was the best upgrade I ever did, I put a stealth kit on it with an in tank pump. I run it without timing control .Is it perfect? No. But it starts every time and runs fairly smooth. I have a buddy with over 20k on his car he daily drives in the summer with no issues. I wouldn't say this is efi in the same sense as a new car, it still has that " Carburetor" type of feel. Hard to explain without experiencing it.
I will note that a terminator kit makes it run like a new car and makes it very reliable at the sacrifice of the " ugliness" of the injectors in the intake manifold. Any questions feel free to ask Nick
67 K20 5.9 p pump cummins (in progress) 68 Camaro 454BBC 86 Camaro 5.3LS turbo |
02-16-2024, 08:46 AM | #16 |
I don't have a Sniper but I have 2 Tuned-Ports myself and have done several TPI conversions for others. With todays fuels, carburetors are a losing battle. EFI allows for so many benefits while still keeping the original look and drivetrain. I have owned my '83 K20 for over 30 years. When I got it with 34K miles it got around 14 mpg city and 18 highway with the stock 4-bolt 350, Quadrajet, and 700R4 with 3.42 gears. I ran it that way until 2004 it had 150K miles and a cam lobe went down. Pulled it out and replaced it with a bone stock '91 Corvette 350 TPI engine (aluminum heads). Mileage went to 17 city and 20ish highway. It starts instantly regardless of weather conditions. The increase in power is noticeable. Originally if you were pulling a trailer uphill you had to get on the gas to not lose speed. Now you just barely give it a little more and it moves right along. The TBI 350s that GM did are not power houses but they are very reliable. So I say yes, go for it!
'83 K20-TPI '73 C10 '79 C10-ex-diesel(SOLD) '07 Tahoe(Son driving) '14 Suburban-DD '71 C10-current project |
02-16-2024, 09:15 AM | #17 |
Well it was a lot of work / time to install. Had to splice and lengthen some of the harnesses so it would not look like a snake pit. Needed a few extra fittings to route the fuel lines. Installing the O2 sensor was a battle in itself. Had to make a bracket to mount the fuel pump. Still need to add some isolators cause that pump is loud.
Could one person install the system on a Saturday, yes. It took me longer cause I wanted to make it a clean install. The install instructions are easy to follow and the start-up wizard walks you thru the initial set-up. Had my doubts, but it fired up right way. No pumping the gas, no half throttle while waiting for it to warm up to idle, basically none of the start-up fun from a carb set-up. Also no more leaky gaskets drying out from the desert heat. I had my carb pretty well tuned or so I thought. This system woke my engine up. Was it worth it, hell yes. Could I have done a cheaper set-up to achieve the same results, sure. The only problem I have had is my O2 sensor crapped out on me after a year, which then lead to crappy performance. It was easy to change and now she runs like a beast. |
02-16-2024, 09:29 AM | #18 | |
Chevy Freak
02-16-2024, 10:09 AM | #19 |
Burnsy01, thanks. The picture does not show the best angle, but the O2 sensor is on the pipe section that is aligned with the manifold flange, which puts it at about a 45 degree angle. I think the failure was mainly related to the truck sitting for awhile.
02-17-2024, 10:09 AM | #20 |
I didn't use the Sniper, but I did go with FiTech System. The best decision I ever did. Mine was hard to start after sitting in the garage for a while. My tank was relocated to the rear. After installing this system no cold start problems. It was fairly simple to install.
1972 Chevy LWB Roadster 1999 Chevy Silverado 2wd 2015 Chevy High Country 4x4 Crew Cab |
02-17-2024, 02:30 PM | #21 |
Mike 1969 C10 LWB -- owned for 34 years. 350/TH350, 3.08 posi, 1st Gen Vintage Air, AAW wiring harness, 5-lug conversion, 1985 spindles and brakes. 1982 C10 SWB -- sold 1981 C10 Silverado LWB -- sold, but wish I still had it! 1969 C10 (not the current one) that I bought in the early 1980s. Paid $1200; sold for $1500 a few years later. Just a hint at the appreciation that was coming. Retired as a factory automation products salesman. Worked part-time over the years for an engine builder and a classic car repair shop. Member here for 23 years! This is the very first car/truck Internet forum I joined. I still used a dial-up modem back then! |
02-17-2024, 02:34 PM | #22 | |
I'll be anxiously awaiting more snide remarks from member 67 twins.
Mike 1969 C10 LWB -- owned for 34 years. 350/TH350, 3.08 posi, 1st Gen Vintage Air, AAW wiring harness, 5-lug conversion, 1985 spindles and brakes. 1982 C10 SWB -- sold 1981 C10 Silverado LWB -- sold, but wish I still had it! 1969 C10 (not the current one) that I bought in the early 1980s. Paid $1200; sold for $1500 a few years later. Just a hint at the appreciation that was coming. Retired as a factory automation products salesman. Worked part-time over the years for an engine builder and a classic car repair shop. Member here for 23 years! This is the very first car/truck Internet forum I joined. I still used a dial-up modem back then! Last edited by MikeB; 02-17-2024 at 02:46 PM. |
02-17-2024, 02:49 PM | #23 |
I never make snide remarks, only well thought out comments.
02-17-2024, 05:23 PM | #24 |
Just ran across this site. Looks like they have a few kits all 20% off this weekend. Never used them so can't say what their service is like. Might save you $300 or so.
https://www.topflightautomotive.com/ |
02-17-2024, 11:17 PM | #25 |
Kootenay, you sound undecided in your first post (EFI vs carb). If it's just the frustration of tuning the carb, have you considered replacing your carb for a professionally rebuilt q-jet? Or perhaps sending yours out for a rebuild? Yes, it's true you can do it yourself, as others have posted, but I also understand not wanting to mess with them - but I think you'd come out $ ahead to pay someone to rebuild it - and set it up, so that there's nothing less to mess with other than bolting it on. Although I understand the draw to the newer technology and its obvious benefits (efficiency, self-learning, less tuning, etc), I still prefer an original q-jet on these old trucks - have had a few edelbrocks, but definitely prefer a q-jet. It's just my own personal preference, everyone's different.
Here are a few resources (if you decide to stay carbureted ) https://cliffshighperformance.com/ (preferred. Cliff rebuilds baseplates, not certain if he still rebuilds carbs for folks, but he is the Rochester whisperer) https://smicarburetor.com/ (EDIT: q-jet rebuild sales/service https://smicarburetor.com/service-mo...uadrajet-symc/) https://nationalcarburetors.com/ (EDIT: and specific to 72 GM trucks: https://nationalcarburetors.com/chev...arburetor_1972) Last edited by jocko; 02-17-2024 at 11:25 PM. |
