Old 02-18-2024, 04:39 PM   #1
MikeB
MikeB's Avatar
tire sizes
My 69 C10 currently has 255-70X15 tires front and back on 8" wheels. I've been looking at ways to reduce highway revs a little w/o going to an OD trans. Axle ratio is 3.08, so there's nowhere to go from there.
What do you guys think about 32x10.5x15 tires in the rear? Looks like they will reduce RPM by 240 RPM at 70mph. I'd probably put the same brand/model tires on the front in size 235-75x15.
How would the truck look? I can handle criticism fairly well.
BTW, the engine is a mild 350 with TH350 trans. I am not worried about "getting off the line" in a hurry.
Mike
1969 C10 LWB -- owned for 34 years. 350/TH350, 3.08 posi, 1st Gen Vintage Air, AAW wiring harness, 5-lug conversion, 1985 spindles and brakes.
1982 C10 SWB -- sold
1981 C10 Silverado LWB -- sold, but wish I still had it!
1969 C10 (not the current one) that I bought in the early 1980s. Paid $1200; sold for $1500 a few years later. Just a hint at the appreciation that was coming.
Retired as a factory automation products salesman.
Worked part-time over the years for an engine builder and a classic car repair shop.
Member here for 23 years! This is the very first car/truck Internet forum I joined. I still used a dial-up modem back then!
MikeB is offline   Reply With Quote
Old 02-18-2024, 11:55 PM   #2
novaX522
Re: tire sizes
I just did 31x10.50-15s with a a 1” drop front and 3” drop in rear. If yours isn’t dropped, you should be able to fit it.
novaX522 is offline   Reply With Quote
Old 02-19-2024, 11:48 AM   #3
MikeB
MikeB's Avatar
Re: tire sizes
That's about how much mine is dropped. Thanks for the picture. Got any from an angle, like left front, right rear, etc?
Here's how mine looks now with 255-70x15s.
Mike
Old 02-19-2024, 12:56 PM   #4
geezer#99
geezer#99's Avatar
Re: tire sizes
Easiest and cheapest way is to reduce speed to 64 mph. A 6mph drop equals about 240 rpm.
geezer#99 is online now   Reply With Quote
Old 02-19-2024, 01:26 PM   #5
MikeB
MikeB's Avatar
Re: tire sizes
Problem solved! But then they'll call me "Slow Lane Charlie".
Back in the days of 55-65 mph speed limits, I put several thousand freeway miles on the truck. Heck, now a 70 mph speed limit essentially means 75-80 here in Texas, which the truck simply doesn't like.
Funny, because I remember driving freeways in cars with 27" tires and 3.7x gears back in the day, and we never even thought about needing another gear. Had a friend with 4.11 gears in a 60s Corvette who used to drive a 500 mile round trip twice a month to see his girlfriend. He said the same thing -- he doesn't remember the high revs being an issue.
Heck, I'll probably just end up with an OD trans, but then my 3.08 gears will be a little tall. Damned if I do...
Mike
Old 02-19-2024, 03:20 PM   #6
novaX522
Re: tire sizes
Here’s pictures before I added a 1” drop block in the rear, so it just has 2” drop coil in rear and 1” in front.
Old 02-19-2024, 04:04 PM   #7
68Gold/white
Re: tire sizes
What's that white stuff on the ground???
68Gold/white is offline   Reply With Quote
Old 02-19-2024, 04:19 PM   #8
HO455
Post Whore
HO455's Avatar
Re: tire sizes
Why not pick up a pair of cheap used tires off Craigslist or a wrecking yard and give them a test then if your not happy you're not out any serious cash.
RIP Bob Parks.
Old 02-19-2024, 06:42 PM   #9
MikeB
MikeB's Avatar
Re: tire sizes
Thanks!
Mike
