Old 02-18-2024, 08:40 PM   #1
forestb
forestb's Avatar
Another LED bulb question
Whatever led bulb I try to install on the front turn signals it never works. If I turn on the blinker it just stays lit and the rears (led) don’t blink at all. I have the special blinker switch. It works fine if I have the leds in the rear and normal bulb up front. I have cleaned off all the metal to metal connections so I am pretty sure it is well grounded. Is there another way to ground it that I am missing? It’s a 62 c10 pickup.
forestb is offline   Reply With Quote
Old 02-18-2024, 10:11 PM   #2
dmjlambert
dmjlambert's Avatar
Re: Another LED bulb question
You can get a no-load flasher module to replace the regular one, or install load resistors. Google or look on Amazon.com for LED load resistors. Or what I do is use regular bulbs in the front and LED in back. The advantage of LED bulbs is instant-on for your brake lights giving you more safety, there really isn't any advantage for using in any other position on the truck. If you use a paperclip to plug and unplug into the flasher module socket and with a helper notice it works OK, then that would determine the flasher module is not suitable. Wear leather gloves when handling the paper clip in case it gets hot.
Here is a no-load flasher module, but note that I did not try it with all LED lights, I just suspect it will work. It's returnable if it doesn't work out. https://www.amazon.com/Keep-Clean-10...dp/B00H8KDON0/
dmjlambert is offline   Reply With Quote
Old 02-18-2024, 10:32 PM   #3
forestb
forestb's Avatar
I have the non load flasher. The only reason I am looking for LED blinkers up front is so that they would be brighter.
Old 02-18-2024, 10:39 PM   #4
dmjlambert
dmjlambert's Avatar
Perhaps the no-load flasher you have is not working properly, or you need load resistors, or you might try incandescent 2357 bulbs which are brighter.
Old 02-18-2024, 11:03 PM   #5
forestb
forestb's Avatar
I don’t have it in front of me now but the amber bulb that is currently in the truck has a 4 digit part number that starts with a 3. If the led bulb is not going to be brighter than its not worth the trouble of getting a resistor and LEDs
Old 02-18-2024, 11:27 PM   #6
dmjlambert
dmjlambert's Avatar
My mistake for assuming you might have an 1157 bulb. There are many different bulbs that are similar in size and can interchange. Some are brighter than others.
Old 02-18-2024, 11:44 PM   #7
Getter-Done
Getter-Done's Avatar
My Nephew put a-Lot of LED light on his truck.
After he added a few,.
We had to add some filters.
I am not sure what kind.
Here is an example link.
Link: https://www.ebay.com/itm/22511000101...65a8eaf5faa12f
84 Chevy K-20
Old 02-18-2024, 11:47 PM   #8
forestb
forestb's Avatar
No problem. I think all of what you said still applies.
Old 02-18-2024, 11:48 PM   #9
forestb
forestb's Avatar
Thanks I will look into it.
Old 02-19-2024, 12:30 AM   #10
dmjlambert
dmjlambert's Avatar
When you find out the type of regular bulb you have that is not so bright, let us know and perhaps there will be a different bulb that will work better.
Old 02-19-2024, 01:01 AM   #11
forestb
forestb's Avatar
That’s what I was thinking thanks. When the storm we are having is over I will take a look.
