Old 02-26-2024, 11:55 AM   #1
Loose Screw
Loose Screw's Avatar
What's My Engine?
Stamping on the right front:
V0710FSD
TIA
Loose Screw is offline   Reply With Quote
Old 02-26-2024, 01:11 PM   #2
Troy Sr
Troy Sr's Avatar
Re: What's My Engine?
That might be a serial number, I'd look on the back where the tranny bolts up and find a casting number.
Take Care
Troy
Troy Sr is offline   Reply With Quote
Old 02-26-2024, 02:40 PM   #3
mongocanfly
Post Whore
mongocanfly's Avatar
More info would be nice
Inline 6-v6-v8- smallblock-bigblock- LS-diesel-??????
Pics would also be helpful
Mongo...aka Greg
RIP Dad
RIP Jesse
2023 Chevy Z71..daily driver
Old 02-26-2024, 03:26 PM   #4
Keith Seymore
Keith Seymore's Avatar
Carbed? Fuel injected?
K
Chevrolet Flint Assembly
1979-1986
1986 - 2019
Old 02-26-2024, 03:50 PM   #5
Loose Screw
It's an old 350 with points and ram's horns...
Old 02-26-2024, 05:14 PM   #6
dmb
Active Member
dmb's Avatar
sd comes up to a 327 1962 with a powerglide
dmb is offline   Reply With Quote
Old 02-26-2024, 05:51 PM   #7
Loose Screw
It's going to be a while before I get any numbers off the back of the engine. I just got the truck. The transmission shifts 3 times, but that's all I know for sure right now.
Here's a crummy picture...
Old 02-26-2024, 06:09 PM   #8
geezer#99
geezer#99's Avatar
But the suffix code is FSD
Old 02-26-2024, 06:15 PM   #9
geezer#99
geezer#99's Avatar
You got a pic of the pad?
Old 02-26-2024, 09:00 PM   #10
Loose Screw
Originally Posted by geezer#99 View Post
you got a pic of the pad?
Old 02-27-2024, 10:34 AM   #11
THI
Active Member
THI's Avatar
V - Flint Engine Plant
0710 - Build date
FSD - decodes to a 1994 350
A 350 built in the Flint Engine Plant on July 10, 1994
THI is offline   Reply With Quote
Old 02-27-2024, 11:07 AM   #12
geezer#99
geezer#99's Avatar
I found it to be a 94 350 but the lack of centre bolt valve covers threw me off.
Must have older heads on it.
Old 02-27-2024, 11:48 AM   #13
Loose Screw
So no tellin what vehicle this came out of. I was told that the ram's horn headers are the old thick metal type...for what ever that's worth. Frankinengine for sure.
It misses and has an exhaust leak. But believe it or not it doesn't leak engine oil, doesn't smoke, no clatter and starts right up!
...Oh, and it is hacked into the frame. Chopped out a crossmember and *relocated* it....
Thanks Guys.....
Old 02-28-2024, 01:31 PM   #14
Wrenchbender Ret
They probably used the older heads so they can use the older type intake manifolds.
George
Wrenchbender Ret is online now   Reply With Quote
