Old 03-04-2024, 10:30 PM   #1
Bigzack
Front Harness
I’m starting with the front lighting harness, the loom was supposed to be here today however a slight delay, that will give it time to relax the coil
Bigzack is offline   Reply With Quote
Old 03-07-2024, 11:13 PM   #2
Bigzack
Re: Front Harness
Parking light, side marker and horn wired
Old 03-11-2024, 04:46 PM   #3
Bigzack
Re: Front Harness
A little more work in the engine bay
Old 03-11-2024, 08:33 PM   #4
Bigzack
Re: Front Harness
After a snack break, I finished pulling the dash, main harness and fuse block
Old 03-18-2024, 10:01 PM   #5
Bigzack
Re: Front Harness
Need some help, there is a plug on the front passenger side of the transmission with a dark green and a light green wires goes into the main wire harness
Old 03-18-2024, 10:15 PM   #6
Bigzack
Re: Front Harness
More work today
Old 03-18-2024, 10:49 PM   #7
LockDoc
The Older Generation
LockDoc's Avatar
Re: Front Harness
Are you talking inside the cab or underneath the cab.... Do you have an automatic or manual trans? It sounds like they would be for the reverse lights.
Leon
Old 03-19-2024, 12:06 AM   #8
Bigzack
Re: Front Harness
Thanx totally forgot about reverse lights, 4 speed manual
