Old 03-07-2024, 11:53 AM   #1
novaX522
Airlift airbags for rear
I have a 1972 c10 with rear coil suspension. It has 2” drop springs and a 1” drop block. I run 31x10.50-15 tires. I have the stance where I like it. I do plan to pull an open trailer with my race car on it occasionally. I looked around for air bags for a c10 and none are listed. I found some info on here, but that was for trucks dropped more than mine. I spent some time looking through Airlifts custom size airbags.
For my application I went with part number 60924. It is 5.5” x 8.5”. I think I could have went 1” taller, but I think this will work great.
I drilled a 3/8” hole through the upper spring clamp and frame for the air line to connect to the bag. Other than that, it was pretty straightforward.
novaX522 is offline   Reply With Quote
Old 03-07-2024, 11:57 AM   #2
oneshotkyle
Active Member
Re: Airlift airbags for rear
I like the idea of being able to pack a couple dirtbikes atleast. Would love to hear an update on your experience months from now
oneshotkyle is offline   Reply With Quote
Old 03-07-2024, 01:25 PM   #3
novaX522
Will do. Racing starts going late April around here. I’ll definitely do a test pull before then.
Old 03-07-2024, 02:29 PM   #4
Very kewl. Can't see clearly in picture, but did you run they line through a grommet? It doesn't look like it in yhe picture, and with no grommet the line could be worn/cut easily
Old 03-08-2024, 09:43 AM   #5
SCOTI
SCOTI's Avatar
x2.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 03-08-2024, 08:43 PM   #6
novaX522
I didn’t use a grommet. With the spring clamp and frame, it’s pretty thick. It would be hard to find a grommet that size. I did drill the hole much larger than the air line, and cleaned the hole of burrs. If it becomes an issue, I left extra length on the air line for repair. I would find a slightly larger diameter piece of rubber to go over the airline.
Old 03-08-2024, 08:47 PM   #7
novaX522
I drove the truck tonight with no load and 20 psi in the airbags. It was rough and bouncy. I let it down to 10 psi, and it rode nice and smooth like it always does
Old 03-09-2024, 08:24 AM   #8
That was a great move. You will be happy with your choice. I used Airlifts on a '70 Custom/10 I bought to use for work and used the bags in coils like you, standard height. A true 1500# boost in capacity, when needed, and same smooth ride which dropped pressure. My truck had a Reading steel topper with tools in side bins and bed, as well as walk boards, pump jacks, and ladders on top. It did great all because of those bags. Later I took the truck out of work duty and removed the topper. It rode great with the pressure dropped down
Old 03-09-2024, 07:57 PM   #9
indymachinist
I need to do this on my truck.
-Curt
My 1968 Chevy shortbed stepside build
indymachinist is offline   Reply With Quote
