03-25-2024, 04:44 PM | #1 |
425hp409
68 accelerator pedal
Is it possible to install a swinging accelerator pedal and go with the accelerator cable instead of the factory accelerator rod in y 68?
Charles 68 SWB, Dad bought new, now 396 & factory ac 64 Impala SS, 409 425HP, 4 speed AC 64 Bel Air Wagon, 400 Small Block 57 Bel Air all original 283 w/Factory Air 77 GMC Sprint, 454/425HP 67 Olds 442, all original 90 ZR1 Corvette |
03-25-2024, 05:03 PM | #2 |
Born Psycho
Re: 68 accelerator pedal
I did it on my 69 suburban - i cut out the firewall area from a 72 and welded it into my firewall, it was pretty simple-BUT- i had the front clip off and the engine was out of the truck so there was lots of room.
jerry moss 72 cheyenne super K20- tilt,tach,vacuum,speedwarning,buckets,shoulder belts,am/fm,tow hooks,bumper guards,toolbox,aux. fuel tank,posi front and rear,plus other goodies!!! SOLD 69 suburban K20-tilt,tach,vacuum,speedwarning,buckets,shoulder belts,am/fm,4 inch all spring lift,4 speed, 14 bolt full floater, dana 44 HD,warn winch,posi front and rear,tow hooks,plus other goodies. 73/80 chevy/gmc K20 SB400,turbo 400,205,tilt,a-c,gas hog. 77 K/5 cheyenne blazer-daily driver/beater. SON HAS IT NOW BRENTWOOD,CALIFORNIA |
03-25-2024, 07:37 PM | #3 |
Yes, there are adapter plates that make it pretty easy.
Or if you are feeling crafty http://67-72chevytrucks.com/vboard/s...00#post1383300
Roger '68 Short step - https://67-72chevytrucks.com/vboard/...d.php?t=849675 '69 ('70?) 2wd Blazer '70 GMC Jimmy 2wd |
