04-10-2024, 12:27 PM | #1 |
Bolts for battery tray? Size?
Anyone have pictures of the bolts for the battery tray? What size, length and head size are they?
Searched on here but haven’t found exact post yet. I can’t remember what they are/look like as I go through all my bolts to put the tray back on lol. Thanks!
- long term project '68 C10 true shortbed! Resto-mod. LS swap. Build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=769919 "I've still kept this project truck when anyone else would've given up and sold it as is. Giving up is easy, staying the course is part of life's journey" ___________________________________________ '68 C10 true shortbed, LS swap restomod. '03 Z71 daily, '63 AMC Rambler V8 survivor |
04-10-2024, 12:42 PM | #2 |
Re: Bolts for battery tray? Size?
Per AMK:
https://www.amkproducts.com/i-kits/c...&category=Body Kit: G-24046 BATTERY TRAY They are 5/16"-18 with the 1/2" head size
1970 K/5 Blazer CST 4WD, Bronze, 93k ACT. miles, 350, 4 speed, positraction, 16.5" x 8.25" wheel option, tilt, tach, vacuum, AM/FM, manual throttle...Dad ordered and purchased new 4/70. Currently frame off restoration in progress... 1972 Cheyenne Super 20 2WD, DK Blue/White, 90K ACT. miles, 402, TH400, 4.10 open, tilt, tach, vacuum, A/C, AM/FM, manual throttle.. A mostly original paint never rusted Texas survivor... 2017 Sierra 1500 SLT 4WD, Black, 41k miles, 5.3, 6L80E, 3.42 LS, 20" polished wheels, everything but moonroof and 6.2... 2019 Canyon SLT 4WD, White, 60k miles, 3.6, 8L45, 3.23 LS, 18" wheels |
04-10-2024, 06:21 PM | #3 |
Two different size 5/16-18. They're shorter on the LH side to add clearance from the radiator.
The battery box mounts to the core support’s RH rail using three (GR 5) 1/2" hex recessed head tapered bolts with spin washers. The bolt threads are 5/16-18 x 5/8”, and the heads are stamped "ELH". • The battery box mounts to core support’s rear wall using two (GR 5) 1/2" hex recessed head tapered bolts with spin washers. The bolt threads are 5/16-18 x 7/8”, and the heads are stamped "E". The box’s LH side has a fixed J-clip for the radiator overflow hose, though a retainer clips onto some boxes. The box’s LH side is stamped 3886786.
Tony 71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assm. guide "kit" for restoring the truck from ground up. With assys, the guide accts for 1000s details, OEM identifications & part numbers, written in short order. 700+ images of assm., illust., charts, and points of interest. Much of the info. applies to all 67-72 GM trucks, and to a lessor degree all 67-72 GM vehicles. My build thread, and more on the guide https://67-72chevytrucks.com/vboard/...d.php?t=730025 |
