Old 04-18-2024, 01:08 AM   #1
Luke87gt
275/60/15 at all 4 corners: lowering experts, please come in
Hi guys,
My ‘69 c10 is getting 275/60/15 at all 4 corners on 15x8 4.0” BS truck rallys.
I’m debating whether to do a 2/4 or a 3/5 drop.
Will either of these drops present any problems for me with the wheel combination above?
Luke
1969 C10 Shortbed
Wanted (pm me):
- Pair of 275/60/15 tires
Luke87gt is offline   Reply With Quote
Old 04-18-2024, 08:45 AM   #2
Marc33
Marc33's Avatar
Re: 275/60/15 at all 4 corners: lowering experts, please come in
following....
Current stable:
1970 K5 Blazer 4x4
1972 K5 Blazer 4x4
SOLD:
1971 GMC Sierra Grande 2500 2wd
1972 Chevrolet K5 Blazer
1966 Chevrolet C20
1972 Chevy Suburban 4x4 1500
1956 Chevy 150 2 door post
1956 Chevy 2 door post bel air
1968 Chevrolet C20
1958 Ford Thunderbird
1968 4x4 Suburban 1/2 ton
Marc33 is offline   Reply With Quote
Old 04-18-2024, 09:11 AM   #3
67C10Step
67C10Step's Avatar
OK, not a lowering expert, but I have a similar setup to what you are describing. My truck is a 2.5/4 static drop with 8" rally wheels. I went with 255/70-15 at the time to better fill up the fender wells.
I could easily add another 20mm of tread width and drop the front or rear another inch without any issues.
1967 C10
1980 Jeep CJ5
2020 Toyota 4Runner
2024 Toyota Tundra
67C10Step is offline   Reply With Quote
Old 04-18-2024, 11:44 AM   #4
cj847
cj847's Avatar
I am not an expert but here is my story.
1967 with 2.5 spindle drop 4" rear. 235/75/15. When I go over a big dip at speed the front tire will contact the inner fender.
My tires are smaller than 67C10step yet I have a problem and he doesn't. All that to say, I bet your plan will work. I just recommend that while you have the springs out, check the clearance with the truck on the bump stops. Then adjust things to make it work.
cj847 is offline   Reply With Quote
Old 04-18-2024, 12:01 PM   #5
67C10Step
67C10Step's Avatar
Interesting. The sidewall height on our two tire selections should not be very much different. When you did the drop spindle install did you replace the springs? Just thinking if you re-used the old springs they may have enough sag to give you more drop than I got out of mine. I replaced my front springs with stock height but now sort of wish I'd gone with a 1" drop spring.
1967 C10
1980 Jeep CJ5
2020 Toyota 4Runner
2024 Toyota Tundra
Old 04-18-2024, 01:09 PM   #6
CG
BlahBlahBlah
Here is a thread for 15 inch wheels only. I believe there are a lot of trucks in here that have the combo you are asking about.
https://67-72chevytrucks.com/vboard/...t=15+inch+only
Old 04-18-2024, 08:37 PM   #7
cj847
cj847's Avatar
The drop was installed by the previous owner. And the springs are definitely old and tired.
The thing that bothers me is regardless of what spring, if it ever hits hard enough to reach the bump stop it is going the interfere.
Old 04-18-2024, 08:55 PM   #8
67C10Step
67C10Step's Avatar
Dang man! You need to slow down! Just kidding. I’ve driven mine over 3000 miles since doing the suspension and getting it on the road and I’ve never even felt like I was close to hitting the bump stops up front.
1967 C10
1980 Jeep CJ5
2020 Toyota 4Runner
2024 Toyota Tundra
Old 04-18-2024, 09:41 PM   #9
mm1077
Active Member
mm1077's Avatar
Originally Posted by Luke87gt View Post
Hi guys,
Luke
This is my truck with 2/4 spring drop. 15x8 rallies w 275/60 on all 4. Daily drove it for a year with this setup -never an issue and our roads can get pretty rough around here. I just went to steelies and caps for the look I wanted.
mm1077 is offline   Reply With Quote
Old 04-18-2024, 10:25 PM   #10
Luke87gt
Very nice! What drop kit is that?
1969 C10 Shortbed
Wanted (pm me):
Old 04-19-2024, 12:14 PM   #11
MikeB
MikeB's Avatar
FWIW, 255-70x15 tires on 8" rally wheels from a square body truck barely rubbed the bolts holding my inner fenders to the outers. It only happened on bumpy roads while turning. I fixed it by replacing the hex head bolts with button head bolts. My truck has somewhere around a 2" drop at the front.
However, 275-60x15 tires are shorter than mine, so you may not have a problem, depending on how low you go.
Mike
1969 C10 LWB -- owned for 34 years. 350/TH350, 3.08 posi, 1st Gen Vintage Air, AAW wiring harness, 5-lug conversion, 1985 spindles and brakes.
1982 C10 SWB -- sold
1981 C10 Silverado LWB -- sold, but wish I still had it!
1969 C10 (not the current one) that I bought in the early 1980s. Paid $1200; sold for $1500 a few years later. Just a hint at the appreciation that was coming.
Retired as a factory automation products salesman.
Worked part-time over the years for an engine builder and a classic car repair shop.
Member here for 23 years! This is the very first car/truck Internet forum I joined. I still used a dial-up modem back then!
MikeB is online now   Reply With Quote
Old 04-19-2024, 12:57 PM   #12
mm1077
Active Member
mm1077's Avatar
Western chassis parts
Old 04-19-2024, 06:41 PM   #13
Luke87gt
With a 2inch spring drop, can you align to spec ?
1969 C10 Shortbed
Wanted (pm me):
Old 04-20-2024, 05:06 PM   #14
MikeB
MikeB's Avatar
That's a real beauty with a very nice stance.
Mike
Old 04-20-2024, 09:29 PM   #15
kaycee
kaycee's Avatar
275/60/15 on 15 x8 all 4 corners 2.5" front 4 " rear static drop no issues on rubbing . Rear tires wear out twice as fast as fronts
2001 Silverado K-1500
2005 FXDWG stage3
69 CHEVY Short/Step 327/4L60 373 posi
63 IMPALA 327
kaycee is offline   Reply With Quote
Old 04-20-2024, 10:26 PM   #16
67swb72klb
67swb72klb's Avatar
Never had an issue with mine not really sure on the drop on it though..
California 65 GTO---Texas 64 burb 283 ---Oklahoma 67 CST SWB BBW wood bed 327 2004r---New Mexico 72 k10 350 350 auto---Georga 72 short step project
67swb72klb is offline   Reply With Quote
Old 04-21-2024, 01:02 AM   #17
HalfBrit
I ran 275/60's for many years with a 2.5" spindle + 1" drop spring in the front. The rear was a 4" drop spring. This pic is that same drop with slightly smaller overall diameter 255/50-17's.
HalfBrit is offline   Reply With Quote
Old 04-21-2024, 10:50 AM   #18
MikeB
MikeB's Avatar
Earlier I wrote: "255-70x15 tires on 8" rally wheels from a square body truck barely rubbed the bolts holding my inner fenders to the outers."
My truck does have 85 spindles. I wonder if they position the wheel outboard just a little further? It's not much, because button head bolts fixed the problem! Tires are Cooper Cobras, which may be a shade wider or taller than BFG Radial T/As.
Mike
Old 04-22-2024, 12:18 AM   #19
Luke87gt
Cooper Cobras are generally a tad narrower than BFG T/As from my experience
1969 C10 Shortbed
Wanted (pm me):
