Old 04-22-2024, 10:39 PM   #1
donthekawguy
donthekawguy's Avatar
To Locktite or not to Locktite
I put my frame back together with grade 8 hardware, flat washers and lock washers. I wish I would have used nylon lock nuts but I didn't. Should I have used Locktite? This is one of those things that keeps me awake at night when I'm trying to fall asleep. lol
66 shorty
donthekawguy is offline   Reply With Quote
Old 04-22-2024, 11:13 PM   #2
Getter-Done
Getter-Done's Avatar
Re: To Locktite or not to Locktite
I thought this process thru/When I was building a frame for a 78 4x4.
I concentrated more on the shoulder of the bolt being long enough.
I did not want to use a Full threaded bolt
I wanted the shoulder to be in full contact with the frame and the bracket it was going thru.
I used Hardened washers to take up the space / (If Any) then a stover / toplock nut.
Loctite on this would be a plus.
Hope this helps.
84 Chevy K-20
Old 04-23-2024, 04:58 PM   #3
ACK
ACK's Avatar
Lock washers and torquing the bolts good and tight should be plenty fine. If you're still losing sleep, check a few bolts after driving a couple hundred miles and see if frame flex has loosened any of them up.
My truck ain't dead, it just smells funny.
ACK is offline   Reply With Quote
Old 04-23-2024, 06:13 PM   #4
lilpoindexter
lilpoindexter's Avatar
locktite > all other thread locking methods. Go buy some. redo the fasteners that you worry about....be happy
lilpoindexter is offline   Reply With Quote
Old 04-23-2024, 07:05 PM   #5
donthekawguy
I think this is the only thing that my brain will let me do. Lol I do have time to kill while waiting for the new ball joints to get here. There is close to 50 so that should keep me busy for a while. Lol
66 shorty
Old 04-25-2024, 12:18 PM   #6
Grounded63
Maybe loctite 290.
Grounded63 is offline   Reply With Quote
Old 04-25-2024, 08:44 PM   #7
Accelo
Accelo's Avatar
Their is more than one type of Locktite.
I would recommend using the "Blue" service removal type.
Accelo is offline   Reply With Quote
Old 04-26-2024, 07:57 AM   #8
Keith Seymore
Keith Seymore's Avatar
The factory fix on the assembly line for missing or mis-hit rivets was a 3/8" bolt, washer and nut.
They did not use loctite.
But - since there is red, and there is blue: a little blue loctite could never hurt.
K
Chevrolet Flint Assembly
1979-1986
1986 - 2019
Old 04-26-2024, 11:13 AM   #9
rideblue00
rideblue00's Avatar
IMO, me being a machinist, I would use red Loctite. And also if the frame wasn't coming back apart, I would use a crimped style lock nut instead of a Nyloc type. It wouldnt hurt to use a split type lock washer either. Frame stiffness is pretty important. Just my 2 cents.
rideblue00 is offline   Reply With Quote
