01-17-2004, 10:56 AM | #1 |
Stock GM Hei ?
I have a '72 GMC with the 402BB and I want to change my stock distributor to a stock GM Hei and a friend of mine gave me an Hei. People on the board said for me to get a '73 Hei. I took my Hei down to Napa and their Hei was a little different than mine. My hei has plates right under the Cap and no rotor and has a codensor and a black electrical piece with 2- screws and says GM on it. Napa's Hei doesn't have the plates right under the cap and looks to have a rotor on it. The Napa guy gave me a price for the rotor , so his uses a rotor. Is mine a later Hei or a computer controlled hei? Which one do I need? I don't want to use mine because it's very dirty and I don't want to go through the hassle of rebuilding it. Thanks everyone.
01-17-2004, 11:02 AM | #2 |
Resident Curmudgeon
It should have a rotor under the cap. The HEI you need is 4 pins on the module. If you remove the black thing that says GM how many pins on it? FYI, I'm sure there is a better way to tell so before going to that trouble, you may want to wait for a alternate response.
Currently on or near the homestead: 67 Chevy SWB 2WD stepside 350/3 on tree (Pat's) 67 GMC SWB 2WD Fleet 402/auto (Brian's under construction) 67 Chevy 3/4 ton 2WD 402/auto (Business Hauler) 67 Chevy 1 ton dually 2WD 396/4 speed (Former business hauler, Needs TLC) 68 Chevy 1/2 ton Suburban 2WD 250 six/3 on tree (Brian's Needs TLC) 70 Chevy 3/4 ton 4WD 350/4 speed (Pat's - Disguised as a 68 GMC) 71 Chevy SWB stepside (Crushed by tree - parts donor) 72 Chevy 3/4 ton 4WD (Parts donor) 72 Chevy 3/4 ton 4WD Suburban (Parts Donor) 72 GMC 3/4 ton 4WD 292 six/4 speed (Mine - Disguised as a 67 GMC) 81 GMC 4WD Dually Dump Body 350/4 speed (Business Hauler) 82 Camaro Z/28 355/Super T-10 (Pat's toy) 93 Caprice 9C1 (Brian's Cop Car) 02 Toyota Camry (Reliable but a souless steel and plastic hulk) 2011 2SS RS Camaro M6 Factory Hurst Shifter Maybe I need to sell some of this crap Yet another Bozo with a sawz-all |
01-17-2004, 11:04 AM | #3 |
Wish someone would do a complete run down on the HEI.
I've heard so many diffenent views even form parts houses.
1970 Chev CST 2003 Harley Fatboy 1975 Chevrolet Step Van 1956 Chev Bel Air 1977 Blazer 2WD For Sale $3000.00 1978 Blazer 2WD For Sale $7000.00 1978 Silverado 2005 Monte Carlo |
01-17-2004, 11:15 AM | #4 |
Mine has prongs at each end of the piece that says GM on it and each prong has 2 prongs, and the piece that says GM on it has 2 srews which hold itin palce.
01-17-2004, 11:19 AM | #5 |
Resident Curmudgeon
Sounds correct. Does it only have 4 leads that plug into the cap?
01-17-2004, 11:31 AM | #6 |
no, mine has only has 2 form the wire to the cap and mine does not have a rotor.
01-17-2004, 12:39 PM | #7 |
I have seen different amounts of leads at one end or the other on that black thing(control module) based on the year of the distributor. So that is the only real important part as far as replacing things that is what usually fails when its not getting fire
01-17-2004, 12:53 PM | #8 |
HEI did not start until late 74 on Cadilliac. There is a # on the side of the housing such as 1103532 that can be looked up to tell what year and car it was used in and the advance rates. The computor controlled HEI will have 2 sets of wires coming out of the base--one with 3 wires and one with 4 wires. This is the one tht you do NOT want. Get the one with 3 wires. If you like get the # and I will look it up for you.
56 Chevy Bel-Air 2dr. HT (purchased new) 71 Chevy Cheyenne SWB PU (502HO) 65 GMC short bed step--work in progress and my gofer |
01-17-2004, 01:37 PM | #9 |
Cause the Chicks DIG IT!!
that little thingy that says gm on it you guys were talking about is the ignition module. I believe it is what limits your red line to around 5000 rpm bone stock. Sometimes when these go bad when cold engine will run fine but when heated up it will just die and it won't start again till it cools down. This problem is sometimes caused by the lack of dielectric grease underneath it. The ignition module is an easy fix. Any parts store should be able to test them. I've had em checked at napa's and autozones and advanced autos before. There only about 15 bucks so it's an easy fix. You should have a rotor on there too. But then again I may be wrong. As far as not getting fire the main things are your hot wire going into the distributor, your coil, your ignition module, and then last off your pick up coil. As long as your plugs and wires are ok the next thing i'd do is to check the cap and make sure it isn't burnt anywhere. Then check the rotor this is usually a culprit too, as it will get little burnt black streaks on it. then check the ignition module and if all that stuff checks out your pick up coil is probably bad and it's about 15-20 dollar range too. Problem is you have to tear apart the distributor to put it in. HEI's came out in 75 but they might have come out in late 74 like the other gentlemen said on cadillacs
01-17-2004, 01:58 PM | #10 |
Currently Blazerless
The computer controlled hei will not have a vacuum advance, they all have to have a rotor.
1972 C/30 133" W.B. C&C 1970 GMC 3500 157" W.B. single wheel C&C Last edited by BLAZERMAN; 01-17-2004 at 08:40 PM. |
01-17-2004, 08:26 PM | #11 |
Thanks guys, I got the one with the 3 wires and the vacuum advance. Mine didn't have a rotor on it and I see where it goes on now. I'll send it out now to have it recurved.Thanks again. Dave
01-18-2004, 02:09 AM | #12 |
its all about the +6 inches
A good stock GM module WILL fire over the 4500 - 5000 RPM that so many ppl say. I have had mine to 6500 more times than I can remember and accidently up to 7500 once. (Bout crapped my pants on that one too)
Be very carefull on those $15 parts store modules. They are pretty much all junk and have given the HEI a bad rap. The GM one is 10 times better,a nd will run over 100,000 miles. I would pull one out of a junk yard for 20 bucks before I would ever run a parts store $15 one. |
