Old 01-17-2004, 03:24 PM   #1
gmc67swb
gmc67swb's Avatar
Serpentine Accesory Question
I WOULD LIKE TO CONVERT TO THE SERPENTINE SET UP USING JUNK YARD PARTS. MY QUESTION IS, WHAT SHOULD I DO ABOUT THE POWER STEERING PART OF IT. I CURRENTLY DON''T HAVE POWER STEERING. CAN YOU USE OUR POWER BOXES WITH THE LATER STYLE PUMPS? WHAT WOULD I NEED TO CONVERT TO POWER STEERING?
THANKS ,
LARRY
GM 330HP/350, Magnuson 122HH, Tremec TKO 5spd
gmc67swb is offline   Reply With Quote
Old 01-17-2004, 07:02 PM   #2
jmanz69
Careful, they attack...
jmanz69's Avatar
I am currentlt collecting the parts to do this. From what I understand, you can use the new style pumps. You will have to have a new set of hoses made. Napa makes them and so do some other parts places. You will need a power box and piman arm also. I got the serpentine brackets off ebay fro $40. I will get a new or rebuilt pump, alternator, water pump. If you get the complete set-up, then you can reuse those parts. You have to remember that the water pump will need to be changed. The serpentine pumps run reverse of a normal V-belt pump.
jmanz69 is offline   Reply With Quote
Old 01-17-2004, 07:27 PM   #3
Javy
Javy's Avatar
serpentine
GM Performance Parts offers a complete kit for small block.
http://www.gmgoodwrench.com/gmgoodwr...erpentine+belt
Javy is offline   Reply With Quote
Old 01-17-2004, 08:52 PM   #4
jmanz69
jmanz69's Avatar
Cool, but you saw the price of it right!! Holy crap, that's a lot of money. Especially for something you can get at the junkyard. If you are running TPI, you need one from a TPI car, if you are running TBI, you can use any one. The TBI serpentine sets don't give you room for the throttle body of a TPI.
Old 01-17-2004, 09:40 PM   #5
djracer
djracer's Avatar
You can get them from a 4.3v6 also if you are going to the junk yard. I got a set from a 95 caprice but I don't have them installed yet! I looked at several setups before choosing one because some of them have struts that run back to the intake and that is real difficult with a vortec intake.
Kevin
Special Thanks to All who have helped on the TRUCK!
My Pass Time Show http://s129.photobucket.com/albums/p...Chapter1-0.mp4
So Far my best Times are:
Motor only:
6.44 1/8 @ 104.13
10.39 1/4 @ 125.83
Nitrous Times:
5.785 1/8 @ 118.65 with a 1.336 60ft
9.168 1/4 @ 142.58 with a 250 shot dead out of the hole!
djracer is offline   Reply With Quote
Old 01-17-2004, 11:23 PM   #6
Low69CST
I bought an accessory system off an 84 vette that has worked great. I don't have the power steering hooked up yet, but I'm going to get some conversion fittings from Russel and make my own AN power steering hose, as mentioned above you can get hoses made by napa to work.
'69 CST Short fleetside
Lowered, 400 small block, 700R4, 4 wheel disc brakes, front sway bar & rear camaro sway bar (in progress)
'87 V10 4x4 Short Fleetside
Quad Suspension and Dual Tanks
Low69CST is offline   Reply With Quote
