Florida Key's Member
locating the temp guage wire?
does anyone have a wiring harness diagram or can lend assistance?
Craig Wood 1972 SWB Chevy Cheyenne 4X4 Restored stock except 454 (481 cu. in. now) most options Available pictures of my truck http://myoldtruck.com/gallery/browse...500&userid=528 Come to florida and visit www.Paradisewatersports.com |
update
ok i have done some testing of the sender wire and the temp guage and the wiring harness and the voltage at the guage cluster
sender wire has no ohm drop from the pin on guage plug to the sender on the motor... temp guage reads 54.2 ohms resitance across the two side terminals voltage at the guage on the printed circuit reads 12.8 volts on one side and 7.4 volts on the other
Watch out for your cornhole !
![]() Join Date: Jun 2003
when you ground the wire, what does the guage do?
grounding wire
tell which wire you are referring to and ill try it
Is there a green wire that goes to the temperature sending unit?
green wire
yes there is a dark green wire running from the guage to the sending unit
its all about the +6 inches
Ground that green wire, if the guage tachs out, then everything from that wire to the guage is working. (assuming it goes to full ledt when not grounded)
