Old 02-05-2004, 01:42 AM   #1
chicogixr
Angry wierd engine sounds
im getting wierd engine sounds coming from what sounds like the pass. side. it sounds like detonation but its louder and it doesnt happen all the time. it happens when its its accelerating any faster than your grandma does, but when the engine is been running for like 15 minutes it doesnt do it- only a little sometimes. performance is the same so i dont think its a connecting rod. maybe one of my rockers is a little loose? i think it might be the torque converter or flywheel but i dont see any rub marks. since it stops after a while maybe something with the transmission?how fast to atf heat up? ill try to pull the valve cover tomorrow but for now i dont know. its a newer engine maybe 10-15k 350. in a 79 k10 and a t350.
chicogixr is offline   Reply With Quote
Old 02-05-2004, 02:35 AM   #2
bigjimzlll
bigjimzlll's Avatar
Hey...ever come by the redding drag strip? if you do..look me up. Check your converter to flex plate bolts ans look for a cracked flex plate
It's called "drag racing" if they called it "tic..tic..WHAM!..BANG! F*&K!!!", they'd have to keep the magazines under the counter with the other men's publications
click the clicky to join the site....
67 lwb..first hotrod in 25 years..540 best ET is 9.45 @ 141.44
Anderson,CA
bigjimzlll is offline   Reply With Quote
Old 02-05-2004, 03:09 AM   #3
chicogixr
ill check the flywheel. where is the drag strip? are they doing anything during the winter time?
Old 02-05-2004, 03:13 AM   #4
bigjimzlll
bigjimzlll's Avatar
No..they start in March..heres the link
http://www.reddingdragstrip.net/
Anderson,CA
Old 02-05-2004, 12:57 PM   #5
shadetree
shadetree's Avatar
Chico, get a mechanics stethoscope (or a reasonable substitute) and listen near the fuel pump, for that noise. Stock fuel pumps have a knack for breaking the return spring, causing the solid steel pushrod to "knock" at certain rpms'.
1970 long fleet, 355 4 speed, primer, walnut goodies
shadetree is offline   Reply With Quote
Old 02-05-2004, 01:34 PM   #6
chicogixr
i have a electrical fuel pump.
Old 02-06-2004, 08:40 PM   #7
flip66
flip66's Avatar
Some of them have an emissions flap on the passenger side that goes between the exhaust manifold and the exhaust it works off the vacuum from the emissions system. It stays closed until the engine warms up and then opens. It could be leaking when its closed would sound like a exhaust leak or tick until it opened and let exhaust pass through.
flip66 is offline   Reply With Quote
Old 02-07-2004, 12:02 AM   #8
chicogixr
i talked to a guy and he said its most likely detination. it doesnt help that my rockers are a little loose either
Semper Fi
seafoam green 79 K10 stepside with a 6" lift, 33" baja claws, billet interior, autometer gauges, 350/t350
