02-11-2004, 04:19 PM | #1 |
80 Blazer question on price
I have a chance to get a 80 Blazer with only 34,000 miles on it. It is four wheel drive and everything still works. Body is in great shape with only the passenger rocker a little rusty. It is painted Silver. What would be a good price? Thanks in advance Kerry (Wootdog)
1969 Chevelle 1990 IROC Z Convertible 2002 Silverado LT |
02-11-2004, 05:15 PM | #2 |
around here depending on options and aftermarket acc. I'd say 3-4k
2011 CCSB GMC 2500HD DMAX 73 GMC 3/4 ton 4x4 96 Chevy 1500 STD Cab Shortbed Z71 Owner of WickedWolfRC.com |
02-11-2004, 07:40 PM | #3 |
Are you sure that 34,000 miles isn't 134,000 miles. I'd give 2500 at the most.
02-11-2004, 07:54 PM | #4 |
Positive
A friend of mine has had it for the last couple of years. He bought it from a Dr. in Conn. that only used it sparingly. Mostly to plow the parking lot for his medical building.
02-11-2004, 07:59 PM | #5 |
Options
It has the Silverado trim package. Wootdog
02-13-2004, 01:22 AM | #6 |
Big Block Blazer
$2,500-$3,000
[1985 Chevrolet K5 Blazer][454BBC][TH400][NP241][Dana 44][GM 12 Bolt w/ Eaton LSD][Hedman HTC Hedders][Dual 2.5" Stainless Steel Exhaust][Hedman Turbo Muffler's][Dual Spal's 14" Electric Fan's][32x11.50R15 BF Goodrich All Terrain TA KO's on 15x8 Rallys] |
02-13-2004, 11:17 AM | #7 |
Plow truck then it's a hard 34k. Also you often will have problems with leaks , rust, rings etc in a low mile truck like that. It was sitting neglected in the summer proablably with dirty oil. Pobably had limited run time causing a lot of condinsation in the oil and ATF.
If the rocker rot is very limited I would say $3k tops but kind of hard to say without seeing it. I sold a loaded (windows, locks cruise working A/C) 79 to a guy up that way last year for $3k but it had a crate with about 12k on it and rebuilt everything. Little rocker rot and a little trail rash. A relativly rust free truck up that way does seem to go for a little more then down here.
Grim-Reaper 70 Pontiac LeMans Sport Convertible, worlds longest resto in progress Looking for 71-72 2wd Blazer or Jimmy Project |
