Old 02-12-2004, 09:22 PM   #1
yellowgmc
Getting cabin fever?!?!?!
yellowgmc's Avatar
85 blazer problem rust areas?
hey all. i usually post over on the 67 - 72 side but i'm looking at an 85 blazer. where are the problems rust areas on these things? i'm wondering what i will be looking at replacing. i know the drivetrains are pretty bulletproof.
Member of the Discs Up Front Club
1972 GMC 1500
1994 F-150 XL 4x4
Tact is for people not whitty enough to be sarcastic
yellowgmc is offline   Reply With Quote
Old 02-13-2004, 01:20 AM   #2
IoWnZa
Big Block Blazer
Fender's, wheel wheel's, rocker's, door's, tailgate, roof/windshield area.
[1985 Chevrolet K5 Blazer][454BBC][TH400][NP241][Dana 44][GM 12 Bolt w/ Eaton LSD][Hedman HTC Hedders][Dual 2.5" Stainless Steel Exhaust][Hedman Turbo Muffler's][Dual Spal's 14" Electric Fan's][32x11.50R15 BF Goodrich All Terrain TA KO's on 15x8 Rallys]
IoWnZa is offline   Reply With Quote
Old 02-13-2004, 11:21 AM   #3
Grim Reaper
Rockers, above the rear wheel openings, tail pan were the gate bolts to is the worst areas.
In I think 86 but may have been as late as 88 they started galvanizing and they are much less prone to rusting out. Before that they don't even have paint on the insides of the rockers and that;s why they rust out so bad. Same problem that the 67-72's had rotting out up around the top. No paint and it would form condinsation.
Grim-Reaper
70 Pontiac LeMans Sport Convertible, worlds longest resto in progress
Looking for 71-72 2wd Blazer or Jimmy Project
Grim Reaper is offline   Reply With Quote
Old 02-13-2004, 03:30 PM   #4
yellowgmc
yellowgmc's Avatar
cool thanks guys.
1972 GMC 1500
1994 F-150 XL 4x4
Old 02-14-2004, 12:28 PM   #5
Mike Martin
My 82 Jimmy had a leak that was in the seal between the fixed roof and the removable roof. Unknown to me it had been leaking for years, basically ruining the floorpan, front and rear. Check out the floorpans on any vehicle you are interested in. The repair of these is a bear (or at least it is to me.) There was also a small leak around the front windshield, Someone else mentioned a cowl leak. Good luck.
Mike Martin is offline   Reply With Quote
