Old 02-22-2004, 02:06 AM   #1
Chevyman90
Power steering problems
I recently bought someones project truck, a 1978 silverado shortbed converted to a 3/4 ton 4x4 the problem I am havin is to do w/ the power steering previous owner cut the lines so i had to put new hoses on the steel lines, and everytime I tightin down the hose clamps and test it out if i turn it full bore to one side the hose shoots off and fluid goes everywhere, is there a way to prevent this from happenin or will i have to get stock lines w the special fittings , I have yet to flare out the steel lines since ive been in a hurry do you think if i flare them out it will be less likely to shoot off the line?
1990 cheyenne 1500
Chevyman90 is offline   Reply With Quote
Old 02-23-2004, 08:39 PM   #2
eaglelox
Member Dude
eaglelox's Avatar
get the pressure in hose crimped at a hydrolic shop.you dont need to on the return side. when you hit full stroke you are probably squirting oil at 2500 psi, so dont get your hand near it.
Steve
1978 K20 Burb, 4" lift, 33's, 350
Eaglelox@Hotmail.com
eaglelox is offline   Reply With Quote
