03-18-2004, 11:47 PM | #1 |
HEI & Tach ?
I installed my tach dash last weekend,and it looks great ! Now I picked up a HEI Dist from pickmup without thinking about if it will work with the tach ! So is it possible to use the HEI dist with the 67-72 tach ???
Where Am I ? How did I get Here ? 1970 K-10 292 Longbed stepside (now a stakerack)powersteering ,Factory step bumper,Tow Hooks,Deluxe gauges Tach & Throttle, 4 speed manual 1 out of 464 made with protectoplate intact . |
03-19-2004, 12:22 AM | #2 |
Going up ?
03-19-2004, 12:26 AM | #3 |
"Trucks with Class"
Yup!
Yes the stock tachs, or Camaro tachs, work fine with HEIs. Did you get a 6cyl tach?
03-19-2004, 12:32 AM | #4 |
Yes,Your Hei and recovery tank arrived today ! Is the hose long enough to mount on the drivers side of the radiator ?If so where does the hose rout to?
03-19-2004, 02:05 AM | #5 |
"Trucks with Class"
It is designed to go on the right side, right by the battery. It is in the same location as the windshield bottle, on the other side. They match and look like they were meant to go there.
03-19-2004, 09:42 PM | #6 |
Is that recovery tank just an old winshield washer tank if not how can I get one.
03-20-2004, 12:35 AM | #7 |
"Trucks with Class"
NEW!
You can "rig" up a WS bottle set, but this is a new 6-piece set with correct size hose, recovery cap, etc. It sells for $40 delivered. to you.
03-20-2004, 10:50 AM | #8 |
Installed mine last night it looks factory,alot better than the cheap one I had before !
