Old 03-29-2004, 05:27 PM   #1
54rustbucket
Question Moving '54 chevy rear axle
I have a rusty '54 chevy truck that I'm begining a ground up rebuild. A friend told me I should move the rear axle back a few inches to center the wheels in the wheel well openinings. Does anyone know the best way to do this? Can I just drill off the original bracket held on with rivets and move them back then reattach with bolts. It almost sounds too easy. Also, is this common practice?
54rustbucket is offline   Reply With Quote
Old 03-30-2004, 11:27 AM   #2
solidaxel
solidaxel's Avatar
That would work but I think it would be a lot of work !! Why not drill the main leaf and the next one and re stack the rest of the leafs !! When you put large tires in the wheel well it will fill up the opening and yes the axle is one and a quarter inches too far forward. There are many ways to perform this surgery all in the name of HOT RODDING, go for it !!! While your at it why not change the axle to a Monte Carlo-Reagle or a wider one like a mid 70's Camaro, and don't forget to lengethen the drive shaft !!!
53 TuTone Extended Cab 350 4-Spd 3:08 (SOLD)
53 Chevy Moldy pearl green ZZ-4 4L60E 9" 3:25
55 GMC 1st Black Mll (ZZ4) ZZ6 TKO 600 5 sp 3:73
62 Solidaxle Corvette Roman Red (327
340hp 4spd 3:36) C4 & C5 suspension tube chassis
LS 3 4L70E
65 Corvette Coupe 327 350hp 4spd 4:11
78 Black Silverado SWB (350/350) 5.3 & 4L60E 3:42
2000 S-Type 3.0 (wife cruiser)
2003 GMC SCSB 5.3 4L60E 3:42
solidaxel is offline   Reply With Quote
