Old 03-29-2004, 10:21 PM   #1
69-z28
Wanted Blazer rear hatch handle with key
I need a 69 -72 blazer rear hatch handle with key. Let me know what you have.
Thanks, Dave
69-z28 is offline   Reply With Quote
Old 03-29-2004, 11:00 PM   #2
earnhardt221
hatch handle
Hey Dave Whats Up
If you go to www.chevylandparts.com that guy has the factory hatch handles for $32.95 new i believe w/keys. Check him out you wont go wrong.
Glad to help you out
Tom e-mail:earnhardt221
earnhardt221 is offline   Reply With Quote
Old 03-30-2004, 12:04 AM   #3
badpeanut
Not a bad nut after all..
badpeanut's Avatar
The cheap solution is to use a garage door T-handle (approximately $8 at a hardware store), cut the handle to length, drill a hole for the spring pin, and transfer over your torsion spring and bracket. The only downsides are slightly different cosmetic appearance, and you loose the flapper door where the key goes in (helps to keep out the elements).
If you need the torsion spring or bracket I think I still have an extra set.
badpeanut is offline   Reply With Quote
