Old 04-05-2004, 07:31 PM   #1
4Burb4
Unhappy Rear Air Switch for '72 Sub
I have been looking all over the place for a factory rear air switch for a '72 rear air set up. This is the switch that sits below the headlight switch on the gauge bezel. This is a 4 position switch, off/low/med/high, and has 4 prongs on the back (3 to the harness, 1 to the fuse box) Anyone have one or know where to look, or if all that is not possible, where to find a suitable replacement? THX.
4Burb4
4Burb4 is offline   Reply With Quote
Old 04-06-2004, 08:35 AM   #2
bagged91
Out draggin'
bagged91's Avatar
Yeah, ME TOO!!!!
Yeah, I need the switch too with all the mounting hardware and the plate. I haven't seen them listed "new" so does anyone have a good used one they can spare?
91 GMC Xcab LB-Bags/bd/caddy clip SOLD
72 C10 Cheyenne Super LWB SOLD
92 GMC K1500 Burb
72 C10 Burb (ex. Cheesewagon)SOLD
72 C20 Burb parts truck
71 C10 Burb "project"
bagged91 is offline   Reply With Quote
Old 04-13-2004, 11:06 AM   #3
JimKshortstep4x4
Talking
The rear air switch is made by Indak and I believe they can help you. The PN stamped on the switch is 3999580. You might have to contact them but take a look at the three speed rotary switch.
The picture looks just like the original switch. Koch Sales is the distributor for the Indak switches.
Here is a link.
Jim
http://www.kochsales.com/3posrot.htm
Old 04-13-2004, 11:19 AM   #4
4Burb4
Smile
Jim,
Thanks for the help. I have sent a request to Koch's site, so I'll keep you posted if I get a positive result. We're keeping our fingers crossed here... summer's on the way!
Rich
Old 04-13-2004, 11:44 AM   #5
JimKshortstep4x4
Talking
Should you get the correct switch number, please post it as I am sure others will be interested.
Jim
Old 04-13-2004, 06:55 PM   #6
bagged91
Out draggin'
bagged91's Avatar
I for one am interested in a switch or two!!!! Let us know how you made out Rich!!
Thanks for posting this Jim!
L8R - Joe
92 GMC K1500 Burb
Old 03-26-2005, 12:15 PM   #7
Bubsco
Anyone find one?
Did you guys have any luck before I start the process ...
Bubsco is offline   Reply With Quote
Old 03-26-2005, 02:36 PM   #8
bagged91
Out draggin'
bagged91's Avatar
I lost the thread so I couldn't contact them. Let me know if you find anything out. I don't have the original switch right now to go off of either...
92 GMC K1500 Burb
Old 03-27-2005, 12:46 AM   #9
Bob Moore
A very good place to look for the switch itself is in what we call conversion vans - like Coachman etc. Many of these have the rear air option. The switch is on the dash towards the center of the panel. These are great for other uses also. I believe my brother adapted one for dual gas tank sending units. They are quite heavy duty as a lot of current flows into them. The wire terminal(plastic plug) that connects to them is partially melted sometimes. If I recall the standard chrome bezel nut from the 67/72 dash fits just fine along with the knob.
The little tab that says REAR AIR is virtually impossible to find.
I think the switch would work with both rear air and full length air.
Another source for the switch is the early flat face vans with the motor behind the driver. These have an almost vertical steering column with the heater controls in the column brace. One control is an electrical switch with a pull cable knob. The Truck Shop of Orange lists the following:
Heater Control Switch,Push-Pull Cable 64-66 #64-04904 $54.00
I believe the 67/72 chrome bezel and knob fit this also. Just disregard the push-pull feature and use the twist portion.
Hope this helps some of you lucky Suburban and Panel owners out there. I am sooooo jealous..
Good luck - Bob
67 C-20 LWB, tilt, speed alert,
vac, 454, T400
67 C-10 SWB, factory air with
more to follow
Bob Moore is offline   Reply With Quote
Old 03-27-2005, 02:31 AM   #10
benscool1
benscool1's Avatar
Bagged91, I have ur switch and most of the other parts removed and ready to ship, check ur inbox, u have a PM.
Ben
84 C10 Silverado
14 Silverado Z71
benscool1 is offline   Reply With Quote
