Old 01-21-2014, 09:07 PM   #1
LockDoc
The Older Generation
LockDoc's Avatar
Making A New Oil Pressure Line.
I guess this is where this would go. It's kind of self serving but I think other people might get some use out of it also. It's geared toward the '67-'72 Chevy and GMC's, but should work on anything with a SB and mechanical gauge.
How to make a new oil pressure line for the Chevy small block V-8's, using 1/8” copper tubing, a brass adaptor, and 2 brass compression sleeve nuts. First install the block adapter fitting and snug it down. I would use a small amout of thread sealer or 1 ½ wraps of teflon tape on the threads. Do not over tighten! Then bend the line to the shape shown in the pictures below. The coiled part is 1 1/2 coils that are about 2 ½” in diameter. Just wrap the tubing around an object that is close to that diameter. The coil is needed to absorb vibration and movement of the engine. Once you have the general shape, insert the long straight end of the line through the firewall, then screw the bottom sleeve nut into the block adapter fitting while pushing down on the 1/8" tubing. (do not completely tighten) Then go inside, slide the sleeve nut back on the tubing if you removed it, push the tube inside of the oil pressure gauge as far as it will go and while holding it in, tighten the compression sleeve nut. Then finish tightening the sleeve nut on the block adapter fitting. Do not over tighten these sleeve nuts! About ¾ turn after they are seated should do it. After you start the engine check for leaks at all connections and snug up as needed….
The bottom picture shows the location of the oil pressure port on a small block.
LockDoc
Leon
Old 01-21-2014, 09:51 PM   #2
ray_mcavoy
Re: Making A New Oil Pressure Line.
Good write up!
I'd just like to add (for anyone that's interested) that those compression sleeve nuts pictured are the type that will fit into the back of most factory GM mechanical oil pressure gauges as well.
They're available from Weatherhead as #6100x2. And the block adapter fitting is #6200x2.
ray_mcavoy is offline   Reply With Quote
Old 02-04-2014, 11:30 PM   #3
Red65C10
Red65C10's Avatar
Does the lines have to be flared ? What holds them in place if you don't ?
Thanks,
Billy
65 C10
............................... ____
................ ________-|___\____
.;.;;.:;:;.,;.|__(O)___|____/_(O)|
_______________________________
P.S. Send truck money !
Red65C10 is offline   Reply With Quote
Old 02-05-2014, 07:18 AM   #4
Indian113
Indian113's Avatar
The compression of the tightening down holds the tubing in. You don't need to flare these.
Indian113 is offline   Reply With Quote
Old 02-05-2014, 11:52 AM   #5
bigmac73
bigmac73's Avatar
if i wanted to add a secondary back up pressure gage, could i run a line from the front of the engine ? I noticed that there where two small plugs in the front of my block slightly above the water pump
Mike
72 C-10 Cheyenne off frame resto and Upgraded to 4 wheel disk, Tilt, Dakota Digital Dash / Rear slider.
421 SBC / TH350 3000RPM Stall
Progression Ignition /Holley 750 DP/3:73 gear Eaton Limited Slip unit / 2 1/2 exhaust glasspacks
bigmac73 is offline   Reply With Quote
Old 02-05-2014, 05:02 PM   #6
storm9c1
*** That's interesting ***
storm9c1's Avatar
What engine?
On a SBC, the only other oil pressure plug is above the oil filter IIRC.
Tom
Chevy by day...
1969 Chevy C30 Rollback Tow Truck -- 383 stroker, 4L80E
2011 Chevy Caprice PPV 9C3 6.0L
1995 Chevy Caprice 9C1
1994 Chevy Caprice 9C1 #3
1995 Chevy Caprice Wagon #2
1995 Chevy Impala SS
Mopar by night...
1969 Dodge Charger
1972 Chrysler Newport 2dr Hardtop (27K miles)
Plus others...
storm9c1 is offline   Reply With Quote
Old 02-05-2014, 05:08 PM   #7
storm9c1
storm9c1's Avatar
Thanks,
It's been a while since I made up new lines, but if I recall, the sleeve nut distorts and bites on the tubing as it's tightened (and makes a seal). Nothing else required.
Tom
Chevy by day...
Mopar by night...
1969 Dodge Charger
Plus others...
Old 02-05-2014, 07:12 PM   #8
Bigdav160
Bigdav160's Avatar
Originally Posted by storm9c1 View Post
What engine?
I think the one just above the timing cover, on this earlier engine, is also oil.
OK, I'm editing to add another picture with a later block
My Classics:
'72 K20 Suburban + '65 Dodge Town Wagon
'72 Corvette Roadster +'67 Corvette Roadster
'73 Z-28 Camaro
'63 Ford SWB Uni Pickup
'50 Ford Coupe
Bigdav160 is offline   Reply With Quote
Old 02-05-2014, 07:25 PM   #9
ray_mcavoy
Yes, it is. More info here --> http://www.chevytalk.org/fusionbb/sh...?post/1598732/
Old 02-05-2014, 11:24 PM   #10
pritch
pritch's Avatar
I'll be building a new one if I can't get my old one to polish up. 292, but all the fittings are the same.
Thanks, LD!
'68 Panel
Project Boogie Chillin'
'68 C-10
Ol' Green
pritch is offline   Reply With Quote
Old 02-06-2014, 03:26 PM   #11
storm9c1
storm9c1's Avatar
Originally Posted by ray_mcavoy View Post
Cool. Never messed with blocks that early.
Tom
Chevy by day...
Mopar by night...
1969 Dodge Charger
Plus others...
Old 04-06-2014, 12:13 AM   #12
richards72chevy
richards72chevy's Avatar
Where did you purchase the block adapter LockDoc?
richards72chevy is offline   Reply With Quote
Old 04-06-2014, 06:42 AM   #13
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
Leon did a fantastic article here.
I want to add something else to it.
Auto parts stores are not where you shop for stuff like this. Few parts stores carry this kind of thing anymore. You want to go to a hydraulic shop. They speak this language and will have everything you need without hassle of dealing with a parts guy who isn't familiar with things outside of spark plugs and Christmas Tree air fresheners. I can walk into my local hydraulic shop for these fitting Leon mentioned and walk out with my parts in under 5 minutes total. Try that at Autozone. I learned this about 20 years ago when I was building an oil pressure line. The guy at the hydraulic shop said big trucks use this same stuff on air shifter lines so its commonly bought stuff.
Old 04-06-2014, 10:27 AM   #14
earl84
It is a bit** to get to the back of the gauge cluster for removing this line from the oil pressure gauge. Is there some sort of coupling nut for a quick disconnect that can be purchased? I bought a kit but it only has the two end fittings for the engine and the oil pressure gauge, and would REALLY like to have a coupler just into the engine bay for the future.
earl84 is offline   Reply With Quote
Old 04-06-2014, 11:02 AM   #15
cableguy0
Yes you could add a union in the line under the hood BUT the fewer connections the better. Each connection is another chance of a leak. You DO NOT want this line leaking. High pressure oil even through a 3/16's line will empty the engine in a hurry.
Owner of North Point Car Care in Dundalk Md. We specialize in custom exhaust on both modern and classic vehicles. We are a full service auto shop from classics to modern vehicles. Feel free to contact me with questions. I will give a 10% discount to any board member.
cableguy0 is offline   Reply With Quote
Old 04-06-2014, 06:24 PM   #16
richards72chevy
Im trying to hook up my factory oil gauge and I came up short when I purchased a sunpro tubing kit from autozone.I may just break down and buy the oil pressure gauge and hook it up.
Old 04-07-2014, 10:58 AM   #17
Ironangel
Ironangel's Avatar
Location: Falls City, Nebraska "100 Miles From Nowhere"
Good write up Doc, thanks! I purchased all the parts needed at the local "Ace Hardware"...FireFighter is correct, even the guys working the counter at the NAPA in the neighboring town act like your pulling teeth when they have to look up a fuel pump shaft or a spin-on oil filter adapter for a 72 350 Chevy..."Old School Rules!"
Michael of the clan Hill,
"Two Seventy Two's"
71 1-ton Dually 350 4-Speed
71 C/50 Grain Truck, 350 Split-Axle 4-Speed
02 3/4 ton Express
14 Indian Chief Vintage
1952 Ford 8N, "Only Ford Allowed On The Property"
"Be American, Buy American"
Ironangel is offline   Reply With Quote
Old 04-07-2014, 12:40 PM   #18
GASoline71
"I ain't nobody, dork."
GASoline71's Avatar
I have an Ace Hardware store in my town that is the go to for stuff like this as well.
Awesome write up!!
I had to replace mine about 5 years ago. Since it is a PITA to get to the fitting under the dash, I put a union fitting on mine just outside the firewall in the engine bay. No leaks so far to this day.
Gary
'cuz chicks dig scars...
My 1972 GMC 1500 Super Custom (Creeping Death) "long term" build thread.
The Rebuild of Creeping Death after the wreck
Originally Posted by LONGHAIR View Post
I would never rebuild a 305.
Originally Posted by prostreetC-10 View Post
I love using vacuum gauges as part of the carb tuning process. I hook the gauge to the inside of my garbage can and leave it there.
Originally Posted by Marv D View Post
Remember Murphys 2nd law of mechanical relationships... "OPPOSING COMPONENTS ATTEMPTING TO OCCUPY THE SAME SPACE, AT THE SAME TIME, GENERALLY END UP OCCUPYING ADJOINING SPACE AT THE BOTTOM OF THE OIL PAN"
Originally Posted by cableguy0 View Post
Its cheaper to listen to advice given when you ask for help than it is to ignore everyone and wait for carnage.
GASoline71 is offline   Reply With Quote
Old 04-23-2014, 10:24 PM   #19
LockDoc
LockDoc's Avatar
Thanks guys. I have some oil line kits made up in case you can't find the parts.
http://67-72chevytrucks.com/vboard/s...d.php?t=613373
LockDoc
Leon
Old 12-31-2014, 12:02 PM   #20
Longhorn 70
Longhorn 70's Avatar
OK now I have to clean mine up. I have it with no loop in it. I imagine the vibration could losen the end that fits to the gague. Don't want engine oil squirting the driver some day. Thanks for the write up.
1970 Longhorn, Front Disc, 350/4 bolt, 882 heads, HEI, Edelbrock, 700R4, HO-52/4.11.
1996 Corvette, Collector Roadster, LT4, 396, 450RWHP, 6sp, 4.11/Dana44/posi 5 point roll bar
And let us not grow weary of doing good, for in due season we will reap, if we do not give up. Gal 6:9
Longhorn 70 is offline   Reply With Quote
Old 06-03-2017, 09:17 AM   #21
thetruckrman
Really good informative thread, gentlemen. Thanks! I have a 1970 C20 Camper Special project that I just began. The oil sender in the 350 SBC was changed by PO to an electric sender. This thread really helps me!!!
Last edited by thetruckrman; 06-03-2017 at 09:22 AM. Reason: I figured out that the block fitting IS the connector.
thetruckrman is offline   Reply With Quote
Old 12-05-2017, 12:05 PM   #22
Richard2112
Richard2112's Avatar
For the longest time I thought it was my valve covers leaking. After a closer look, sure enough it's the line when the oil pressure fitting goes into the block. Then I thought, these fittings just can't be available any longer.
Great write up Doc. Thanks
Richard2112 is offline   Reply With Quote
Old 12-06-2017, 01:49 PM   #23
GASoline71
GASoline71's Avatar
Lots of applications for these copper lines and 1/8" fittings besides oil lines. These fittings will be around for a long time.
Gary
Old 10-10-2018, 06:58 PM   #24
Larry64
I'll take one please, for an inline 6. To 37091
Never drive faster than your Guardian Angel can fly
Larry
Larry64 is offline   Reply With Quote
Old 10-10-2018, 09:55 PM   #25
LostMy65
But Found Her 25yrs Later!
LostMy65's Avatar
I had the nylon tubing in my 66, and it became brittle and split and blew oil all over my father-in-laws driveway.
I've read of guys having them spray all over under their dash.
I guess that would have been worse.
I'm replacing mine with copper.
However, I have read of some saying that copper may crack from vibration.
Has anyone heard of or had an issue with the copper tubing?
66 C20 Service Truck:
