07-17-2019, 09:10 AM | #1 |
Vintage Air Wiring with LS Standalone Harness
My BP Automotive harness included a connector for "AC Pressure Sensor Wiring" which increases idle and turns the e-fans on when compressor is running (per the BP website). I have a trinary for my VA to turn on the fans so this isn't necessary but I would like to hook up the idle increase functionality if feasible. Can anyone aid me on how this may be done? Attached are the wiring instructions for the VA.
My Daily Driver Build: http://67-72chevytrucks.com/vboard/s...d.php?t=755668 |
07-17-2019, 09:19 AM | #2 |
Re: Vintage Air Wiring with LS Standalone Harness
What year is your engine?
My '72 short bed build. http://www.ls1tech.com/forums/conver...6-0-4l80e.html 5.3 swap into my RUSTY '71 C10 http://ls1tech.com/forums/conversion...71-c-10-a.html |
07-17-2019, 09:26 AM | #3 |
It is a 2000 4.8L Tahoe engine. I am using the VA GenIV system if that matters as well
07-17-2019, 10:53 AM | #4 |
A 2004 wont have a 12v A/C request wire, so in order to use that wire they included in the harness you would most likely need the factory GM pressure sensor. It would be easier to just run the VA as a stand alone unit, but tie the high fan relay (if you have both high and low) to the trinary switch so that it will turn the fans on when needed.
07-17-2019, 11:56 AM | #5 | |
1964 Chevy C10 - Gen IV 5.3 Restomod http://67-72chevytrucks.com/vboard/s...d.php?t=768632 1968 GMC C15 - Gen III 6.0 Restomod http://67-72chevytrucks.com/vboard/s...d.php?t=772047 1969 Chevy C10 - Restoration http://67-72chevytrucks.com/vboard/s...d.php?t=809184 1978 Chevy Scottsdale K20 1993 Chevy C1500 - 5.3/T56 swapped 2008 Silverado Duramax |
07-17-2019, 01:12 PM | #6 | |
07-17-2019, 01:17 PM | #7 | |
07-17-2019, 06:54 PM | #8 |
Thanks for the info. I was just reading through another LSX Swaps thread posted today and eventually got to another thread with a lot of info on 3-relay wiring. I don't plan on buying my VA system for awhile after wiring everything, but I do want to go the 3-relay setup with my fans and I'm going to look at my dad's wiring closer to see what the shop did.
