Old 05-03-2007, 10:34 AM   #1
55dude
55dude's Avatar
drug home a new project!
dudes! found a 54' burb on craigslist and went to look damm! wouldn't ya know it i bought it. guy was selling it because he found out his girlfriend was pregnant. well he was asking $450 but ended up up getting it for $300 bucks. 235 turns by hand going to see if it will start probably going to use a 250/350 combo i happen to have stashed. here are some pic's.
55dude is offline   Reply With Quote
Old 05-03-2007, 11:47 AM   #2
CAL 58 GMC
CAL 58 GMC's Avatar
Re: drug home a new project!
Other then a fender, I would say, WOW what a find!!
CAL 58 GMC is offline   Reply With Quote
Old 05-03-2007, 11:50 AM   #3
Kabwe
Certified Car Nut
Kabwe's Avatar
That is a really great find. I love those old burbs.
Kabwe is offline   Reply With Quote
Old 05-03-2007, 12:24 PM   #4
jsbgump
Gone Fishing
jsbgump's Avatar
Nice find
68 Chevy Short Fleetside LSX Swap Under Way 3.73 posi 2.5/4 drop Frame of resto has been started
2022 Hyundai Tucson Limited
2019 Chevy Traverse Redline Edition Wifes Ride
Build Thread
http://67-72chevytrucks.com/vboard/s...=1#post3483616
jsbgump is offline   Reply With Quote
Old 05-03-2007, 12:31 PM   #5
55dude
55dude's Avatar
other fender is in the back with the wrong year grill 47'-53) and running board. need to find a 54'-55' grille. anyone? should find out next week if it runs or not.
Old 05-03-2007, 03:22 PM   #6
Daniel U
Daniel U's Avatar
They do sell new ones for $650-ish. My mom may be getting one. What's left of her OEM one is rough, but you could paint it. If they get a new one and are interested in selling it, I'll let you know.
Mom's 1954 (TBI 5.7/700R4/14 bolt 4:10) 5 Chevrolet window 3/4 ton long bed Pick up
build thread ->http://www.67-72chevytrucks.com/vboa...d.php?t=228674
My 1954 (TPI 5.7/700R4/10 bolt 3:73) Chevrolet 5 window 1/2 ton short bed Pick up
build thread->http://67-72chevytrucks.com/vboard/s...3&goto=newpost
1960 (400/T350/?) Apache 10 short/fleet side-big window
1973 (TPI 5.7/700R4/14 bolt 4:10 w DANA 60 front) Chevrolet Cheyenne 4X4
2013 (Vortec 5.3/6-speed 6L90 automatic) Sierra LT CREW CAB
Doing my part to warm the globe
Daniel U is offline   Reply With Quote
Old 05-09-2007, 01:58 PM   #7
BobTheTrucker
BobTheTrucker's Avatar
Looks like a fun project. My experience with 235 ( I have 5 of them ) is if they turn over real easy by hand. More than likely the lifters are not pumped up and the valves are not opening. If that's the case and it's not the pistons and rings. She may start right up, if not. Then all you may need to get her started is a clean oil pan and screen so oil pressure can pump up the lifters and let the valves open and close properly.
Most didn't come with oil filters and sludge builds up over the years, even if they changed the oil. It usually stops up the oil pump screen. Low oil pressure no compression. Also this will some times burn the crank and you can't get good oil pressure to get those valves working with burnt bearings on the cam or crank.
1955 Chevy truck ( SOLD )
1955 3/4 ton parts truck.
1957 Chevy truck
1995 S10 Chevy truck
1999 ext cab Chevy truck, w/1998 body style. (for parts)
1964 Honda 90
2003 Ultra Classic Harley
BobTheTrucker is offline   Reply With Quote
Old 05-09-2007, 02:08 PM   #8
BobTheTrucker
You have a 54, I'm not sure but I don't think it has an oil pump. ??? If it doesn't it has a splash system. So good crank and cam bearings or even more important.
1957 Chevy truck
1964 Honda 90
Old 05-09-2007, 02:16 PM   #9
BobTheTrucker
Another thing if she don't start right up is to pull the dist. out and use a drill with a long cut off straight slot screw driver end on it to pump up oil pressure. Of course you checked to see if you have fuel and fire first.
1957 Chevy truck
1964 Honda 90
Old 05-11-2007, 10:02 AM   #10
55dude
55dude's Avatar
the dizzy will be pulled because i have a test HEI that i have just for starting 235's. they need to be reprimed after they sit and why mess with a bunch of old stuff roll in some fresh plugs and HEI saves lots of time.
Old 05-11-2007, 04:47 PM   #11
solidaxel
solidaxel's Avatar
What type of HEI are you using for the I-6
53 TuTone Extended Cab 350 4-Spd 3:08 (SOLD)
53 Chevy Moldy pearl green ZZ-4 4L60E 9" 3:25
55 GMC 1st Black Mll (ZZ4) ZZ6 TKO 600 5 sp 3:73
62 Solidaxle Corvette Roman Red (327
340hp 4spd 3:36) C4 & C5 suspension tube chassis
LS 3 4L70E
65 Corvette Coupe 327 350hp 4spd 4:11
78 Black Silverado SWB (350/350) 5.3 & 4L60E 3:42
2000 S-Type 3.0 (wife cruiser)
2003 GMC SCSB 5.3 4L60E 3:42
solidaxel is offline   Reply With Quote
Old 05-11-2007, 04:54 PM   #12
texascowboy593
texascowboy593's Avatar
Wow...Very nice! Here's one I saw last weekend to give you a little inspiration... 1st pic is a little vague...He's behind me going down the road!
"The rays of light thru the Shiner Bock bottle make me wanna turn the key and put down the throttle...and get lost down 35" - Jason Boland
www.YouTube.com/user/593Films - Watch My Videos!
1977 Silverado K10
2014 Dodge Durango (Wife-mobile)
2008 Dodge Ram Lone Star Edition (Daily driver)
texascowboy593 is offline   Reply With Quote
Old 05-22-2007, 07:18 AM   #13
55dude
55dude's Avatar
latest update on the project: scored a 54' grille,front valance,left front fender for under $200 bucks. also scored a running 61' chevy apache truck for $100 bucks today and drove it home. 235/3spd that's going in the 54' i will post some pic's soon.
