mini truck racer
Enclosed trailer
Looking at enclosed trailers for obvious reasons . Probably be buying a used one in 24' .
How many use them and what size and brand do you have .
1949 5-window 1969 Camaro 1976 Chevy Luv yellow 1978 Chevy Luv Blue 1976 Chevy Luv Black 1979 Firebird Flooded in Harvey 1999 F350 Dually 2005 GMC Sierra 4.8 RCSB 2014 Explorer (wifes) My build :http://67-72chevytrucks.com/vboard/s...d.php?t=399148 Build #2: http://67-72chevytrucks.com/vboard/s...d.php?t=653583 |
~Rest In Peace~
Re: Enclosed trailer
im looking for 20 footer hopefully my tundra will be able to tow it ,most used one i see price range is 4 to 5 k .24 ft up 9k
is it fast ? it has a lighting bolt donut? B___H please, I can remove 90% of your so called "beauty" with a kleenex |
mini truck racer
I looked at a 20 footer that had a 48" side door and i could have gotten the truck and golf cart in it with the golf cart going in the side door , but the 3500# axles are what kept me from buying it . 7000# capacity minus the trailer and accessaries = 3000-3300# . Trailer had refrig , A/C , cabinets in front , microwave . My truck weighs 2800ish and the cart is probably another 600 or so . Im over loaded and haven't even added spare slicks or nitrous bottles , cooler , canopy , BBQ pit etc .
Im looking at a 24 footer with 7000# axles . Maybe over kill , but the bearings and brakes are bigger and the tires are rated higher 14000# rating mins 4000 for the trailer gives you plenty of room for equipment . The 6 lug or 5200# axles would probably be ok also .
It's Better With Nitro
I've had my Haulmark Elite II 24' Race Trailer for 14 years. I've relied on it big time, running Div 7 and 6 Super Gas/Street for 12 of those years - averaging 15K+ miles per season. If I were to buy a new trailer, it would be the Haulmark Edge Pro Series in a 28' length.
1963 C-10: Deluxe-optioned cab, shortbed, fleetside Pontiac 462 ci, Kauffman D-Port alum. heads 4L80E, narrowed sheetmetal Ford 9-inch Tubular front and rear suspension Custom 6-piston front disc and 4-piston rear disc brakes |
mini truck racer
Very nice . Heard the Haulmarks are nice trailers .
Thanks. I had a Pace Shadow before the Haulmark, but the Pace developed cracks at the upper rear corners above the rear drop down door - they were less than sympathetic and didn't do anything to resolve the issue. I think they have since corrected that design fault, but at the time, Haulmark had already engineered their trailer for that issue with the billet aluminum corner pieces.
Registered Truck Offender
If you don't want to winch the car (truck) in and out.. look into ones with a full side door. The JimGlo I bought is ausome,,but all steel frame / aluminum skin, floor inner skin, insulated,, nice but JimGlo is pretty proud of them. The 24' "HotRod suite" is just under $20k but with 4wheel electric brakes, electric door, hydraulic toung jack, winch on rear ramp/door, electric remote release for side doors ,, it's a nice piece and airflow through it with side and doors open makes it 'tolerable shade' in the summer day races.
http://www.small-block-chevy.com/trailer.htm
Still playin with trucks, even at my age! When you're dead, it's only a problem for the people around you, because you don't know you're dead. .....It's kinda the same when your STUPID. I just did my taxes and reviewed my SS statement. Thanks to the current administration it looks like I will only have to work till noon on the day of my funeral. |
mini truck racer
Im planning on the side doors . Im also wanting the tolerable shade . Plus i have a 6700 watt gen so a 15K a/c will also go on the roof .
I have no idea what your tow rig is , but you may want to also look into either a stacker or a toy hauler.. You get the live in features and large amount of work space.. Toy haulers can be bought cheap these days.. used that is ..
My old trailer was a haulmark and loved it.. I just wanted to not have a RV and a trailer. Bought a sand piper ( made by forest river) had no issues with that either.. But the weight is an issue and a larger tow rig is needed. I had a 40 foot toy hauler and it had 18 feet to front cabinet or work area.
62 long box with a little SBC ![]() http://www.67-72chevytrucks.com/vboa...d.php?t=510631 http://good-times.webshots.com/album/561798652HdwqzG |
mini truck racer
I have the brand F 7.3 powerstroke . My storage space is limited to 26' so i need to stay under that . The living quarters would be nice , but i have a nice cot i use for hunting .
well was worth a shot.. If you are traveling this may come as a shock but I looked real hard at a over the road tractor and trailer.. Easy to get plated for non com use and the price of some of the as a done set is not as much as I had in my dodge and toy hauler.. Again intended use is the key word here..
Storage space is the norm find a friend that has the room HA HA for just a trailer I have had nothing but the best luck with the haulmark units.. Cannot say that about the others.. Price tag drew me to them but the cost of ownership , made me sell them.. I went through two sets of wheel bearings on one road trip.. Always fun in 110 temps installing new bearings on the side of the road..
mini truck racer
Put a deposit down on a 2002 Horton hauler 24 foot 4 foot side doors on both sides 7K axles and 16 " wheels .
![]() Join Date: Jun 2006
I would look around at: www.racingjunk.com they have both trailers and toterhomes. The great thing about the toter homes are, even though they look like big rigs, its because of all the false windows allow you to drive them without a change of license and they are registered as motorhomes.
I have owned several enclosed trailers and used to sell them. I wouldn't buy one with 3500 lb axles either. The 5200 and 6k axles are six lug and the 3500's are 5. I prefer a 28 or larger but my truck is longer also.
Kevin Special Thanks to All who have helped on the TRUCK! My Pass Time Show http://s129.photobucket.com/albums/p...Chapter1-0.mp4 So Far my best Times are: Motor only: 6.44 1/8 @ 104.13 10.39 1/4 @ 125.83 Nitrous Times: 5.785 1/8 @ 118.65 with a 1.336 60ft 9.168 1/4 @ 142.58 with a 250 shot dead out of the hole! |
#15 |
I just read where you put a deposit on the trailer with the 7k axles. The sixteens are a definate plus. You can get a much better tire in a 16 than a fifteen.
#16 |
mini truck racer
Yes it is 7K 8-lug with BFG commercial grade tires on it . I would have bought a 28 footer or more except i only have storage space for a 24 . 28 would have ment removal of a tree my wife would not allow . My lot layout is sort of odd and storage payment is not an option . I would stay open trailer vs storage fees .
#17 | |
Be cautious in how you store / lock it down. Your part of the world is just as bad as mine for trailers full of tools and race cars disappearing across the border before you ever know it's gone. I core-holed the concrete drive and put a recessed lug to chain the trailer tounge DOWN to. then added a wireless motion sensor inside the trailer tht is part of the home security. It trips and me and Mr Colt are out the side door before they could ever set it down on the ball hitch! BTW,, CONGRATS on the purchase. It's so nice to pull in after a nite race and just lock things down. Worry about unloading after a good nights sleep!!
#18 | |
mini truck racer
I intend to tie a "lojack" type tracker to the truck and trailer , of coarse the nessesary locks and of coarse Mr.colt . Most of my neighbors are home or retired and home during the day also . Looking into insurance for truck , cart and trailer
#19 |
mini truck racer
Finally got it home and began to do some work on it . Ordering new aluminum cabinets for the front and did some trading for an A roof top a/c unit . Even the wife is pretty happy with it .
#20 |
~Rest In Peace~
i just want one that my truck will fit in and i can use my toyota tundra to haul it to shows ,i think the 20 ft is 3500 ax .
#21 |
RIP Mr Ron
![]() Join Date: Dec 2005
Nice set up. I love my 24' but health issues forced me to get rid of my Nova and some of my race only things. But I'm making a comeback of sorts and still have my 78 Camero and a 355 roller motor so I may not be down for the count. Stay tuned...........
Ron (Mr Round Tuit) ![]() Be kinder than necessary, for everyone you meet is fighting some kind of battle TN Message Forum TN Facebook Group SETN Truck Show My Photobucket |
#22 | |
Ron, sorry about the health and here is to a speedy recovery ![]() ![]() PS.. Just giving you a bad time..
------Motor---------------Bottle 60'---1.53---------------1.41 1/8---6.58 @ 105.92----5.87 @ 118.41 1/4---10.38 @ 126.97----9.24 @ 142.49 |
#23 |
Hotrod,
Nice buy, if you don't mind me asking, what did it run you? I wouldn't mind finding an enclosed someday soon. But I need to buy another house with a shop first.
#24 |
mini truck racer
I gave $4750 for the trailer as you see it with the torsion or equalizer hitch . With the cabinets and A/C unit i will have about $6K in it . I feel like if the enclosed doesnt work out for me i can recover most of it at that cost . I spent quite a while looking at alot of junk .
#25 |
That's cheaper than I thought it was going to be.. Congrats!
