02-18-2015, 12:39 AM | #1 |
New wiring harness questions
Looking at buying a new wiring harness for my 1970 chevy c10 swb. Just wondering if anyone has done this or has any recommendations on brands to use or not to use. Is it difficult? Any pictures or just knowledge on this would be appreciated. Thank you
2005 Chevy Silverado 2500HD- DD 1970 Chevy C10 SWB 454 BBC- Work In Progress |
02-18-2015, 12:49 AM | #2 |
Re: New wiring harness questions
Not difficult, but time consuming. Just get everything out of your way. Drop the column, pull the cluster, glove box, everything. The new harness will pretty much fall into place. It's very gratifying when it's installed, knowing all those cut and bare wires are gone, everything makes connection and it looks good.
I don't have a recomendation on suppliers, but I would start with a supporter of the board. Larry
02-18-2015, 12:59 AM | #3 |
Thank you. I will try starting there
02-18-2015, 05:00 AM | #4 |
Please note that you must be a supporting member to post classified items. This includes but is not limited to What Its Worth, Want To Buy, Want To Trade, and For Sale. Please consider supporting the forum by subscribing. Further information on the subscription levels available are located here
If you need any further assistance with that please contact any Admin for help. Last edited by leddzepp; 02-18-2015 at 04:51 PM. |
02-18-2015, 02:03 PM | #5 | ||
"I ain't nobody, dork."
I got my engine wire harness and front light wire harness from Wes at Classic Heartbeat (site sponsor). The are made by M&H Auto Wire. Completely plug and play with all the correct factor clips, plugs and connectors. Correct harness "tape" and even the plastic channels that the wires run through on the firewall and along the front radiator support.
Great product and easy to install. Gary
02-18-2015, 02:45 PM | #6 |
Can't speak for my c-10 yet but i used American Autowire on my 68 camaro and it was a pretty complete kit. Came with all terminals i needed, good schematic layout, color coated and labled wires. Just took time to terminate and put connectors on. The harness had plenty of wire, as far as length of the wires, also.
Chad '68 Camaro - 408 sbc, Muncie m20, 9' rear, hotchkis supsension (aka Betty) '72 C10 - pretty much all stock as far as i know, for right now anyways (aka Charlie) |
02-18-2015, 02:57 PM | #7 |
I'm in the middle of a complete ground-up resto on my 70 C-10. I went with the American Autowire 510089. Not the cheapest way to go, but I couldn't be happier with it. High quality product and the instructions are making it much easier than I thought. But it is time consuming to do it right.
02-18-2015, 04:53 PM | #8 |
Moderator
M and H or American Autowire. Identical to factory harness.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed. 1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck. RIP ElJay RIP 67ChevyRedneck RIP Grumpy Old Man |
02-18-2015, 05:53 PM | #9 |
Thanks for the info guys. Haven't got a chance to check any of these out yet. Just finished pulling the cab off, motor and tranny. Just get nervous pulling all them wires off (hate wiring) and possibly not remembering where or what they go to. I can follow a wiring diagram pretty good though so I think I should be fine. Thanks again
02-18-2015, 06:59 PM | #10 |
Label each connector in place and take pictures of each and every one. The less you are into wiring the more important this is.
As to harnesses buy the best and most finished you can afford. A drop in exact reproduction is the best bet on a stock truck. Most of the time if you plan ahead, upgrades like an HEI or gauges can be easily accommodated in the new harness. "Universal"s often end up worse than the original harness being replaced.
Thanks, Tim * VIN/Model Decoders * Power Team Charts (engine/transmission/gear ratio) * Post Your Pickup SPID ** Blazer SPID ** Suburban/Panel SPID * RTFM ... Read The Factory Manuals... download 'em here Highlanders ** Do you have a 1972 Plaid Pickup? ** Plaid Blazer ** Plaid Suburban |
02-18-2015, 07:50 PM | #11 |
Any opinions on Painless wiring kits? I checked out the American auto wire and all I could find was pieces not the whole kit
02-19-2015, 11:08 AM | #12 | ||||
Like I stated before I got my harnesses from Classic Heartbeat. He has all the wire harnesses listed with pics. But if you got M&H's website, they have every single bit of wiring for these trucks. Just no pics. Gary
02-18-2015, 08:09 PM | #13 |
look at GMC pauls, he has everything
Mike 72 C-10 Cheyenne off frame resto and Upgraded to 4 wheel disk, Tilt, Dakota Digital Dash / Rear slider. 421 SBC / TH350 3000RPM Stall Progression Ignition /Holley 750 DP/3:73 gear Eaton Limited Slip unit / 2 1/2 exhaust glasspacks |
02-19-2015, 11:14 AM | #14 |
I'm running an American Autowire harness as well. I hate running electricity, but this kit was easy to use. It had all the oem fasteners, plenty of extra wire so that I could tuck and hide as well. Highly recommend going with them.
02-19-2015, 12:07 PM | #15 |
Here's a pic of a full kit and video from American Auto Wire. I found this because I am in the market for rewire this summer.
http://www.americanautowire.com/shop...-1969-72-truck
White K20 |
02-19-2015, 12:15 PM | #16 |
laidbackrestorations is a supporting board member and gave me a good quote on an american wire kit. you can find them in vendor section
02-19-2015, 01:03 PM | #17 |
X2^^^ I just recieved my kit from laidbackrestorations great price and shipped right out.
Mark 1972 C10 SWB LS1/T56 6 speed trans/4:56 posi with 5.5"-7" static drop/Boss 338 Wheels 18"x20" My build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=424609. My first start up http://youtu.be/R899YQ1OcjU |
