09-01-2015, 12:29 AM | #1 |
Cut Dash, Wasn't me!
This is how my dash came. Do any of you have a link to a bracket or something to fill the single DIN hole with a headunit?
09-01-2015, 06:25 AM | #2 |
Re: Cut Dash, Wasn't me!
When you buy an aftermarket stereo, it come with a metal sleeve that goes in there. Then the stereo slides into the sleeve. Those little "V" shaped cutouts get bent up behind the dash to hold the sleeve in place. You can get just the sleeve from Amazon or your local stereo shop if you already have a head unit.
1969 C20 Suburban "Rez Dog" Rebuild America one testicle at a time. US Army 1977-1979 12B Combat Engineer US Navy 1979-1983 Gunners Mate Guns (GMG) NRA Life Member Unrestrained Children in back seats cause Accidents. Unrestrained Accidents in back seats cause Children. |
09-01-2015, 08:13 AM | #3 | |
09-03-2015, 03:30 PM | #4 |
there will also be a stud on the back of your stereo head unit for a hanger strap
be sure to use it
cool, an ogre smiley Ogre's 58 Truk build how to put your truck year and build thread into your signature shop air compressor timer |
09-06-2015, 08:59 AM | #5 |
Like Ogre said, use that strap that comes with it, these trucks can shake a CD to death, plus it helps with the grounding. Your hole looks about the right size, at least it isn't all butchered up like my 69 i had. The PO of it carved it all up and stuck a Chrysler infinity with a CD out of a 98 Caravan in it. Took me a month of fabricating, and painting to fill the hole to put in a single din CD stereo.
09-29-2015, 01:05 PM | #6 | |
I have the same issue on 68. The problem I see is the knob holes that are left a little bit don't always tuck behind a new radio face. WHY WOULD ANYONE GO THROUGH ALL THAT WORK TO CUT UP THAT DASH? |
09-29-2015, 03:00 PM | #7 |
They sell a plate to go behind it, but every time I see one they are billet and like $60.... I am not into shiny things anyways. I would buy one for $10 if they made em that cheap.
10-02-2015, 05:51 PM | #8 | |
Yeah I agree, I was thinking of making a plate out of an old street sign or license plate. Unless I can find a donor dash cheap. Posted via Mobile Device |
10-21-2015, 07:49 AM | #9 |
I think you want something like this so you have some options for fitting a head unit:
Amazon.com: Metra 89-30-0900 Din Trim Rings, 4... If the link does not work, go to Amazon and search for this item: Metra 89-30-0900 Din Trim Rings, 4 Pack |
10-21-2015, 07:57 AM | #10 |
Hey Galdo, the link doesn't work.
01-13-2016, 12:03 PM | #11 |
man I wish I saw this thread before I spent $100 on that billet din plate
01-13-2016, 01:39 PM | #12 |
Tip of the day for stereo installer-types. If you install a stereo and get spark-plug static....pull the radio and use a copper braided strap from the nut on the back of the radio to a good groud. You have now created what is called a Faraday cage. You have turned the radio case into a grounded part of the car, and the braid cancels out unwanted noise from the car electrical system.
01-13-2016, 01:45 PM | #13 |
Nice idea on the copper braided strap, never knew that, thanks.
Mudman.
1987 Green n Green machine. 5.0 4spd std. 7" lift w 35's. |
