Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Electrical > Truck Audio
Old 09-01-2015, 12:29 AM   #1
drewbert41
drewbert41's Avatar
Cut Dash, Wasn't me!
This is how my dash came. Do any of you have a link to a bracket or something to fill the single DIN hole with a headunit?
drewbert41 is offline   Reply With Quote
Old 09-01-2015, 06:25 AM   #2
ranger danger
ranger danger's Avatar
Re: Cut Dash, Wasn't me!
When you buy an aftermarket stereo, it come with a metal sleeve that goes in there. Then the stereo slides into the sleeve. Those little "V" shaped cutouts get bent up behind the dash to hold the sleeve in place. You can get just the sleeve from Amazon or your local stereo shop if you already have a head unit.
1969 C20 Suburban "Rez Dog"
Rebuild America one testicle at a time.
US Army 1977-1979 12B Combat Engineer
US Navy 1979-1983 Gunners Mate Guns (GMG)
NRA Life Member
Unrestrained Children in back seats cause Accidents.
Unrestrained Accidents in back seats cause Children.
ranger danger is offline   Reply With Quote
Old 09-01-2015, 08:13 AM   #3
drewbert41
drewbert41's Avatar
Thanks, hopefully the cut was accurate enough.
Old 09-03-2015, 03:30 PM   #4
_Ogre
_Ogre's Avatar
there will also be a stud on the back of your stereo head unit for a hanger strap
be sure to use it
shop air compressor timer
Old 09-06-2015, 08:59 AM   #5
Dannyboy1966
Dannyboy1966's Avatar
Like Ogre said, use that strap that comes with it, these trucks can shake a CD to death, plus it helps with the grounding. Your hole looks about the right size, at least it isn't all butchered up like my 69 i had. The PO of it carved it all up and stuck a Chrysler infinity with a CD out of a 98 Caravan in it. Took me a month of fabricating, and painting to fill the hole to put in a single din CD stereo.
Dannyboy1966 is offline   Reply With Quote
Old 09-29-2015, 01:05 PM   #6
mywifestruck
I have the same issue on 68. The problem I see is the knob holes that are left a little bit don't always tuck behind a new radio face. WHY WOULD ANYONE GO THROUGH ALL THAT WORK TO CUT UP THAT DASH?
mywifestruck is offline   Reply With Quote
Old 09-29-2015, 03:00 PM   #7
drewbert41
drewbert41's Avatar
They sell a plate to go behind it, but every time I see one they are billet and like $60.... I am not into shiny things anyways. I would buy one for $10 if they made em that cheap.
Old 10-02-2015, 05:51 PM   #8
mywifestruck
Yeah I agree, I was thinking of making a plate out of an old street sign or license plate. Unless I can find a donor dash cheap.
Old 10-21-2015, 07:49 AM   #9
Galdo76
Galdo76's Avatar
I think you want something like this so you have some options for fitting a head unit:
Amazon.com: Metra 89-30-0900 Din Trim Rings, 4... Amazon.com: Metra 89-30-0900 Din Trim Rings, 4...
If the link does not work, go to Amazon and search for this item: Metra 89-30-0900 Din Trim Rings, 4 Pack
Galdo76 is offline   Reply With Quote
Old 10-21-2015, 07:57 AM   #10
Steve Cole
Hey Galdo, the link doesn't work.
Steve Cole is offline   Reply With Quote
Old 10-21-2015, 08:00 AM   #11
Steve Cole
Never mind,
just saw the other part of your post about if the link doesn't work.
Old 10-21-2015, 08:04 AM   #12
Galdo76
Galdo76's Avatar
Sorry about that. Not sure why that didn't work. Here's another site that has a bunch of options for you:
http://www.sonicelectronix.com/cat_i...rim-rings.html
Old 01-13-2016, 12:03 PM   #13
XwalkerX
man I wish I saw this thread before I spent $100 on that billet din plate
XwalkerX is offline   Reply With Quote
Old 01-13-2016, 01:39 PM   #14
Daze57
Daze57's Avatar
Tip of the day for stereo installer-types. If you install a stereo and get spark-plug static....pull the radio and use a copper braided strap from the nut on the back of the radio to a good groud. You have now created what is called a Faraday cage. You have turned the radio case into a grounded part of the car, and the braid cancels out unwanted noise from the car electrical system.
Daze57 is offline   Reply With Quote
Old 01-13-2016, 01:45 PM   #15
mud.man.rj
mud.man.rj's Avatar
Nice idea on the copper braided strap, never knew that, thanks.
Mudman.
1987 Green n Green machine.
5.0 4spd std.
7" lift w 35's.
mud.man.rj is offline   Reply With Quote
