09-22-2021, 10:32 AM | #1 |
'67 GMC high beam headlight placement
Do the high beams go inside or outside? Getting ready to go out and put them in. Hamburger to the winner🏆
Hey man 67 GMC Short Stepside 400 small block, turbo 350. Build thread:http://67-72chevytrucks.com/vboard/s...d.php?t=650603 |
09-22-2021, 10:33 AM | #2 |
Re: '67 GMC high beam headlight placement
High beams inside.
Rephrase, High and Low outside, High only inside |
09-22-2021, 11:23 AM | #3 |
Gotcha. Thank you sir. Next time I'm in Cheyenne I'll get you a burger 🍔. I usually stay at F.E. Warren being retired Army.
09-22-2021, 12:03 PM | #4 |
09-22-2021, 01:54 PM | #5 |
Just wondering.
Is that a law or just how they did things?
I got a bench seat baby, you don't have to sit over there. |
09-22-2021, 02:25 PM | #6 |
I have heard that it was a regulation of some kind that came about in the 1940's when cars started to become noticeably wider. On dark narrow roads it was important to know if the oncoming vehicle was a Model A or a 41 Cadillac to prevent collisions. The manufacturers were required have the headlight within a certain distance from the side of the car.
If you look at cars from the 20's & 30's you can see headlight placement is all over the place.
Thanks to Bob and Jeanie and everyone else at Superior Performance for all their great help. RIP Bob Parks. 1967 Burban (the WMB),1988 S10 Blazer (the Stink10 II),1969 GTO (the Goat), 1970 Javelin, 1952 F2 Ford OHC six 4X4, 29 Model A, 72 Firebird (the DBP Bird). 85 Alfa Romeo If it breaks I didn't want it in the first place The WMB repair thread http://67-72chevytrucks.com/vboard/s...d.php?t=698377 |
09-22-2021, 04:53 PM | #7 |
Probably some combination. There was always weirdness, like CJ7s. The headlight is no where near the outside of the vehicle.
Whenever dual headlights were one above they other, they were mostly bright/dim on top, and bright only on the bottom. I used to switch em just to be troublesome. Trivia: In Wyoming the law still states you have to dim within 500 feet of approaching a car, 300 feet when approaching from behind. With today's headlights, those distances are pretty close and bright. See how that works when you are following a cop at 301 feet. And my personal favorite, it being technically illegal to drive with just your parking lights on. |
09-22-2021, 04:58 PM | #8 |
Fed Reg:
On the front, each headlamp providing the lower beam, at the same height, 1 on each side of the vertical centerline, each headlamp providing the upper beam, at the same height, 1 on each side of the vertical center-line, as far apart as practicable. See also S7 |
09-23-2021, 01:19 AM | #9 |
All four buckets may be different. INside, OUTside and R and L.
Even the orientation (clocking) has to be correct. When you mount the buckets trial fit the bulb to be sure it is correctly orientated. Just went through this on another Chevy. I am making the assumption the trucks are the same as passenger cars. BTW you have the only RH drive truck I have ever seen. LOL. Or the picture was reversed. It's a personal preference but I would paint the transmission cooler black. BTW I am not far from you, Longview WA. Close enough to take you up on the burger! LOL Last edited by Accelo; 09-23-2021 at 01:25 AM. |
09-23-2021, 06:36 AM | #10 | |
