Old 09-22-2021, 10:32 AM   #1
Oregon 1967 GMC
Oregon 1967 GMC's Avatar
'67 GMC high beam headlight placement
Do the high beams go inside or outside? Getting ready to go out and put them in. Hamburger to the winner🏆
Hey man
67 GMC Short Stepside 400 small block, turbo 350. Build thread:http://67-72chevytrucks.com/vboard/s...d.php?t=650603
Oregon 1967 GMC is offline   Reply With Quote
Old 09-22-2021, 10:33 AM   #2
geunther
geunther's Avatar
Re: '67 GMC high beam headlight placement
High beams inside.
Rephrase, High and Low outside, High only inside
geunther is offline   Reply With Quote
Old 09-22-2021, 11:23 AM   #3
Oregon 1967 GMC
Originally Posted by geunther View Post
High beams inside.
Gotcha. Thank you sir. Next time I'm in Cheyenne I'll get you a burger 🍔. I usually stay at F.E. Warren being retired Army.
Hey man
Old 09-22-2021, 12:03 PM   #4
geunther
geunther's Avatar
I know just the place. Not necessary, but Id take you up on it.
Old 09-22-2021, 01:54 PM   #5
purple gas
Just wondering.
Is that a law or just how they did things?
I got a bench seat baby, you don't have to sit over there.
purple gas is offline   Reply With Quote
Old 09-22-2021, 02:25 PM   #6
HO455
HO455's Avatar
I have heard that it was a regulation of some kind that came about in the 1940's when cars started to become noticeably wider. On dark narrow roads it was important to know if the oncoming vehicle was a Model A or a 41 Cadillac to prevent collisions. The manufacturers were required have the headlight within a certain distance from the side of the car.
If you look at cars from the 20's & 30's you can see headlight placement is all over the place.
RIP Bob Parks.
Old 09-22-2021, 04:53 PM   #7
geunther
geunther's Avatar
Originally Posted by purple gas View Post
Just wondering.
Probably some combination. There was always weirdness, like CJ7s. The headlight is no where near the outside of the vehicle.
Whenever dual headlights were one above they other, they were mostly bright/dim on top, and bright only on the bottom. I used to switch em just to be troublesome.
Trivia: In Wyoming the law still states you have to dim within 500 feet of approaching a car, 300 feet when approaching from behind. With today's headlights, those distances are pretty close and bright. See how that works when you are following a cop at 301 feet.
And my personal favorite, it being technically illegal to drive with just your parking lights on.
Old 09-22-2021, 04:58 PM   #8
geunther
geunther's Avatar
Just wondering.
Fed Reg:
On the front, each headlamp providing the lower beam, at the same height, 1 on each side of the vertical centerline, each headlamp providing the upper beam, at the same height, 1 on each side of the vertical center-line, as far apart as practicable. See also S7
Old 09-23-2021, 12:24 AM   #9
'68OrangeSunshine
'68OrangeSunshine's Avatar
Jeeps still have 1930s-style headlamp placement. Now, they're required to mount the yellow running lights more outboard, but from a distance, they're stiil closer than they appear.
Old 09-23-2021, 01:19 AM   #10
Accelo
Accelo's Avatar
All four buckets may be different. INside, OUTside and R and L.
Even the orientation (clocking) has to be correct.
When you mount the buckets trial fit the bulb to be sure it is correctly orientated.
Just went through this on another Chevy.
I am making the assumption the trucks are the same as passenger cars.
BTW you have the only RH drive truck I have ever seen. LOL.
Or the picture was reversed.
It's a personal preference but I would paint the transmission cooler black.
BTW I am not far from you, Longview WA. Close enough to take you up on the burger! LOL
Accelo is offline   Reply With Quote
Old 09-23-2021, 06:36 AM   #11
Oregon 1967 GMC
That's weird how the picture reversed!? Didn't notice. Good advice 👍 Thanks. When I get it drivable I'll come through with a Killer Burger that's what's in the photo.
Hey man
