Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > Info Center > FAQ Truck Tech > 67-72
Closed Thread
Old 03-23-2005, 03:22 PM   #1
Dan72cst
Dan72cst's Avatar
Tilt Column
Can someone explain or post a link on How to convert a Van column to a truck column please?
I paged through the FAQ's section and found the one on "Neutral Safety on Van Column" but I need to know how to do everything else. Thanks!
Marysville, WA (Dan72cst@hotmail.com)
72 4wd Blazer CST 350/350
72 4wd Chevy LWB 350/350
68 2wd Chevy LWB 327/400
Dan72cst is offline
Old 03-23-2005, 04:10 PM   #2
neonlarry
neonlarry's Avatar
What else? Just get adaptor plug and compress intermediate a couple of inchs. It should fit right in.
70 C/10 Light Red 350/TH350, HEI, Duals w/40 series Flows, 91 seat, LED taillights
99 Pontiac S/C GTP, SLP Ram Air hood, GMPP Konis & springs
95 Neon ACR, MP PCM, AFX UDP, 3.0 CAI
neonlarry is offline
Old 03-23-2005, 05:36 PM   #3
Bob Moore
Most people bend the shift linkage arm to allow the the rubber collar, lower gasket, and metal mounting collar to go on from the bottom. Then bend the linkage arm back for proper shifting.
67 C-20 LWB, tilt, speed alert,
vac, 454, T400
67 C-10 SWB, factory air with
more to follow
Bob Moore is offline
Old 03-23-2005, 07:13 PM   #4
72MARIO
72MARIO's Avatar
Just bend the shift arm to slide the van gaskets off and slide your truck parts on. You can remove the wire from the flat plug and put them in you half moon plug. I just did mine it's pretty easy. Should take 2 hours or so.
1968 Suburban numbers matching all original truck now equipped with 6.0/4L80 on Accuair
http://67-72chevytrucks.com/vboard/s...d.php?t=625017
1967 C/20 6.0/4L80 Roofing Truck
1990 V2500 Suburban "Plow Truck"
2005 TAHOE DD
72MARIO is offline
Old 03-23-2005, 07:48 PM   #5
pjmoreland
pjmoreland's Avatar
Also the back-up light connector is a different shape. You can use the connector housing from a van. The connector pins from your truck should pop right in without any cutting or soldering.
pjmoreland is offline
Old 03-25-2005, 10:07 AM   #6
Dan72cst
Dan72cst's Avatar
What does it take or what do you mean by "Compress intermediate shaft" ?????
Dan72cst is offline
Old 03-25-2005, 10:14 AM   #7
Solver
Solver's Avatar
You need to compress shaft so part 1 will slide easily in and out of part 2 .then reinstall column with this shaft on end. then push or pull on steering wheel to position as desired. Then tighten everything back up. If you have further questions please let me know as I have done 7 of these now.
  • 1972 Cheyenne Super 20 LWB-Blue
  • 1972 Cheyenne Super 10 LWB-Black
  • 1972 Cheyenne Super 10 LWB-Red
  • 1972 Cheyenne Super 10 LWB-green
  • 1972 GMC 4x4 LWB-White
  • 1971 Cheyenne 10 LWB-Ochre
  • 1971 Cheyenne 20 Longhorn-Copper
  • 1971 Cheyenne 20 Longhorn-Black
  • 1969 Custom 10 LWB-lt blue
  • 1968 GMC 3/4 ton-green
  • 1968 1/2 ton swb stepside-silver
  • 1967 Chevrolet CST 10 LWB-green
  • 1967 Chevrolet custom 20 LWB-Maroon
Solver is offline
Old 03-25-2005, 11:16 AM   #8
shifty
Questionable
shifty's Avatar
Do you hafta drill out or pop out any rivets or fasteners to get it to telescope like that?
If I've got anything up for grabs, it'll be here: 7-hole gauge cluster for a 67-72 p/u FREE (link)
I can't check the forum daily. If I don't reply to you within 24 hours, drop me a PM! I'm (hopefully) still alive and will reply faster to a PM.
shifty is offline
Old 03-25-2005, 05:36 PM   #9
Solver
Solver's Avatar
Some you can just wack with a sledge gently and they will start to move then lube them well. others I have drilled out the 2 plastic pins(actually 4-- I drill from both sides) Makes it easier to collapse and get it to start telescope without them.
Solver is offline
Old 03-25-2005, 11:03 PM   #10
Tim240Z
Tim240Z's Avatar
Lots of info in the archives using "tilt column" as the search key.
Here is a good one:
http://67-72chevytrucks.com/vboard/s...ht=tilt+column
1972 Suburban C20
454/TH700R4, eaton-corporate 4.10 (looking for 3.7)
Sold: 71 Cheyenne 20
Installed a 99 5.7L L31/4L60E from Suburban 1500 (2005)
Tim240Z is offline
Old 03-26-2005, 12:02 PM   #11
purple gas
Form my shaft, I didn't drill it, I just whacked it on the floor. I held the " inner" shaft and banged straight down hitting the "rag joint" part on the floor. Once it started to collapse I gradually shortened it till it fit just right.
I got a bench seat baby, you don't have to sit over there.
purple gas is offline
Closed Thread
