08-14-2002, 12:36 PM | #1 |
Hot Rods For Life
Does your LWB fit in your garage??
If you have one. My wife and I are building a new house and I am a little concerned about my 68 fitting in the garage. Surely it will right? I mean I know it will once I start to tear it down but I want to do some landscaping and build a shed at the new house before I tear down a perfectly good running truck. I guess I really just need to go and measure once they pour the foundation.
08-14-2002, 12:48 PM | #2 |
I should think so. Some garages are bigger than others, but I've never seen one a LWB won't fit in. In fact, the '92 (XCab LWB) even fits the smaller ones i've been in (barely!).
Ben '68 Chevy C10 Custom LWB 327/TH400 2nd owner '16 GMC Sierra 1500 SLE Dblcab 4wd 5.3 |
08-14-2002, 12:54 PM | #3 |
Hot Rods For Life
That's what I was thinking. I mean I have seen those ext cabs in there. I'm just freaking out I guess. It would be an "Eye Sore" to other in the neighborhood I'm sure, if it sat in the driveway.
08-14-2002, 12:58 PM | #4 |
Better to think of it now, though. Would be a bummer (understatement) to build a house and not be able to fit your project in the garage!
As for being an eyesore, that all depends on what neighborhood you're in! hehe
08-14-2002, 01:03 PM | #5 |
Designated Grumpy Old Man
If you have the time and money build your garage at least 26 feet deep and each stall 12 feet wide so you have some working room. And have your trusses engineered so you can store parts up in the attic above the garage.
Never let the truth get in the way of a good story 71 Chev 1/2 ton 4X4 LWB Fleetside SOLD http://67-72chevytrucks.com/vboard/s...d.php?t=361222 http://www.youtube.com/watch?v=1LgREwtDfaA 68 Chev 1 ton flat bed http://www.youtube.com/watch?v=0bO8szzlD4A 56 Chev Handyman Wagon http://www.youtube.com/watch?v=9y-6ddpBTkM http://www.youtube.com/watch?v=lbLzZ7zY8wA 56 Chev Belair http://67-72chevytrucks.com/vboard/s...d.php?t=410667 http://www.youtube.com/watch?v=xoW0Ei7ZNIg |
08-14-2002, 01:18 PM | #6 |
Mine fits and thats with the washer & dryer in front of it and room to load the dryer. If the washer and dryer were not there I would say that I have maybe 3 or 4 feet of room in the back if I pulled it all the way to the wall.
08-14-2002, 01:27 PM | #7 |
Dude...I'm a CHICK
Watch your measurements...... My burb dont fit in the garage to the house we just moved into Shes about 4 inches too long.
~*~*~*~*~*~*~*~*~*~*~*~*~* "The unexamined life is not worth living" -Socrates ~*~*~*~*~*~*~*~*~*~*~*~*~* '71 GMC Suburban 4x4 |
08-14-2002, 01:51 PM | #8 |
Southern but in Ohio!!!!
I have to put 16 inch rims on digger so she will clear a 7' door, & I havent put the suspesion lift on yet......& theirs a good reason for that! HE,HE
1969 C/10 3/4 ton 4x4 longbed custom, frame made from a 79 1972 custom-10 half/ton longbed 1980 1/2 ton 4x4 all original 350/350/205 with air Eaton,Oh rebelryder@hotmail.com |
08-14-2002, 02:18 PM | #9 |
English Chevy Owner
About as much chance of fitting my truck in my garage as I have of winning the 100 metres at the next olympics! But then American truck into standard size British garage just doesn't go. Even if I manged to just squeeze her in I would have to climb out the rear slider... perhaps that's what they're really for!
Phil '67 C10 long fleet. 350/TH350, 4 bbl Carter, K&N, Dual exhaust, loads of stuff coming soon 2001 S10 Blazer Daily Driver, bone stock 4 door 4x4 with manual transmission |
08-14-2002, 02:32 PM | #10 |
Psycho-billy Member
My garage is 24' deep and my truck fits with a few feet to spare.
26' on the depth would be the minimum that I would go with though.........I didn't have enough room to go that big
'72 C-10 350 w/Lunati Voodoo cam (207*/213*, .437/.454), Performer intake, 625 Road Demon Jr. and Hooker headers. Support your community, support yourself. Buy local, buy American (or Canadian). |
08-14-2002, 03:23 PM | #11 |
When I had my house built I had the garage made 24X24 with two 10' wide doors in the front. There is plenty of room. I have a couple of Snap-On boxes in front of my LWB an if I push the truck to the door there is at least 3' between the truck and the tool boxes.
1970 CST/10 402,700R4,3:73 posi,AC,PS,PB,TLT,PW,Buckets with heaters |
08-14-2002, 03:37 PM | #12 |
My present garage is 24x20, with my shop attached another 10x24, overall 24x30. My longhorn fits just fine, but it's only been in there one night. Getting bids now for my new garage, it'll be 28 x 48 with two overhead doors. then the old one becomes my shop! Can't wait! But wife says she gets a pool, too.
Bill - Tucson, AZ 47 Chevrolet 2 dr sedan 56 Chevrolet 210 2 dr sedan 66 Chevrolet Malibu 2 dr 4 speed 71 Chevrolet C30 Longhorn 86 Chevrolet Monte Carlo SS (Sold) 01 Chevrolet Tahoe IM - BUSTERWIVE@aol.com |
08-14-2002, 04:42 PM | #13 |
Mine fits...coarse, the wife hates it when I do a burnout in the garage.....
08-14-2002, 04:44 PM | #14 | |
Hot Rods For Life
EDIT: I jusr re-read, 3 inches to spare. |
08-14-2002, 05:01 PM | #15 |
I can open the draws and still pas between them and the truck. And im no shrimp. 6' 230lbs. I can use a floor jack to jack the front of the truck up and the handle just misses the boxes
08-14-2002, 07:43 PM | #16 |
My winter storage garage is a tight fit!
I have to air down the tires to get the lights on top of the cab to slide under, and turn in the side mirrors to make her fit. Not to mention lengthwise is tight also. This is a stock truck too!
Jeff '69 GMC K2500 LWB, '74 350/SM465/Rockwell T-221, cnD44/ffD60, 3.73 gears, 31" BFG's (originally had 305ci V-6) '05 VW golf '84 HD Sportster XLX '68 GMC K2500 parts beast |
08-14-2002, 09:17 PM | #17 |
Real Deep...
Too...much..stuff
Get my truck in the garage?
Sure could. As long as I remove the F-350 Crew Cab Super Duty, the F-150 lightning, the '76 GMC Jimmy and the '84 Monte Carlo SS it fits with no problem. I need a bigger garage...
1970 GMC C10 (Deep Purple) 383/700-R4 Mass Modifications 1976 GMC K5 Jimmy (Big Blue) 400/TH350 Coming soon to a drive-in near you... We have done So Much with So Little for So Long.. We are now qualified to do Anything with Nothing. |
08-14-2002, 09:38 PM | #18 |
my c 30 longhorn just barely fits......
08-14-2002, 11:25 PM | #19 |
Just here to help
I work on alot of newer houses and the biggest thing i see is to small of garages on them.I would make sure that you have at least a 26'er, and another thing is you will want a taller door then 7'.Never know when you might move up to a lifted 4x4.....lol
08-15-2002, 12:03 AM | #20 |
My attached garage is the same depth as my house...33' (x24)which makes sense since I see a lot of houses with a "small" room behind the garage that is supposed to pass as a family room. Why not make the entire end a garage?! That way you have tons of room for toolboxes, hoists, engine stands, benches AND room to pull the engine out if needed. Just my opinion.
08-15-2002, 12:27 AM | #21 |
I use a wooden shed/garage for winter storage, it's about 18'x11' and the truck fits barely end to end. There is no room to spare! Luckly the garage doors swing out like barn doors. A 26 footer would be nice, maybe my next house!
Nelson 1970 C10 350 Auto. A/C not Working |
