Old 12-10-2005, 04:10 PM   #1
ponjohn
5.7 enough.....
Is a 99 Suburban (3/4 ton) 350 enough for towing a car/trailer 1/2 dozen times/year? It is an open trailer with a 3600lb car.
been looking at big blocks but found a loaded super clean 99 Sub with 92k miles for 7k$. Leather, barn doors, good rubber, 4x4 SLT.
Thanks-
John
ponjohn is offline   Reply With Quote
Old 12-10-2005, 05:14 PM   #2
70short/step
70short/step's Avatar
Re: 5.7 enough.....
That sounds like an excellent tow vehicle for what you need. Unless you are towing uphill the whole way the 5.7 will be enough. If you are buying it for just a tow vehicle and will only use it for that you may want to look to a big block but I dont think you will be disapointed in that 99!
For every person with a spark of genius, There are a hundred with ignition trouble.
70 Short/Step
70short/step is offline   Reply With Quote
Old 12-10-2005, 08:24 PM   #3
ponjohn
Re: 5.7 enough.....
in a nutshell it will sit and be used as a 3rd vehicle for dump runs, transport our 4 shepherds around, towing, trips to carlisle, swap meets and other utility purposes.
what gear ratio was standard on the small blocks? Were 4.10's available? If so what code on option list in glove box.
john
Old 12-13-2005, 11:48 AM   #4
Eyegore
What Hump?
Eyegore's Avatar
Re: 5.7 enough.....
Its enough. I have 99 2wd burb, I've towed a 26 foot travel trailer for a couple of years. Oh, I have also passed semi's going uphill with no trouble at all.
Lil red 86 c-10
99 Sub
78 Camper Special w/ 454
Eyegore is offline   Reply With Quote
Old 01-05-2006, 02:23 AM   #5
68gmcdually
68gmcdually's Avatar
Re: 5.7 enough.....
I run a 5.7 in my 3500 and it is plenty, mind you it doesn't measure up to the diesel but it still pulls amazingly.
James Bellwood
1968 930 Extend-A-Cab Dually 5.7l, 5 speed,
68gmcdually is offline   Reply With Quote
