Old 11-23-2005, 11:07 PM   #101
Musclerodz
Re: Custom Chassis with canti setup
That is a waaay better setup than the first go round. Kudos to you on your fabrication skills. That should hold up forever and have an excellent ride quality.
Mike
Mike Redpath
Musclerodz is offline   Reply With Quote
Old 12-05-2005, 12:09 AM   #102
cornutz
All Praise RANDY!!
cornutz's Avatar
Hey Jr.--- any more pics to update us on? I know you have been busy burnin' the hours on this project...
cornutz is offline   Reply With Quote
Old 12-05-2005, 04:27 PM   #103
valleycustom
Yeah, I'll take some more tonight. I need to have this thing on the road by the first goodguys in 06.
Please become a site supporting vendor to advertise a business in your signature. you can do so here
valleycustom is offline   Reply With Quote
Old 12-07-2005, 12:01 AM   #104
Damian
Damian's Avatar
Dam thats some nice work you have done. I go down to Modesto ever weekend so I would like to see all the work in person and maybe talk to you about bagging my tuck. So let me know. Thanks
Damian is offline   Reply With Quote
Old 12-07-2005, 01:25 AM   #105
dwcsr
Hollister Road Co.
dwcsr's Avatar
valleycustom,
I'm curious as to why you used a tapered roller bearing rather than a sealed axial ball bearing in that pivot. Its real nice work by the way.
Old 12-11-2005, 11:51 PM   #106
cornutz
All Praise RANDY!!
cornutz's Avatar
Come on Jr... I know that you must have already changed about 8 things already and have beefed up a ton more since the last set of pics... give us an update my man!
Old 12-12-2005, 08:24 PM   #107
valleycustom
Originally Posted by dwcsr
valleycustom,
I used these because they can handle the side load pressure that is created when I bolt the unit together and it also keeps the shaft were it needs to be. There are bolts on each end of the shaft. When they are tightened the sleeves press against the bearings and keeps all the parts in place with the frame. Normal sealed bearings I feel can't handle the side pressures created when I bolt everything up. I could have placed a shim in between two axial bearings but I figured if any parts needed to be replaced this setup would be eaiser for a person to get parts.
Old 12-12-2005, 08:31 PM   #108
valleycustom
LOL cough cough cough... I've been trying to fight off a case of Pneumonia for over a week. As soon as I get back on my feet a will get some more pictures. I'm also waiting on Modesto steel to cut out the new arms I designed for the canti setup. I hate having to outsource work to other people, but it would have taken me forever to cut these out with my plasma and clean everything up.
Old 12-13-2005, 01:30 AM   #109
70short/step
70short/step's Avatar
Hey Jr. If the weather is good this Saturday and you have time, I still need to come over cause I want you to make me those "bullets" for my lower shock mounts. Let me know here or I can just call ya I guess. Oh yeah, Just so ya dont forget........
24th All American Get-Together
March 25, 26, 2006
Pleasanton, CA
Need to see that chassis rolling by then!
For every person with a spark of genius, There are a hundred with ignition trouble.
70 Short/Step
70short/step is offline   Reply With Quote
Old 12-13-2005, 10:15 PM   #110
FRENCHBLUE72
PROJECT 7DEUCE
FRENCHBLUE72's Avatar
Nice damn work....
GO BIG GREEN GO DUCKS
MEMBER #6377
Project "7DEUCE"
FRENCHBLUE72 is offline   Reply With Quote
Old 12-29-2005, 12:51 AM   #111
valleycustom
Well here are some more pictures. I had some new brackets laser cut for the canti. It took over 2 weeks for this to get finished. So that set me back. I'm still on for the goodguys show in March. I'll be driving this there if my life depends on it. The body might not look to nice but it will be on the road.
Old 12-29-2005, 12:59 AM   #112
valleycustom
I also had the driveline made by inland empire driveline. They did a nice job.
Old 12-29-2005, 01:52 AM   #113
SCOTI
SCOTI's Avatar
Very trick.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 12-29-2005, 10:27 AM   #114
Izzy
Trucker.
Izzy's Avatar
Sweet.
Izzy is offline   Reply With Quote
Old 12-29-2005, 05:36 PM   #115
FRENCHBLUE72
PROJECT 7DEUCE
Its gonna be a shame to put sheetmetal on the chassis....
MEMBER #6377
Project "7DEUCE"
Old 01-06-2006, 03:54 PM   #116
bshelton
Pictures-Some other work done by Valley Customs. I figure its ok to post these pics because its a Chevrolet..its driven hard. Why do I know? Drag racing tickets and impounded car for 30 days to prove it. This was set up with 4 link, bagged, 350/350, 9" rear. We also moved the tranny tunnel up so driveline wouldnt hit, bunch of trick stuff. It will lay the frame on the ground and when you mat it..it hooks up big time. This guy knows what hes doing, he proved it on this Belair. Enjoy!
bshelton is offline   Reply With Quote
Old 01-06-2006, 03:55 PM   #117
72CSTC5
72CSTC5's Avatar
Looks like Vegas on that suspension, "just a roll of dimes stacked on top of each other" gorgeous welding by the way. You need to teach some of the big name builders how to build chassis.
72CSTC5 is offline   Reply With Quote
Old 01-06-2006, 04:09 PM   #118
bshelton
couple more bel-air pics
Old 01-06-2006, 06:43 PM   #119
72CSTC5
72CSTC5's Avatar
Dude that 56 is so bad looking in Black. Love your car.
Old 01-06-2006, 08:23 PM   #120
bshelton
right on..thanks!
Old 01-06-2006, 08:35 PM   #121
fastbagged68
fastbagged68's Avatar
Bshelton....what else is done to the chassis. My buddy has a Nomad we are going to do. There are no floors in the car now so we might body drop it. What size tires are on that bel air? Is that the stock front end? Help me out!
fastbagged68 is offline   Reply With Quote
Old 01-06-2006, 09:03 PM   #122
bshelton
fastbagged68 brother,
The chasis has a c-notch kit from jegs modified alot, front is pro-fab bag setup using the stock a-arms, all hand built by VC. No body drop, just new body bushings and hardware. wheels were 17X7 front 17X8 rear with standard offset. One mistake I made was that the rear end is 9", it really is 8" from a Granada; the thing about the 8" is its really narrow so you can tuck everything pretty easily in the back. The tires 255/55/17 and 245/55/17..I think..sold the car to build a c-10 truck.
For advice on your friends nomad:
the kid from Valley Customs built this suspension, motor mounts, tranny mount-(tucked, he should manufacter these), entire floor hump redone so you could drive it on the ground as hard as you want without the driveline hitting the bottom of the floor, a cool pro fab sheetmetal floorpanel to match the C notch..... all 3 years ago. This means he was 13. Bottom line, he is a Badass fabricator and his dad is an engineer, so its genetics + skill. I say see him for advice/insight on any project. Bill S Modesto CA-
Old 01-06-2006, 09:23 PM   #123
72CSTC5
72CSTC5's Avatar
bshelton, this kid is 16YRS OLD!!!!!!!!!!!!
Old 01-06-2006, 09:26 PM   #124
valleycustom
Dude I'm 26... He's joking. He owns the C-10 that I am working on. LOL The notch for the bel-air was from ***************** with over the axle setup. I made the front components. The center tunnel was moved up 2-3" to clear the driveline, and I custom made the 4 link.
Old 01-06-2006, 11:41 PM   #125
cornutz
All Praise RANDY!!
cornutz's Avatar
I heard that this Jr guy has six fingers on each hand and that is what enables him to achieve these awesome welds!!!!
Also, I heard his dad used to drink water out of a well near a hick town called Waterford... you see.... there might be something in the water that caused the spermies to, well, you know...the rest.
Bill G
