Old 11-26-2005, 01:54 AM   #26
cypress TX 72
Saving one 72 at a time!!
cypress TX 72's Avatar
Re: progress pictures
All of us "frame off" guys know thats a lot of work, clean and precise...
good work
cypress TX 72 is offline   Reply With Quote
Old 11-26-2005, 01:59 AM   #27
djracer
djracer's Avatar
this was his first try at this type of box!
Kevin
Special Thanks to All who have helped on the TRUCK!
My Pass Time Show http://s129.photobucket.com/albums/p...Chapter1-0.mp4
So Far my best Times are:
Motor only:
6.44 1/8 @ 104.13
10.39 1/4 @ 125.83
Nitrous Times:
5.785 1/8 @ 118.65 with a 1.336 60ft
9.168 1/4 @ 142.58 with a 250 shot dead out of the hole!
djracer is offline   Reply With Quote
Old 11-26-2005, 05:13 AM   #28
tnblazerk5
User #12137
tnblazerk5's Avatar
it all looks great to me that box looks really good i thought about takin a old gas tank and doin sumthing like that with it
tnblazerk5 is offline   Reply With Quote
Old 11-26-2005, 07:50 AM   #29
LSGarage
LSGarage's Avatar
Gosh I'm old. I always thought two 6x9's and a killer 30amp output, am/fm with presets was the cat's meow.
67 GMC 4x4, 305 V-6, 4-spd
86 S-10, 2.8 2WD LWB
01 Suburban (family hauler)
13 Honda CRV (wife's wheels)
03 Malibu (daughter’s car)
LSGarage is offline   Reply With Quote
Old 11-26-2005, 10:40 AM   #30
mike nutt
69fatmotor
mike nutt's Avatar
Originally Posted by FRENCHBLUE72
What does flipping the crossmember like that do? I have never heard of doing that. Very nice progress so far keep us posted..
in the pics below there are two different trucks both with ece's 6" drop kits the top pic is my with the x-member flipped , the second is not flipped ,as you can see in the pictures on my truck the axle end of the trailing arm is alot closer to level. don"t know if it really needs it ,i just think it looks better.
mike nutt is offline   Reply With Quote
Old 11-26-2005, 11:37 AM   #31
Hart_Rod
Hart_Rod's Avatar
Nice job on the truck. I guess I'm blind, because I'm not seeing the difference in the trailing arms. Did you C-notch? Did you use shock relocators?
Rob
Hart_Rod is offline   Reply With Quote
Old 11-26-2005, 11:48 AM   #32
FRENCHBLUE72
PROJECT 7DEUCE
FRENCHBLUE72's Avatar
O.K. I see the difference looks like it would help out the pinnion angle and eliminate any of the vibrations that may come from such a drastic drop.. If its not too much trouble could you show some pics of your pinnion angle as it is now?? Thanks Luke,
GO BIG GREEN GO DUCKS
MEMBER #6377
Project "7DEUCE"
FRENCHBLUE72 is offline   Reply With Quote
Old 11-26-2005, 12:32 PM   #33
roj2323
i wonder if you could just flip the brackets on the crossmember instead of fliping the whole crossmember? you would probably have to exchange left for right but i think it would work.
ondrew
roj2323 is offline   Reply With Quote
Old 11-26-2005, 03:40 PM   #34
Hart_Rod
Hart_Rod's Avatar
I finally get it. I thought you meant the trailing arms were flipped upside down, now I see you were talking about the crossmember.
R
Old 11-26-2005, 08:04 PM   #35
mike nutt
69fatmotor
mike nutt's Avatar
frenchblue72, i don't have any pics of my pinion angle, on my truck i'm using a later model rearend , i had to cut the axle perchs off and i'm using a new set of perchs from ece, my pion won't be set until the truck is almost complete and pretty much at finished ride higth , but it does help if you were stock axle because of the severe pinion angle. i could have got by with out flipping the x-member and just corrected the pinion angle before welding the perchs on. just a note , the x-member work was done with the cab and bed off of the frame
Old 11-27-2005, 01:52 PM   #36
junkyarddog1956
junkyarddog1956's Avatar
Lookin good Mike ... nice job ... jyd
69 Chev C-10 ... painted and ready to reassemble ( for sale )
82 Custom Deluxe ( have parts to restore )
junkyarddog1956 is offline   Reply With Quote
Old 11-27-2005, 02:12 PM   #37
GMan69
GMan69's Avatar
Gonna be one awesome ride when you're done!!
George Morgan
Hernando, MS
'69 C-10 swb fleetside
'72 GMC swb Stepside
GMan69 is offline   Reply With Quote
Old 11-27-2005, 02:32 PM   #38
muddpile
muddpile's Avatar
Wow does that look good! I really like the sub box in your old truck too! I can't wait to see what else you have planned for this one.
muddpile is offline   Reply With Quote
Old 11-27-2005, 02:42 PM   #39
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Top notch fab worh there.
On that speaker box... what did you make that out of?
Old 11-29-2005, 06:36 PM   #40
Metmanice
Metmanice's Avatar
That speaker box is great. I have drawn out the plan for one like it in my '67 but that is a while off. I wanted to put the plan down to remind me (got a lot moving around in the head now
'67 C10 SWB Frame off (and smiling)
Metmanice is offline   Reply With Quote
Old 01-08-2006, 09:01 PM   #41
mike nutt
69fatmotor
mike nutt's Avatar
heres a few pictures of the cab after bodywork and primer.
Old 01-08-2006, 09:06 PM   #42
krue
Designated A-hole!
krue's Avatar
Very nice.
"If it ain't broke, fix it 'til it is!"
Being stupid ain't illegal.
We're Still Debt Free Except for the House!!!
www.daveramsey.com
70 GMC SWB Stepside project "Green Booger" soon to be 6.0l/4l80e
93 S-10 "Poppaw's Truck"
krue is offline   Reply With Quote
Old 01-08-2006, 09:19 PM   #43
phantom dually
Project92 SWB stepside
phantom dually's Avatar
looks great
92 C1500 stepside 496 Stroker Competiton Engineering Ladder bars/QA1 coilovers. Dana 60 rear with 4.10 gear and posi. Bonspeed Palisade 20x12 in rear w/335/30/20 and 20x8.5 front w/245/40/20. 5/8 drop with Belltech springs/DJM spindles/drop shocks. WWS Progress thread http://67-72chevytrucks.com/vboard/s...d.php?t=140448
phantom dually is offline   Reply With Quote
Old 01-08-2006, 09:24 PM   #44
mike nutt
69fatmotor
mike nutt's Avatar
and heres some of the latest progress on the late model bed i will be using. the bed was shortend by 4 1/2" . the rear step was shaved and the front step was cut off and raised up to line up with cab. i liked the look of the bed sitting lower on the truck instead of raising the bed to line up the bottom of the bed.
Old 01-08-2006, 09:47 PM   #45
mike nutt
69fatmotor
mike nutt's Avatar
more bed pics
Old 01-08-2006, 09:51 PM   #46
project76
project76's Avatar
looks great, do you have any plans to mod the wheel wells on the bed to match the fenders?
Brandon
project 67 swb bagged on 20" Coddingtons
project76 is offline   Reply With Quote
Old 01-08-2006, 10:02 PM   #47
mike nutt
69fatmotor
mike nutt's Avatar
looked at it alot and don't think i will, but not 100% sure
Old 01-09-2006, 12:22 PM   #48
djracer
djracer's Avatar
Lookin Good Mike! I need you to work on mine so huury up on yours!
Kevin
Motor only:
6.44 1/8 @ 104.13
10.39 1/4 @ 125.83
Nitrous Times:
Old 01-09-2006, 02:49 PM   #49
1Ton
1Ton's Avatar
Very nice truck. Top notch fab work.
Support your local search and rescue team.... GET LOST!
Originally Posted by DURRTY
if some is good
more is better
too much ought to be enough........
1Ton is offline   Reply With Quote
Old 01-09-2006, 06:47 PM   #50
lolife99
67-72 parts collector,…
lolife99's Avatar
Hey Mike,... Just a quick question. How did you Z the frame and not have to drop the front frame horns by the core support? Is the frame only Z'ed behind the engine? Great looking truck!
Keith
Convert to disc brakes.
