Old 09-05-2006, 09:32 PM   #1
1950 PA Truck
1950 Chevy 3600 Project
I am starting a project on a chevy 3600 pickup. I still have the split rim wheels on it. Does anyone have a good source for wheels for this vehicle or should I find tubes for the split rims?
Also the gas tank has alot of stuff in it - is it recommended to replace the thing or does these cleaners and sealers work.
1950 PA Truck is offline   Reply With Quote
Old 09-22-2006, 03:35 PM   #2
mylow53
mylow53's Avatar
Re: 1950 Chevy 3600 Project
if i remember right innertubes are the only way an older split rim will work. i can't say the tank can be cleanedout my 53 sat for 10 years and the varnish was like putty. i dought a cleaner could go thru that, but who knows what wonder chemical are out there
Greg
mylow53 is offline   Reply With Quote
Old 09-22-2006, 07:46 PM   #3
Kager67
what knocking sound?
Kager67's Avatar
I would just get a new one. They are only 125 bucks at brothers right now. If you replace it you'll never have to worry about it again. JMHO
Kager67 is offline   Reply With Quote
Old 09-22-2006, 11:21 PM   #4
70shortnphat
"See the U.S.A....."
70shortnphat's Avatar
I have a 1949 3600 with origional two piece rims and like them alot.Dont forget to buy tube liners also.
1970 short bed fleetside
1949 all origional chevy 3600
1974 camaro
Richmond , Texas(just S.W.of Houston)
70shortnphat is offline   Reply With Quote
Old 09-23-2006, 12:32 AM   #5
dwcsr
Hollister Road Co.
dwcsr's Avatar
One word of caution. Don't ever inflate a split rim that is not in a safety cage. They outlawed those rims because they can kill you if they are not put together and infalted correctly. Especially if they are old and have been rusty around the lock ring. Get it done at a tire shop.
Old 09-23-2006, 05:54 AM   #6
entourageguy
Yellow truck club
entourageguy's Avatar
Ive got a friend with the facial scars to back that statment ... ouch
Brian
Brian ......
My hub garage address
http://www.hubgarage.com/mygarage/59apache
I gue$$ everything has it'$ price
ALL GONE NOW
59 Chev Apache
PRAISE THE LOWERED
350 700r lokar shifter
power MII front end, shockwaves
tilt, 4 wheel discs
4-link and bags
10 bolt limited
entourageguy is offline   Reply With Quote
Old 10-21-2006, 07:16 PM   #7
LBflyer1
I'm glad I found your string while trying to learn more before I start working on my 1949 3600. It is a very original, low-mile truck, and I want to avoid changing it, because it looks great on the original style tires and wheels, but I am hoping someone out there knows a good source for correct tires (type and size), and where to find the tubes and liners. Thanks
LBflyer1 is offline   Reply With Quote
Old 10-21-2006, 07:26 PM   #8
LBflyer1
Since I'm new here, I just wanted to make sure my pic downloaded - thanks
Old 10-23-2006, 12:44 PM   #9
mylow53
mylow53's Avatar
speaking of split rims i had a friend in highschool that had one let go on him. he was in a wheelchair for life. i saw an example of how powerfull they are on tv they could lift a compact car 8 feet off the ground with the explosion... not worth the original look if you ask me i choose walking....
Greg
1953 chevy 1/2 ton 5 window, chevy 350 330 horse 700r tranz, lowering spindels mustang 2 frount. ford 9", airbags on 4 corners . purchased in 1983 for $325 while in high school
http://67-72chevytrucks.com/vboard/s...=215079&page=5
