Old 01-10-2007, 07:01 PM   #26
pcmcobra
pcmcobra's Avatar
Re: Impala SS/Caprice rear disc brake BRACKETS
me needs some for a 10 bolt
pcmcobra is offline   Reply With Quote
Old 01-10-2007, 08:02 PM   #27
eric72
sent you a pm
eric72 is offline   Reply With Quote
Old 01-10-2007, 08:42 PM   #28
glock35ipsc
Next project: 1970 K10
glock35ipsc's Avatar
Just so everyone knows, since a TON of people have been asking, I will be working on coming up with a bracket for the 93-9? Camaro calipers that have an e-brake. No promise as to when they will be ready, but my guess is about a month.
Bob
1970 Chevy K10 LWB "Goldie" 350/TH350 next project!!
1981 Chevy C10 LWB 355/TH350 - My son's truck
LS SWAP FORUM! Tons of LS swap info here!
PLEASE CLICK HERE TO SUPPORT THE GREATEST BOARD ON THE NET!
CLICK HERE FOR THE FAQ INDEX by KRUE
glock35ipsc is offline   Reply With Quote
Old 01-10-2007, 09:05 PM   #29
pcmcobra
pcmcobra's Avatar
10 bolt anytime soon?
Old 01-10-2007, 09:44 PM   #30
Ram-Man
Ram-Man's Avatar
here is a pic of them mounted. Glock I may want a couple of the adapters too.
Ram-Man is offline   Reply With Quote
Old 01-10-2007, 09:48 PM   #31
glock35ipsc
Thanks for the pics, Ram-Man! My supplier informed me today that they are out of stock, and won't have the adapters for 5-7 days. I'll let you know when they come in.
pcmcobra - When things slow down, I will see what I can do. It may have to be a one-off set, but I will see what I can come up with after things get settled down here.
Bob
Old 01-10-2007, 10:22 PM   #32
pcmcobra
pcmcobra's Avatar
sweet,
thx a bunch.
Will give me a little time to recoup from dropping some $ on my wheels and drop kit.
John
Old 01-10-2007, 11:29 PM   #33
powell72
powell72's Avatar
As glock said, I have confirmed that the Impala brakes will fit behind a Rally wheel. Glock's brackets are a steal considering trying to make these things yourself.
Chris
74 Custom Deluxe SWB 350/350/3.73’s
99 2wd Silverado RCSB 5.3/4L60/3.90’s
http://www.classictrucks.com/feature...short_bed.html
powell72 is offline   Reply With Quote
Old 01-10-2007, 11:35 PM   #34
byrd
Union Electrician
byrd's Avatar
About how much total for the swap, including the parts needed? I would like to have an idea before I jump on board. Are you able to retain an ebrake with this style? about the oem brakets needed, can you buy them or is it bone yard only?
Randy
69 Custom-10 SWB FLEETSIDE 350/350 TH Dropped 3.5/5.5"
Help support the board->HERE
Board vendors -> Vendors list
Zip:40272
Big Sandy Survivor...
We cannot choose the way we die, but we can choose the way we live
If you can't fix it with a hammer, you've got an electrical problem.
I think Congressmen should wear uniforms like NASCAR drivers so we could identify their corporate sponsors
byrd is offline   Reply With Quote
Old 01-10-2007, 11:55 PM   #35
Alvin
Never Done?
Alvin's Avatar
Well it depends on if you're going to use all brand-new parts or not. I'm looking at ~$450 using rebuilt calipers, new caliper brackets (they are available), slotted & cross-drilled rotors, the CPP prop valve, new hoses, banjo bolts, etc.
I've not seen anything about an e-brake with this set-up.
Ethel - The Legend Continues...
Ethel has been sold.
Alvin is offline   Reply With Quote
Old 01-11-2007, 12:05 AM   #36
glock35ipsc
Randy
Alvin is pretty much spot-on. I have figured around $350-$450 with new parts. There is a core on the calipers, so look on eBay and boneyards for a cheap set to use for cores. Or if they are in good enough shape you can rebuild them. I do include a list of items needed along with part numbers and where to go. The Impala/Caprice does not use an e-brake on the caliper. And the OEM bracket is available at most all parts houses. I included a part number from www.rockauto.com because they have the best price, but I know the Parts America (Checker/Schucks/Kragen) also stocks them.
If you really want an e-brake, I have a set of Camaro calipers soming to use for designing a bracket for them too. They do have on integral e-brake.
Bob
Old 01-11-2007, 12:13 AM   #37
byrd
Union Electrician
byrd's Avatar
OK, I will wait on the camaro style.
Thanks,
Randy
Zip:40272
Old 01-11-2007, 01:16 AM   #38
glock35ipsc
Randy, I'm hoping I can have something within a month.
Bob
Old 01-11-2007, 02:03 PM   #39
jkade
jkade's Avatar
Size:  44.9 KBHere are the powder coated brackets and calipers. The brackets didn't turn out as nice as the calipers but I didn't sand them either.
jkade is offline   Reply With Quote
Old 01-11-2007, 02:14 PM   #40
glock35ipsc
Sweet!! They look great! You may need to sand a little powder coating off on the inside of the large hole, as the first batch were fitting kind snug to the axle flange. Just an FYI.
Bob
Old 01-11-2007, 09:12 PM   #41
Mixup
Bob put me on the list for the Camaro brackets.
Ken svr1113@cox.net
1980 Chevy Shortbed Pickup
1969 Z28 engine
Turbo 350
Mixup is offline   Reply With Quote
Old 01-11-2007, 09:41 PM   #42
glock35ipsc
Your on, Ken!
Bob
Old 01-11-2007, 09:50 PM   #43
jkade
jkade's Avatar
Thanks for the heads up. Maybe I will get around to putting them on in the next couple of months.
Old 01-11-2007, 09:57 PM   #44
glock35ipsc
LOL, lets hope it's sooner than that!
Bob
Old 01-11-2007, 11:34 PM   #45
Col Clank
any chance of designing a bracket for a 10 bolt rear end.
Col Clank is offline   Reply With Quote
Old 01-12-2007, 09:58 AM   #46
glock35ipsc
Like I said earlier in this thread, when things slow down a little, I will look into making a couple sets.
Bob
Old 01-12-2007, 01:39 PM   #47
p-low
p-low's Avatar
count me in if you have 10 bolt plates made preferrably with the camaro caliper...thanks, taylor
p-low is offline   Reply With Quote
Old 01-12-2007, 01:54 PM   #48
glock35ipsc
Gotcha!
Bob
Old 01-12-2007, 08:26 PM   #49
53burb
53burb's Avatar
Only the distribution valve needs replacing & not the master cylinder?? I thought you would need a disc/disc m/c instead of a drum/drum....
53burb is offline   Reply With Quote
Old 01-12-2007, 08:37 PM   #50
glock35ipsc
I was under the impression you could run the same m/c (and some board members have). Drum/drum brakes require an equal volume of fluid since the wheel cylinders are almost equal, and the disc/disc would be very similar too.
See post's #12 and #13:
http://67-72chevytrucks.com/vboard/s...ghlight=impala
Bob
