01-31-2007, 06:00 PM | #126 |
Re: PO has me PO'd
Thanks Kurt for the compliments. Yeah it's been a long enjoyable road. The only areas that I didn't touch were under the seats and above the seam line on the cowl. Thank goodness that was rust free, I have seen some trucks with rust in that area and it looks like a PITA to fix.
You've gotta room to talk, all the work that you have done to the Big Blue One. I remember when you first bought it. I think you said it was good to go the way it was. haha You -Greg and Rab will be looking at me on the bottom side of the black trails, as I don't plan on creasing any of these great looking Goodmark panels....... well, for awhile anyway.
Semper Fi...Uncle Sam, you da man All parts offered to help are free, unless otherwise noted Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training SAFETY FIRST AS usual, off topic They say your mind goes second, can't remember the first Jim Last edited by jaros44sr; 02-01-2007 at 06:03 PM. |
01-31-2007, 06:43 PM | #127 |
Re: PO has me PO'd
Here's some more
This template is wrong, so don't use as a guide!!!
Semper Fi...Uncle Sam, you da man All parts offered to help are free, unless otherwise noted Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training SAFETY FIRST AS usual, off topic They say your mind goes second, can't remember the first Jim Last edited by jaros44sr; 02-02-2007 at 07:57 AM. |
01-31-2007, 06:48 PM | #128 |
The LuvShack Garage
Re: PO has me PO'd
Nice work, scares me watching yours, I couldn't do that, keep it going
01-31-2007, 07:06 PM | #129 | |
Re: PO has me PO'd
These chassis, cab setups are so stable they don't move!! Working on monocoque cars, like E-type Jags, now that is scary. Talk about door sag, the tires were on the ground and you couldn't open the doors because they were dragging.
01-31-2007, 07:22 PM | #130 |
Re: PO has me PO'd
Jaros. Nice work. I was wondering why the patch panel you made for the kneewall to the B pillar was not solid.(It has that cut out) If you look at the pic the VT posted you see the piece hanging down without the rocker. I am currently doing the same thing that you are. Mine was for the most part intact.
01-31-2007, 08:04 PM | #131 | |
Re: PO has me PO'd
But your right it should come out farther to catch more of the 'B' post patch. Any progress pics of yours???
Semper Fi...Uncle Sam, you da man All parts offered to help are free, unless otherwise noted Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training SAFETY FIRST AS usual, off topic They say your mind goes second, can't remember the first Jim Last edited by jaros44sr; 01-31-2007 at 08:11 PM. |
01-31-2007, 09:14 PM | #132 |
Re: PO has me PO'd
Jaros: I actually had my patch screwed to it while I was fitting it. The only reason I asked was I thought it might have been there to keep the B pillar and rocker from flexing when people stepped in. I really have no clue just a guess since that metal was so thick when I patched it.
Keep up the good work. So day when I learn to post pics I put some up |
02-01-2007, 12:38 PM | #133 |
Re: PO has me PO'd
My man Jaros, your kickin' butt, the weather better warm up so this ole man can get started on his Jimmy. Your work looks great glad, to see your taking your time and doing it right the first time.
I need for the temperatures to warm up a tad (don't want to blowup my shop) so I can paint some interior sheetmetal in preparation of adding firewall insulation and dynamat. Hang in there, nice work for an ole Jarhead |
02-01-2007, 05:56 PM | #134 | |
Re: PO has me PO'd
Semper Fi...Uncle Sam, you da man All parts offered to help are free, unless otherwise noted Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training SAFETY FIRST AS usual, off topic They say your mind goes second, can't remember the first Jim Last edited by jaros44sr; 02-02-2007 at 07:54 AM. |
02-06-2007, 06:56 AM | #135 |
Re: PO has me PO'd
Got my Tabco rocker today, much heavier metal, .045"....
All my home made patch panels are 10 gauge, stood on the rocker panel with out proper support, 2 zip screws, and it didn't flex at all. So to answer the question, yes it is strong enuff. More pics to follow....
Semper Fi...Uncle Sam, you da man All parts offered to help are free, unless otherwise noted Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training SAFETY FIRST AS usual, off topic They say your mind goes second, can't remember the first Jim Last edited by jaros44sr; 02-14-2007 at 05:56 PM. |
02-15-2007, 07:54 AM | #136 |
Re: PO has me PO'd
Here's my current progress:
THANKS GOODMARK, can't imagine how I could have done it without your product!!!
02-15-2007, 08:03 AM | #137 |
Re: PO has me PO'd
Thanks Mods for opening up the board again, I promise to behave and follow the rules...
02-22-2007, 07:14 AM | #138 |
Can't wait to retire!!
Re: PO has me PO'd
Looking good J...what's next?
2009 4x4 Chevy Crew Cab 6.0 1989 4x4 Siverado (270,000 miles) 1972 4x4 Blazer 2007 Chevy Cutaway 1 ton 1970 Corvette (sons project) RIP - CLR 10/11/09 |
02-22-2007, 07:45 AM | #139 |
Re: PO has me PO'd
Thanks Chev. I finally got to do some welding on the 'B' post backing plate, after 6 months of cutting and fitting. I had the rocker panel backing plate bent up at work, it's 10 ga. so it is beefy. Hope the project speeds up now!!! Looks like I only have 3 holes to fill in now. I'll post up some pics as soon as I can...
Going wheeling at Raush Creek this weekend, so I don't think I'll get any work done. I did get the drivers side door assbled, all new pcs., just have to put the glass in. I guess u have to put the window in first, as I can't get it in .... J.
03-03-2007, 12:50 PM | #140 |
Re: PO has me PO'd
How goes the progress? Did you get your door glass in?
03-03-2007, 01:04 PM | #141 |
Re: PO has me PO'd
Nah, but I just got a smoking deal on door locks, Thanks Centsless, my doors are now complete.
Im working on the rockers again, welded in my step up patch moving on from there. Man this 'B' post area is a PITA hardest part so far, has alot of different intersections. Can't take pics rite now, wifey borrowed the camera and left it at my daughters house - baby shower- I was bummed out that I missed it. I was rock crawling instead
03-16-2007, 04:43 PM | #142 |
Re: PO has me PO'd
Did you get your camera back?
03-16-2007, 05:43 PM | #143 |
Re: PO has me PO'd
Not much progress, seem to have lost the drive, maybe it will come back Sat. Anyway here's some pics:
Kinda redesigned things alittle, made it easier to build the part. Don't laugh at my welds it is only tacked in, and I'm using aflux core welder. Makes for a sloppier weld, but I can clean it up later. Every thing seems to fit nice.... J.
03-16-2007, 06:38 PM | #144 | |
GMCDAC
Re: PO has me PO'd
Thanks for the update---Later---DAC
1970 GMC K5 Jimmy Custom 4X4 Mom's driver from 1971 to 2001!! Under rebuild! 1972 GMC C2500 Pickup owned since 1979 Needs a rest and refurbish! 1955 GMC 100 2nd design driven almost daily! Rest In Peace Mom. "Dolly" 7/15/23 - 5/18/09 GMC driver for 30 years! |
03-16-2007, 06:52 PM | #145 |
Re: PO has me PO'd
The patch on the step up is all ground, just takes practice, been awhile since I last welded. I just keep tacking it till it is all filled in, VT had a great idea with the light behind the work, allows you to see any areas not welded. Keep your gaps as tight as you possibly can, makes it a whole hella've lot easier....
Any pics of your progress??? J.
Semper Fi...Uncle Sam, you da man All parts offered to help are free, unless otherwise noted Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training SAFETY FIRST AS usual, off topic They say your mind goes second, can't remember the first Jim Last edited by jaros44sr; 03-16-2007 at 06:56 PM. |
03-18-2007, 10:44 AM | #146 |
Re: PO has me PO'd
Here's my current progress, 2 patches down. Rocker panel backing plate to go
Hey Look, no more rust...
Semper Fi...Uncle Sam, you da man All parts offered to help are free, unless otherwise noted Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training SAFETY FIRST AS usual, off topic They say your mind goes second, can't remember the first Jim Last edited by jaros44sr; 03-18-2007 at 11:00 AM. |
03-18-2007, 11:22 AM | #147 |
PROJECT 7DEUCE
Re: PO has me PO'd
lOOKS GOOD i JUST DID MY PASSENGER SIDE NOT TOO LONG AGO THANK FULLY IT WAS JUST THE FLOOR..
GO BIG GREEN GO DUCKS MEMBER #6377 72 k-5 daily driver 6'' lift 35'' 350-350-205 slowly getting rust free. Project "7DEUCE" check out my build http://67-72chevytrucks.com/vboard/s...d.php?t=267665 Tim Powell..R.I.P EastSideLowlife..... R.I.P.. |
03-18-2007, 12:11 PM | #148 | |
Re: PO has me PO'd
Side note, did you try those 35's with 4" of lift?
Semper Fi...Uncle Sam, you da man All parts offered to help are free, unless otherwise noted Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training SAFETY FIRST AS usual, off topic They say your mind goes second, can't remember the first Jim Last edited by jaros44sr; 03-18-2007 at 12:14 PM. |
03-18-2007, 12:21 PM | #149 |
PROJECT 7DEUCE
Re: PO has me PO'd
I have only rant the 35's with the 6'' lift beacause the wheels are 15x12so I dont think they would of been able to turn.. I worked out to just the rocker since it was fine I do have new ones that I plan on putting in sometime soon though.
03-23-2007, 06:55 AM | #150 |
Re: PO has me PO'd
Here's some pics. of a gusset I'm putting in to add some support to the step up:
Took some metal out, putting some backin
Semper Fi...Uncle Sam, you da man All parts offered to help are free, unless otherwise noted Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training SAFETY FIRST AS usual, off topic They say your mind goes second, can't remember the first Jim Last edited by jaros44sr; 03-23-2007 at 04:47 PM. |
