Old 03-23-2002, 07:09 PM   #1
Southpa
Southpa's Avatar
Post Outlet fittings for 3/4 ton Master cyl...
Are they the same size as those of the 1/2 ton master cyl? I'm thinking about getting rid of this leaky 1/2 ton master w/ the single hold-down clip for a 3/4 ton master (2 hold-downs) seeing as how I already have a 3/4 ton booster. And I don't want to have to re-fabricate the lines going to the prop. valve. Going to buy NEW this time and it will be closely inspected. Any nicks in the top rim and its going down the guy's gullet.
Southpa
1970 GMC 1500 Custom
Victoria, BC, Canada
[This message has been edited by Southpa (edited March 23, 2002).]
Original 350/TH350
You can wish in one hand and crap in the other.
See which one gets filled first.
Southpa is offline   Reply With Quote
Old 03-23-2002, 07:53 PM   #2
jostrans68
Jostrans68
jostrans68's Avatar
Post
no they are not they are backwards
68 c20 in progress 327 TH400 tach dash Disc Brakes and soon 3.90 rear gears.. have many new parts now just need the time..... Sound Familar
[CGTW Member
former 67-72 now with a 96 silverado
jostrans68 is offline   Reply With Quote
Old 03-23-2002, 07:59 PM   #3
Fast68Chevy
Fast68Chevy's Avatar
Post
you can make your own lines form short pieces of lines from auto parts stores, the lines are inexpensive, just out the correct ends that you need on the lines, theya re 3/16" and 1/4"
Fast68Chevy is offline   Reply With Quote
Old 03-23-2002, 09:31 PM   #4
Mike C
Mike C's Avatar
Post
They are reversed, but you can buy adapters at auto parts stores. I ordered new lines for my 3/4 ton when I did the disc swap and they sent 1/2 ton lines. I just bought the adapters and bolted it all up.
70 GMC 3/4 ton Sierra Grande 402/TH400
72 Jimmy 4WD 4spd 4" & 35's
64 Corvette Coupe
68 Camaro 'vert TPI & TH700
69 Z/28 355 12.6's @110
72 Datsun 240Z-ol' reliable
44 Willys MB
52 M38A1
64 Corvette Coupe
68 Camaro 'vert LT1 & TH700
02 GMC 2500HD 4x4 Duramax
